sine wave script
 1-7  8-27  28-34
7861.8 In reply to 7861.7
Thanks Michael.
So I guess a "thumbnail" viewer would be a lot harder to write, or maybe be too slow...
7861.9 In reply to 7861.8
Hi Brian, well I think the idea for those viewers is to be able to interactively rotate/pan/zoom the model which won't work with a thumbnail image.
Right now MoI does not write a thumbnail image into 3DM files either, but that's something I want to add in the future.
Funny! A sine wave along a sine wave! :)
French version: http://moiscript.weebly.com/geacuteomeacutetries-par-bemfarmer.html
(holes are only a texture with holes! ;)
EDITED: 24 Feb 2016 by PILOU
7861.11
Thank you gentleman for your help, Bemfarmer youre amazing !
7861.12 In reply to 7861.11
Thanks Tom. The scripts are mainly cut and paste, based upon Michaels scripts, and study of them.
Attached is an update, adding spherical sine wave. It was a bit harder, due to imaginary numbers turning up in the spherical formula, due to possible
square root of negative numbers. So there is an alert if amplitude squared is greater than radius squared. Note that negative amplitude is possible, resulting in "phase shifts." The solution is cobbled together. Maybe there is a better way. The .js and .htm in the zip are not labeled 2, so they could overwrite older versions.
7861.14 In reply to 7861.12
Hi Benfarmer , very cool to see you have updated the script - never thought of a circulear sine wave before ... works perfectly !
EDITED: 2 Mar 2016 by SIRTOM
Size: 45.5 KB, Downloaded: 59 times, Dimensions: 555x439px
7861.15 In reply to 7861.14
Im really impressed with the circular sine wave . is there an easy way to create
only a segmented circular sine wave (like 30° / 60° etc), Bemfarmer ?
Create CircularSinWave2
In view Top
PolyLines : you can take any angle in seeing the Bottom task Bar case < angle or input angle by numeric keyboard!
Trim ;)
Seems some speedy! And avoid headache to Bemfarmer! :)
EDITED: 2 Mar 2016 by PILOU
7861.17 In reply to 7861.16
Never intended to create headache to benfarmer ;-) I thought maybe it is only the need
to change a number in the code - for example I changed "8" to "3" in the code of the array command
to generate 3 instead of 8 instances.
Btw what renderer did you use for that nice "sinewave" rendering ?
7861.18 In reply to 7861.17
<< what renderer did you use for that nice "sinewave" rendering ?
The funny easy tricky SimLab Composer! (not free: 4$/month hobbyist-student)
and at the end you can use some of these 2 other free ones !
from a Sketchup model by NextDave
Sketchup Make (free)
Simlab
then Fotor
and finally Fotosketcher + Fotor
EDITED: 3 Mar 2016 by PILOU
7861.19
Hi Pilou
nice - where did you get that setup for Simlab?
7861.20 In reply to 7861.19
<< where did you get that setup for Simlab?
for the first image rendered
Just pick Materials from the Gallery of Materials as explained on the video
and apply them on each different part of your model by moving from Material to the piece (selected or not) on the screen!
This can be made even during the rendering itself!
7861.21
A proposal : an icon of CircularSinWave2 script ( and for the script icons gallery )
7861.22 In reply to 7861.21
7861.23 In reply to 7861.21
Hi BEAR17,
That's a similar proposal for the CircularSinWave2 icon,
that imitates the style of the other icons in the package of the thread http://moi3d.com/forum/index.php?webtag=MOI&msg=7862.1
Nice night,
Marco.
Size: 407.9 KB, Downloaded: 30 times, Dimensions: 1600x1600px
7861.24
Hi Marco,
I think my icon is more appropriate :
- More simple it is, the better is
- The script does not allow a tubing of the curve (as suggested by your icon)
- In the scripts gallery, there are many more icons with a representation of orange curve as solid.
Of course, it's only my opinion.
Bear
7861.25 In reply to 7861.24
Hi BEAR17,
in general i also agree to keep things as clear and simple as possible,
but, if you notice in my original icons package, i have drawn some of the icons in
a way that may help to identify a possible use of the resulting curves generated by the various scripts, as i did with the icons for CircularSinWave2 or DupinCyclidesUV.
But, of course, it's only a matter of personal taste.
Nice day,
Marco.
7861.26 In reply to 7861.18
Thank you Pilou, very informative !
7861.27
Another question regrading the script :
The sine wave always starts at the origin point . is there a way of letting
it start at specific coordinates ?
Show messages:  1-7  8-27  28-34
