can't solve chamfer problem...
All  1-9  10-16
7843.10
Hello,
Your construction lines are a little out of square (Align is your friend), also try moving the egg shaped seam to the midpoint of a larger face.Those construction lines have a crazy amount of points, for clarity I rebuilt and aligned, and it chamfered fine, even with or without straight edges enabled. I have some time for a video if needed.
Chamfer
EDITED: 2 Feb 2025 by OSTEXO
Hi OSTexo,
if your time allows it would be nice and appreciated to see your solution too, to get a better understanding!
Best regards
7843.12
Hello,
Video is up:
https://vimeo.com/154803074
EDITED: 3 Feb 2025 by OSTEXO
Master class of rebuilding!
Hi OSTexo,
thanks a lot for taking the time, showing your technique! This is very helpful in the future for me.
Learned some new things from you.
Best regards
7843.15 In reply to 7843.14
Stefan, here is another complementation for Ostexo's tut... for rebuilding top surface.
Clean and fast with Box, Isect, Network
Envelop with box
Use Isect, after delete all solids
Cleanup and use Network
Trim and shrink
-EDDI
7843.16 In reply to 7843.15
Oh, that's a great way to avoid those seam lines at all! Thank you very much for showing this Eddi!
Will be very helpful in the future.
Best regards
Show messages: All  1-9  10-16
