Problem to name subobjects in js/nodeeditor
All  1-7  8-12
7899.8 In reply to 7899.7
Hi Karsten,
> the output node uses clone and after an Apply the edges are
> unnamed - name of the brep is ok.
Ok yeah if it's a Brep being cloned then I think there is a problem in there with sub-object atttributes not coming through. I've got it fixed for v4 but for now try using the copy factory from above to duplicate the Brep instead of clone().
7899.9 In reply to 7899.8
Hello Michael,
I have made a testnode to check the chain "this.setOutputDatata"-> "this.getInputData" from one node to another. The inputdata are complete available - including named subobjects. So I can use this method to select named subelements for a blendnode:-)
When I have finished the node, I will post it to the forum.
By the way: What is the index 1 -|>Orientations in the blend factory for? And what are the parameters? I didn't find something in the blend.js that helps me.
Thank You very much for your help!
Have a nice day
Karsten
7899.10 In reply to 7899.9
Datata has an extra ta ?
-B
7899.11 In reply to 7899.10
Hello Brian,
it is only the increase form of data;-) -> datata -> datataest
Have a nice day
Karsten
7899.12 In reply to 7899.9
Hi Karsten,
When you do a blend, the blend factory will fill that in itself, it stores 2 flags for each blend side, a "flipped" flag for whether the side should be flipped from its natural orientation, and a seam parameter for where the seam point should be located on a closed blend.
Those are then stored in the factory input so they will get serialized into history data and a history update will use any customized seam locations that were set by the user inside the Blend command.
Show messages: All  1-7  8-12
