Surface selecting
All  1-2  3-4
7882.3 In reply to 7882.1
Hi Mike, also see here for a script that will grow the selection from one selected face to its neighboring attached ones:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.4
Set that on a keyboard shortcut and then keep triggering it until the selection has spread all the way through.
You can use that if you want to extract out the outer or inner piece of a hollow solid with a cavity in it.
7882.4
Good morning Michael,
My model, although it could be/should be two parts, appears to be fushed or one. When I select one surface and hit command A It selects the entire model. I will need to dissect the surfaces, separate them manually. I'll try the scripts you mentioned.
Mike
Show messages: All  1-2  3-4
