Technical Dashes Script
All  1-2  3-4
7866.3 In reply to 7866.2
Hi Michael ,
Thank you for your quick and clear answer.
I just float the idea. I do not know programming or coding so my help is very limited to start a new script on this subject.
I can continue to work manually to thicken my edges/lines, until Moi will be able to do it (management lines).
Bear
7866.4 In reply to 7866.1
Hi BEAR17,
I don't know if i understood well but if your goal is to quickly draw simple dashed lines,
you can use those very useful scripts written by Max Smirnov and MARTIN3D.
To be more precise, those are by Max : PatternSelection, _PointsOnCurve, FatLines,
and this is by MARTIN3D : HatchIt.
In the attached images you can see two examples of using those scripts.
You can find all those scripts in the thread http://moi3d.com/forum/index.php?webtag=MOI&msg=7862.1 i wrote some days ago,
unzipping the archive indicated in the point "Step 5" of the instructions.
Hope this can help, have a nice day,
Marco.
Size: 200.5 KB, Downloaded: 86 times, Dimensions: 1887x940px
Size: 230.1 KB, Downloaded: 88 times, Dimensions: 1471x966px
Show messages: All  1-2  3-4
