Scripts Icons Gallery
 1-20  21-40  41-51
7862.21 In reply to 7862.18
Thank you very much for your translating job!
I am pleased to see that you have appreciated my little and funny job.
Now...do you want also design some different and funny colored icons ? :) :)
A sort of skinnable Moi's UI....
What do you think 'bout ?
Nice day.
Marco.
7862.22 In reply to 7862.21
Design icons is not an easy work!
It's difficult to keep same style for numerous pieces!
I prefer play with more free organic volumes! ;)
Here Bemfarmer SinWave along a Sinwave path with a hole texture material! :)
EDITED: 26 Feb 2016 by PILOU
7862.23 In reply to 7862.22
Unconventional 3d modeling....as usual.
Nice job!
Yes, I agree with you that the hardest work, regarding the design of a skinnable UI, is to keep same style for numerous icons,
while maintaining those, eye catching and self explanatory.
Marco.
7862.24
Very nice, Marco.
Very good instructions which I failed to follow precisely but got there in the end.
Love it.
Many thanks,
Mike.
7862.25 In reply to 7862.20
Hi Marco,
> What do you think about my post to Sharif about the convenience to write some
> sort of plugin gallery that will supply a sort of filter search based on some hidden descriptions
> applied to each or some of the commands, and should filter the shown icons accordingly ?
> Are you thinking some similar sort of thing for version V4 ?
I can't say for sure which specific version will have it (like whether it will be for V4 or not until some time later than that), but I definitely want to work on a plug-in browsing system similar to what you are describing.
Something like a "Browse plugins" button and if you clicked it a dialog would come up with different categories and yes I guess probably a search function eventually too, where you could go and then click a button to install it and probably assign a shortcut key to it there too.
Something like that anyway...
There will be a significant amount of work involved in creating that entire system though, so it's difficult to know exactly when it will be implemented. Right now plugins in general is not my main priority, I'm still working on much more basic things still.
7862.26 In reply to 7862.24
Hi Mike,
Thank you very much for your appreciation of my job, and i'm glade to know that all worked for you.
Let me know if the instructions i wrote are incomplete or broken, and if anyone wants to
write more clearly instructions, it's free to do it :)
Nice day,
Marco.
All is done for the French Version! :)
http://moiscript.weebly.com/liste-scripts-commandes.html
7862.28 In reply to 7862.20
magnificent JOB Marco
congratulation !
M.O.I , already great ,with your job and other contributors begin to be incredible !
Thanks to you and thanks for sharing.
Thanks to PILOU for french translation
EDITED: 27 Feb 2016 by CHRI
Size: 102.1 KB, Downloaded: 109 times, Dimensions: 1277x740px
7862.29 In reply to 7862.28
Hi, Pilou and christian (CHRI).
Thank you christian for your words regarding my job.
I enjoyed myself in designing those icons.
Now, it's my intention to focus more on pure nurbs modeling,
both in Moi and in Rhino.
Anyway, like i said to Pilou, is there someone who wants to supply new/better self-explanatory icons for the plugin gallery ?
who knows .....?
Pilou, thank you very much for your translation work!
You're a very patient man :)
Nice night,
Marco.
7862.30
I seem to have a French version of Chain Maker....
All the others that I have tried have been in English.
Is it just me?
Mike.
PS By the way, I'm not entirely sure that Chain Maker should be in 'Mechanical'. I ran it expecting to get an Engineering type chain.
7862.31 In reply to 7862.30
Maybe you must turn Options / Language in French ?
And you must make all this "French" installation!
7862.32 In reply to 7862.31
I think that I expressed myself poorly.
I want it in English like the rest of the icons that I've clicked.
7862.33 In reply to 7862.32
So In Eglish follow the first post of this thread! ;)
7862.34 In reply to 7862.30
Hi Mike, I think you can find the original chain maker script which was in english here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6087.67
If you overwrite your french version with that original English one that should then set you up with the english command.
7862.35 In reply to 7862.34
Thanks, Michael.
That did, of course, do the trick.
Mike.
If you want to add an icon to a "One Line" script like Loop Selection for example
 script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Just create a .js file with a text editor and make the same than above post #1! ;)
Very detailed method http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS&msg=485.20 for French readers! ;)
EDITED: 29 Feb 2016 by PILOU
7862.37
Thanks for this cool script! ;)
I was wondering if you use the kitbash script as well, because it seems not display in the menu kitbash since i copy paste the codeline if Icon in the CommandBar.htm (step 3).
Does someone find a solution?
7862.38 In reply to 7862.37
Hi vangcki, this menu is a bundled package of scripts, and it did not happen to include the kitbash script.
If you wanted the kitbash script to show up on this UI, you would need to modify the ScriptsGallery.htm file that is part of the installation package and add in an additional <moi:CommandButton> element under the section where you wanted the kitbash icon to appear in.
7862.39
This script gallery looks very nice!
However I couldn't install it properly :(
I followed the instructions but I end up with this:
- Script Gallery button is not aligned to the rest of buttons from Max's custom UI.
- Option and help Buttons overlap the other buttons.
- When I click on Scripts Gallery button, I can see the icons and tabs but they are far apart from each other and I have to scroll to find them.
What am I doing wrong here?
I'm using V4 beta
Any help would be appreciated.
Size: 336 KB, Downloaded: 129 times, Dimensions: 1918x1038px
7862.40 In reply to 7862.39
Hi Stargazer, that looks like what would happen if you installed the old version of CustomUI that is for MoI version 3, instead of the newer one that is for V4.
Show messages:  1-20  21-40  41-51
