can't solve chamfer problem...
Hi Michael and all,
i have a part which i can't chamfer at all. I need it with the chamfer value of 0.1
I tried to rebuild as lofted model and also tried other approaches. but all failed.
The only thing one time i got was a joined surface part, but i need a solid, so that
i can 3D print it. I have many similar parts, which i could solve with Rhino eval. etc.
but this is the only part from the whole model where i get stuck.
Any help how to solve this chamfer problem would be greatly appreciated!
EDITED: 4 Nov 2016 by STEFAN
7843.2 In reply to 7843.1
Ok, problem solved for now (with the free Autodesk 123Design)... :-)
7843.3 In reply to 7843.1
Hi Stefan,
I'm not sure what the problem is, but it looks like to many naked edges.
I would rebuild it like so.
1. Re-create the two profiles.
2. Run "Planer" on the poly-line piece
3, Trim that with the oval.
4. Extrude that.
5 Create two curves and boolean diff, removing the top and bottom pieces.
6. Run the Chamfer tool.
Works for me.
scott
Hi Scott,
thanks for your reply, much appreciated! Unfortunately your technique does not work. I attach a picture
which shows the difference with your approach. I must learn more about this naked edges issue and how
to solve this, in case if this is the problem.
EDITED: 30 Oct 2016 by STEFAN
7843.5 In reply to 7843.3
Guess I was a little late.
Here is take two, where instead of creating two curves, you create two fairly large spheres, positioned slightly apart to account for the thickness you need.
Use one sphere and run Boolean Diff.
With the other, run a Boolean Intersect.
scott
7843.6 In reply to 7843.1
Replace exterior wall and interior wall with sweep and join all back to solid
File for testing attached
(Blue profiles, red rails)
-EDDI
Hi Scott,
thanks again, but your part does not have the curvature which i need. ;-) Thanks anyway for helping me!
Hi Eddi,
that's it! Perfect! Many thanks for your solution, much appreciated!
Best regards
7843.8 In reply to 7843.6
I began with that approach eddi, but then stopped after having the other rebuild idea.
Nice solution!
-s
7843.9 In reply to 7843.7
No problem Stefan.
-s
7843.10
Hello,
Your construction lines are a little out of square (Align is your friend), also try moving the egg shaped seam to the midpoint of a larger face.Those construction lines have a crazy amount of points, for clarity I rebuilt and aligned, and it chamfered fine, even with or without straight edges enabled. I have some time for a video if needed.
Chamfer
EDITED: 2 Feb 2025 by OSTEXO
Hi OSTexo,
if your time allows it would be nice and appreciated to see your solution too, to get a better understanding!
Best regards
7843.12
Hello,
Video is up:
https://vimeo.com/154803074
EDITED: 3 Feb 2025 by OSTEXO
Master class of rebuilding!
Hi OSTexo,
thanks a lot for taking the time, showing your technique! This is very helpful in the future for me.
Learned some new things from you.
Best regards
7843.15 In reply to 7843.14
Stefan, here is another complementation for Ostexo's tut... for rebuilding top surface.
Clean and fast with Box, Isect, Network
Envelop with box
Use Isect, after delete all solids
Cleanup and use Network
Trim and shrink
-EDDI
7843.16 In reply to 7843.15
Oh, that's a great way to avoid those seam lines at all! Thank you very much for showing this Eddi!
Will be very helpful in the future.
Best regards
