Scriptproblem with BReps and getNackedEdges
All  1  2-4
7819.2 In reply to 7819.1
Hi Karsten - it's a spelling problem there, (or more likely an unintended translation?) the name of that method is .getNakedEdges() - you've got an extra c in the middle there that needs to be removed.
That method will get edges that belong to only one face and are not joined between 2 faces.
The other edge getting methods you can call on a brep or face are:
getEdges() // Gets all edges
getJoinedEdges() // Gets edges that are joined between 2 faces (or seams too I think), leaving out naked edges
getNakedEdges() // The one you're trying to use
getSeamEdges() // Gets the seam edges of a closed surface.
Also another way to go through edges is to do it by the trim boundaries on a face by calling face.getLoops() - that returns a set of boundaries with the first boundary being the outer boundary of the face and any next ones being holes. Each boundary is itself a list of edges that make up the boundary.
Hope this helps!
7819.3 In reply to 7819.2
Hello Michael,
thank You very much! I will test it:-)
Have a nice day
Karsten
7819.4 In reply to 7819.3
Thanks again, Michael,
now everything works fine:-)
Show messages: All  1  2-4
