Rhino V5 equivalent commands in Moi
All  1  2-9
7867.2 In reply to 7867.1
One possibility
Use Curves / Iso
then Trim
7867.3 In reply to 7867.2
Thank you Pilou for your answer to my question 1.
Marco.
7867.4 In reply to 7867.3
With the Pilou's method :)
For the question 2, I have the same unwanted lines in 3D view... But not with a export in PDF :
EDITED: 28 Feb 2016 by BEAR17
7867.5 In reply to 7867.1
Hi Marco,
> 1) Is there a Rhino 3d SplitEdge equivalent command in Moi ?
Yes, the Edit > Trim command can be used on an edge in MoI to cut the edge. You don't need to create an isoparm separately, you can use the "Add trim points" option in the Trim command to indicate the spots you want to cut at. So select the edge, run Edit > Trim, then click "Add trim points" and place a point at the desired split location and then right-click to finish the Trim command.
> 2) What are the unwanted lines that i get while in shaded mode, as illustrated by the
> file 05_garbage_lines.jpg ?
> Is there a way to avoid that ?
Those are a display artifact of the realtime display, they are a result of pulling edges and curves towards the eye point to avoid a different and worse artifact of having the edges being partially submerged in the surfaces. See here for more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3933.3
There isn't any way currently to avoid that - it's a normal thing that you will see various kinds of display artifacts in the window display because it is focused on doing things quickly so the display is responsive, it's not focused on trying to make a "pixel perfect" display for generating a final illustration since doing that takes a lot more calculation and waiting.
To get a better quality display you should use something that's focused on image quality rather than focused mainly on speed, so something like a rendering program or MoI's export to PDF or AI format should generate a better quality image.
Hope that helps!
7867.6 In reply to 7867.5
thanks a lot for your detailed reply to my questions.
It's a pity that those display artifacts cannot be avoided in the viewport's display,
'cause i tested that those artifacts are also captured by both the commands getViewport.renderToClipboard() and getViewport.render(),
two commands that would be very useful for creating presentation images of the 3d models.
Anyway, do you think that the next V4 version, will integrate an optional better display mode, in case of using a
discrete video card, like those offered by Nvidia Quadro series ?
(i own a Quadro K3100M 4gb, and i'm planning an upgrade to K5100M 8gb if possible)
Thanks again and good night.
Marco.
7867.7 In reply to 7867.4
Thank you BEAR17 for your answer to my question 2,
unfortunately currently i can only use the trial version, save disabled, of Moi.
Thanks anyway.
Marco.
7867.8 In reply to 7867.6
Hi Marco,
> getViewport.renderToClipboard() and getViewport.render(), two commands that
Yes, that's to be expected because both of those methods use the viewport realtime display
mechanism. They are meant to just capture the display and are not really intended for
making final presentation graphics.
For better quality presentation images, the PDF or AI exports will work much better, those are
the functions that are more oriented towards making a high quality graphic result and not
only primarily focused on speed like the viewport display is. Or also the other main way to get
high quality renders is to export to a rendering program.
> mode, in case of using a discrete video card, like those offered by Nvidia Quadro series ? <....>
I don't know yet what will be done in this area for V4. I have a few ideas on how to improve
that particular display artifact but it has to be done quite carefully in order to not degrade
the performance of the display engine. So any changes have to be tested quite a bit to make
sure it doesn't come at too high of a performance cost. That type of stuff involves quite
a bit of work and it's difficult for me to predict when such things will be completed. It's very
important for the display to be quick so that it can be interactive, the display engine is just
overall much more focused on speed and not on trying to make a presentation type graphic.
Any future improvements in this area will probably involve calculations done by the CPU
before stuff is sent to the graphics card, and so probably won't be dependent on any
specific video card.
7867.9 In reply to 7867.8
now it's all clear. Thank you for your comprehensive answer!
I understand your technical point of view...you prefer to be independent from any particular hardware requirements,
and do all the tasks leveraging on the cpu rather than any type of gpu.
From what I've read here and there on the web, i'v seen that there are two main approaches to display 3d graphics models in realtime.
Someone prefer to squeeze the gpu up to its limits, while others
say that the tasks that a cpu can accomplish are more accurate and reach better results.
I'm sure that whatever approach you will adopt for V4, it will be a good compromise between speed and quality,
(also winking at a better antialiasing quality :)
Have a good work,
Marco.
Show messages: All  1  2-9
