Scripts Icons Gallery
 1-6  7-26  27-46  47-51
All is done for the French Version! :)
http://moiscript.weebly.com/liste-scripts-commandes.html
7862.28 In reply to 7862.20
magnificent JOB Marco
congratulation !
M.O.I , already great ,with your job and other contributors begin to be incredible !
Thanks to you and thanks for sharing.
Thanks to PILOU for french translation
EDITED: 27 Feb 2016 by CHRI
Size: 102.1 KB, Downloaded: 109 times, Dimensions: 1277x740px
7862.29 In reply to 7862.28
Hi, Pilou and christian (CHRI).
Thank you christian for your words regarding my job.
I enjoyed myself in designing those icons.
Now, it's my intention to focus more on pure nurbs modeling,
both in Moi and in Rhino.
Anyway, like i said to Pilou, is there someone who wants to supply new/better self-explanatory icons for the plugin gallery ?
who knows .....?
Pilou, thank you very much for your translation work!
You're a very patient man :)
Nice night,
Marco.
7862.30
I seem to have a French version of Chain Maker....
All the others that I have tried have been in English.
Is it just me?
Mike.
PS By the way, I'm not entirely sure that Chain Maker should be in 'Mechanical'. I ran it expecting to get an Engineering type chain.
7862.31 In reply to 7862.30
Maybe you must turn Options / Language in French ?
And you must make all this "French" installation!
7862.32 In reply to 7862.31
I think that I expressed myself poorly.
I want it in English like the rest of the icons that I've clicked.
7862.33 In reply to 7862.32
So In Eglish follow the first post of this thread! ;)
7862.34 In reply to 7862.30
Hi Mike, I think you can find the original chain maker script which was in english here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6087.67
If you overwrite your french version with that original English one that should then set you up with the english command.
7862.35 In reply to 7862.34
Thanks, Michael.
That did, of course, do the trick.
Mike.
If you want to add an icon to a "One Line" script like Loop Selection for example
 script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Just create a .js file with a text editor and make the same than above post #1! ;)
Very detailed method http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS&msg=485.20 for French readers! ;)
EDITED: 29 Feb 2016 by PILOU
7862.37
Thanks for this cool script! ;)
I was wondering if you use the kitbash script as well, because it seems not display in the menu kitbash since i copy paste the codeline if Icon in the CommandBar.htm (step 3).
Does someone find a solution?
Thanks.
7862.38 In reply to 7862.37
Hi vangcki, this menu is a bundled package of scripts, and it did not happen to include the kitbash script.
If you wanted the kitbash script to show up on this UI, you would need to modify the ScriptsGallery.htm file that is part of the installation package and add in an additional <moi:CommandButton> element under the section where you wanted the kitbash icon to appear in.
7862.39
This script gallery looks very nice!
However I couldn't install it properly :(
I followed the instructions but I end up with this:
- Script Gallery button is not aligned to the rest of buttons from Max's custom UI.
- Option and help Buttons overlap the other buttons.
- When I click on Scripts Gallery button, I can see the icons and tabs but they are far apart from each other and I have to scroll to find them.
What am I doing wrong here?
I'm using V4 beta
Any help would be appreciated.
Size: 336 KB, Downloaded: 129 times, Dimensions: 1918x1038px
7862.40 In reply to 7862.39
Hi Stargazer, that looks like what would happen if you installed the old version of CustomUI that is for MoI version 3, instead of the newer one that is for V4.
7862.41
I have installed CustomUI.2.0.beta2
7862.42 In reply to 7862.41
Hi Stargazer, did you overwrite any files inside MoI's UI directory?
7862.43
No, I only overwrote commands folder.
I also added the block of code from the instructions to CommandBar.htm and EnglishStrings.txt.
Thank you for your responses!
7862.44 In reply to 7862.43
Hi Stargazer, those instructions are for the old version of CustomUI though that only works with MoI v3.
The instructions for CustomUI.2.0.beta2 are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
For v4 it goes in the appdata directory now and you shouldn't modify CommandBar.htm anymore for v4.
Please carefully check what version you're getting because what you show and describe all fit with the old version of CustomUI and not the one that works with v4.
7862.45
Sorry, I think I explained my self poorly.
When I said I copied the block of code from the instructions, I didn't mean the instructions for older Custom UI. I meant the instruction for installing Scripts Icons Gallery.
I'm using the new Custom UI and its files are located in my "AppData\Roaming\Moi" folder.
Thanks again,
7862.46 In reply to 7862.45
The instructions for the Scripts Icons Gallery are over 3 years old.
Has anyone installed them recently, in MoI v4 beta?
Edit: The first post says "This UI add on, works with or without the fantastic Max's CustomUI."
So whatever the install problem is, it is not dependent upon CustomUI (IMHO).
Modification was to MoI3 (?) So new install for MoI4 beta would have different (Unknown) requirements. (AFAIK).
Perhaps new instructions could incorporate the Gallery into CustomUI?
A cross between Max's Object Library and Scripts Icons?
And also add subdirectories to Max's Object Library, and/or Scripts Screen?
(These are comment questions, not question questions :-))
EDITED: 13 Apr 2019 by BEMFARMER
Show messages:  1-6  7-26  27-46  47-51
