Scripts Icons Gallery
 1-4  5-24  25-44  45-51
7862.5 In reply to 7862.4
You right for any reasons the files and folders were not copyed!
All works fine for the icons! (of Course I must all translate in French! :)
I must also resolve now some problems because seems
There is some problem for some one and some other works fine!
this one is ok! :)
tis one is not OK! :( (works of course when I Press Tab then write _Fatlines !
It's not present on your "commands folder" but present in my "commands folder"!
As the folder commands is yet existing how do you manage files inside with your new commands folder?
EDITED: 25 Feb 2016 by PILOU
7862.6 In reply to 7862.5
Hi Pilou and everyone again.
I tried the FatLines command and all works fine for me.
The UI add on i wrote, needs to have the commands and scripts, contained in the file Step5_Commands_And_Scripts.zip.
One unzipped, you will get 2 elements.
1 folder "commands" and 1 folder "scripts"
Both the folders must be copied into the folder : "<moi install folder>".
In the "commands" folder, for example, there are the FatLines.htm and FatLines.js files, that are required to run the FatLines command.
Note that in my package the command file name is "FatLines" and not "_FatLines".
Hoping this con help.
Marco.
That is that!
You have writed FatLine and not _FatLines! ;)
After rename this inside the Step4 (ScriptsGallery.htm) all works fine for me!
Now some works for me for rename all the commands witout the "_" and translate icons' name! :) (if possible)
Else very cool one plugin! Bravo!
PS if you copied a folder "commands" in the same folder Moi/ where one is yet existing there will be conflict ?
7862.8 In reply to 7862.7
There's one thing that i don't understand yet.
Why do you want to rename some command file names reference in the ScriptsGallery.htm ?
If you copy all the files that are contained into the "commands" and "scripts" folder zipped into the file Step5_Commands_And_Scripts.zip,
you don't have the need to rename anything.
If you copy the "commands" and "scripts" folder in "<moi install folder>",
is it possible that you will get the overwriting file dialog.
In this case, no problem. Answer "yes" and accept the new files.
Marco.
7862.9 In reply to 7862.8
About the command I have yet existing commands in my folder commands so I was affraid that your folder smaller than mine will erase mine!
Possible! ;) And Of course I must change titles! ;)
7862.10 In reply to 7862.8
Hi Pilou and all,
anyway, if someone don't want to use the commands and scripts contained in the file Step5_Commands_And_Scripts.zip,
but want to maintain his current commands or scripts file names, no problem.
In this case, is sufficient to rename the command name referenced in the file ScriptsGallery.htm,
contained into the archive Step4_ScriptsGallery.zip.
I hope that Pilou or someone else will improve this UI add on.
Nice evening.
Marco.
7862.11 In reply to 7862.10
Very nice work on the icons!!!
I believe that all must will work now!
7862.12 In reply to 7862.9
Hi Pilou and all,
I think that this be useless, but.....
as a general info, if you overwrite a folder that contains, let's say, 10 files,
with a folder that have the same name, but contains, let's say, only 5 files,
this operation wan't delete any files from your original folder.
If the folder you are copying contains new files, those files will be copied to the original folder,
while every files with the same name will be overwitten.
So, no problem if the "commands" and "scripts" folder that are contained in the Step5_Commands_And_Scripts.zip file,
have less files then your actual folders.
Marco.
EDITED: 25 Feb 2016 by MKDM
7862.13 In reply to 7862.12
Thanks for the info and in any case we can make a save before in case of! ;)
7862.14 In reply to 7862.13
You are welcome.
Anyway i relaunch the proposal to anyone is interested to improve this add on with new/modified icons, and/or new commands or scripts.
Nice evening.
Marco.
Yes, the task will be an easy system for add its own icons or future new Scripts / commands ! ;)
7862.16 In reply to 7862.14
Hi Marco,
Great job! Nice icons. I took different approach ( See attached image). I used MOI option Dialog and created the Plugin gallery. The dialog can stay open or you can drag it to second monitor and free-up the moi viewport. This is part of my overall UI modification. I will be happy to share it just need to write instruction for installation.
-sharif
Size: 142.6 KB, Downloaded: 294 times, Dimensions: 994x960px
7862.17 In reply to 7862.16
Hi Sharif,
I'm happy to see that in this forum good ideas never die :)
I like your approach and i think it will be very useful, although,
for a more practical use, it needs doubtless a second monitor.
In my opinion, the very best tool to obtain a real cool plugin library,
would be to have this two things linked together :
a panel gallery based on big and nice, and self explanatory icons,
like ones did by you or me (i prefer colorful icons than grey ones),
and, above all, a text command search with auto completion.
So, while someone writes some letter of a command name, the panel filters the icons accordingly.
You might even think to filter the search based on some hidden description apppliyed to each or some of the commands.
So, if i have, let's say, 400 or more commands and scripts, and i need a tool
that help me to create some kind of stuff, the search should show me all the commands and script that are
candidate to do that stuff.
Maybe someone wants to dig into this challenge ?
I hope someone will do.
Nice night.
Marco.
French version of the Marco list done! :)
http://moiscript.weebly.com/liste-scripts-commandes.html
Hi Marco, thanks for sharing your work!
7862.20 In reply to 7862.19
Not at all!
It was a some sort of break time from my daily job,
'cause i'm an hobbyist and an enthusiast in cad and 3d modelling and in computer graphic in general.
Using Moi is almost always a fun, and i think, that most of the philosophy that lies behind Moi,
should, in general, be shared by others cad/3d software, like, just to name one, Rhino.
Not for nothing that product was also written by you, if i remember correctly... :)
What do you think about my post to Sharif about the convenience to write some sort of plugin gallery that
will supply a sort of filter search based on some hidden descriptions applied to each or some of the commands,
and should filter the shown icons accordingly ?
Are you thinking some similar sort of thing for version V4 ?
Thank you for all and nice day.
Marco.
7862.21 In reply to 7862.18
Thank you very much for your translating job!
I am pleased to see that you have appreciated my little and funny job.
Now...do you want also design some different and funny colored icons ? :) :)
A sort of skinnable Moi's UI....
What do you think 'bout ?
Nice day.
Marco.
7862.22 In reply to 7862.21
Design icons is not an easy work!
It's difficult to keep same style for numerous pieces!
I prefer play with more free organic volumes! ;)
Here Bemfarmer SinWave along a Sinwave path with a hole texture material! :)
EDITED: 26 Feb 2016 by PILOU
7862.23 In reply to 7862.22
Unconventional 3d modeling....as usual.
Nice job!
Yes, I agree with you that the hardest work, regarding the design of a skinnable UI, is to keep same style for numerous icons,
while maintaining those, eye catching and self explanatory.
Marco.
7862.24
Very nice, Marco.
Very good instructions which I failed to follow precisely but got there in the end.
Love it.
Many thanks,
Mike.
Show messages:  1-4  5-24  25-44  45-51
