How to realize this shape
 1-7  8-26
7891.8 In reply to 7891.6
in fact , how i can draw facet into a cylindrical model (see attachment picture)
use Trim, other ?
thanks
EDITED: 9 May 2020 by FINEMA
7891.9 In reply to 7891.8
yes eddy, it's not a pattern (random but design by me) and i want to manage my facets.
thanks
7891.10 In reply to 7891.6
There are some more photos here, including a top view, showing "unsymmetric" shape.
http://www.coroflot.com/cristiano_giuggioli/diamond
Apparently this beautiful bottle design did not win the Agua Carpatica competition (?)
https://www.tumblr.com/search/aqua%20carpatica
The light cast upon the table appears to be the same pattern, for the bottle rotated about 90 degrees.
For a skew quadrilateral, loft of opposite sides can be done, which could make a cutting surface that is not planar...
EDITED: 24 Mar 2016 by BEMFARMER
7891.11 In reply to 7891.10
thanks for this link :)
but it's not resolve my problem...pointed facet on cylindrical shape :)
7891.12 In reply to 7891.11
The glass could start as a box, but I think that the pre-faceted blank bottle should be "convex."
At least partly bulged out "conical", rather than cylindrical.
...Sphericalness or Ovalness...
- B
Hi Finema,
maybe you can try the following out:
Save your model as polygon mesh, use a polygon reduction tool, re-import the reduced version,
cut off the top. Create some circles for the top and do a loft twice.
This is my humble approach which i did quickly on a downloaded slim bottle model.
https://www.behance.net/futagoza
EDITED: 30 Oct 2016 by STEFAN
7891.14 In reply to 7891.11
Hi Finema,
Hmmm, I'm not sure that you're asking for something that's physically possible...
A facet is a planar piece, while the outline you drew earlier on your curved shape was not planar, right? It might be helpful if I had the 3DM file for that rather than just a screenshot.
You can carve off a planar facet from a base solid by creating a plane that intersects the solid and then using boolean difference to slice the solid with a plane. But intersecting your curved surface with a plane will make a rounded intersection with a round object.
Maybe you can describe why you're trying to start with the round object? I think you might be better off working all with faceted construction from the beginning like the examples from others above.
7891.15 In reply to 7891.11
Hi Finema, maybe if you want to use your rounded shape as a guide, you could draw a few points on it using Draw curve > more > Point, and then delete it and use the points to draw lines, then form your facets by selecting the lines and running Construct > Planar to build each facet. For a 4 sided boundary that's not planar, use Construct > Network to fill those in.
My clumsy model, starting with a revolved ellipse:
For the 1st cut, drew a tangent, used new mirrorsymmetry script, did 6 lofts, moved the 6 faces down a bit, and did Boolean diff.
For 2nd cut, did the same with a different tangent, and a rotate and adjust cut position down a bit.
- B
EDITED: 25 Nov 2018 by BEMFARMER
Size: 36 KB, Downloaded: 19 times, Dimensions: 102x196px
7891.17 In reply to 7891.15
thanks for all this solution
@ stefan > reduction polygon is really cool but i can't control the facets but i 'll use it
@ michael > draw point on my shape is the great idea because i can control facet. But how i can snap the points on my bottle ?
@bemfarmer > i 'll use your method for an other design
thanks a lot
7891.18 In reply to 7891.17
Hi Finema,
Just make sure Object Snap is turned on in the bottom toolbar, and then run the Draw curve > More > Point command and click the "Repeat" checkbox, and click several points on the bottle in the 3D view - "on surface" snap will engage in the 3D view to make the points be on the surface.
If other snaps are getting in your way, open the menu above the object snap button and right click on "on surface" to make that the only active object snap type, and later on after you're done return there and right-click on it again to re-enable all the other ones.
Here's a quick example, I'm just picking points in the 3D view:
7891.19 In reply to 7891.18
Thanks a lot Michael
7891.20 In reply to 7891.19
How can i force planar drawing point ?
7891.21 In reply to 7891.20
Hi Finema,
The easiest way is to use one of the ortho views, any of the Top, Front, or Right views (not the 3D view) for drawing any points you want to be planar - when you place points in one of those 2D views it will make all the points after the first one you pick to be on the same plane (oriented to that view) as the starting point.
If you want that to happen on an arbitrary plane then you can set the CPlane first using View > Cplane - once you set a cplane to a custom direction the Top, Front, and Right 2D views will be views relative to that new plane. When you are done with the custom cplane right-click View > Cplane to reset it.
7891.22 In reply to 7891.21
Thanks a lot
7891.23 In reply to 7891.22
You can also pre draw the facets you want to work with then use "pastePart" to build the profile of the bottle with facets. A circle array will then make the revolve of the facets.
May have to do some math to figure out the size of the bottle vs. facet size so an array will connect up. or just manually fill a particular gap with a different set of facets.
7891.24 In reply to 7891.23
Thanks Burrman
Can you show me a simple example ?
7891.25 In reply to 7891.24
Hey Finema,
Here's a quick shot of what I meant. I kindof screwed up the alignment trying to be quick, but this should show what I meant. I don't have a lot of time right now to dig into it, but I think pastepart for building with facets can be your friend. Maybe some "rings" to help aligment etc (Rings like if you were going to loft the bottle)
Anyway, gotta drop off. Hope it helps any..
7891.26 In reply to 7891.25
Thanks BurrMan
It helps a lot
Show messages:  1-7  8-26
