Cycling shortcuts
All  1-2  3-10
7838.3 In reply to 7838.2
Michael You are the best. That's exactly what I needed. Thanks for taking the time to write this cool script.
7838.4 In reply to 7838.3
double post
EDITED: 17 Feb 2016 by ARCMAN
7838.5 In reply to 7838.2
I stumbled upon small inconvenience when applying your script to shortcuts. When I cycle between commands assigned under one tab (there are 2 tabs - "draw curve" and "draw solid") all works brilliant and I got visuall feedback instantly with right commands highlighted in the menu. But when I draw ex. Line and then press shortcut to draw Box (which is in "draw solid" tab) Moi doesn't automatically change tabs and doesn't show that the active tool has changed (I have to manually change tabs). It would be cool if you could address this issue Michael.
7838.6 In reply to 7838.5
Hi arcman, you can fix this by adding the following script to the end of that previous script (paste it in at the end of it):
var tabname = 'DrawCurveTab'; moi.ui.getUIPanel('moi://ui/SidePane.htm').document.getElementById(tabname).parentElement.activeTab = tabname;
That should then make the Draw curve tab be the active one.
For other tabs, change the value 'DrawCurveTab' at the start above to the particular tab name you want, the different tab names are:
'DrawCurveTab' , 'DrawSolidTab' , 'EditTab' , 'ViewTab' , 'SelectTab' , 'ConstructTab' , 'TransformTab'
Hope that does what you are looking for.
7838.7
This is great!
7838.8 In reply to 7838.6
Thanks Michael, everything works great now - expect one thing:) Tools that don't come in many variations aren't higlighted in side menu when pressing a shortcut key assigned to them (like ex. sphere). I know it's a nitpick but when this is solved your scripts for shortcut keys will officialy reach an ultimate state of perfection :D
7838.9 In reply to 7838.8
Hi arcman,
It looks like a case sensitivity bug, the button will only highlight if the command you put in matches the same exact case as what is on the button's HTML code.
So for sphere for instance put it in as all lower case like: sphere and then it should highlight. If you put it in as something like Sphere with a leading capital letter, it will get launched ok (the launching part is not case sensitive) but it will miss the button highlighting part.
I'll fix that up for v4 so that the button highlighting isn't case sensitive.
7838.10 In reply to 7838.9
Lower case works. Thanks a lot.
Show messages: All  1-2  3-10
