strange trim behavior / how best to align points on curve?
All  1  2-3
7816.2 In reply to 7816.1
Hi yophie - it's because the curves you are trying to trim with each other do not actually touch each other, there seems to be a pretty significant gap between them, about 0.25 units or so:
It looks like the curves in the upper third area did touch the edge, that's why those ones worked.
When they don't touch each other the regular Trim function is not going to be able to find an intersection between them. It is possible to do an "apparent intersection" trim, if you switch to the Front view, and make sure the checkbox for "Project intersections" in the Trim options is turned on and then you can cut them to the 2D projection of the edge curve but there will still be a gap between them since they don't touch each other in 3D space.
re: align points - there is a script that will place a point object at the start point of a curve, it might help - it's available here: http://moi3d.com/forum/display.php?webtag=MOI&msg=2888.11 it it's the opposite point you end up needing (the end point of the curve rather than the start point), you can edit that script in a text editor and change the part that says .getStartPt() to instead say .getEndPt() and save it off as a new script which will create an end point instead of a start point.
Hope this helps!
7816.3 In reply to 7816.1
Hi yophie, and maybe your array curve did not do what you thought - when you do an Array curve to replicate an object along a path, the object is duplicated along points calculated along the path curve. If you use the "Align to surface" option, it will also look at the surface normal at each point and make sure that there is an additional rotation done to keep something that was starting out coming off perpendicular from the surface to stay perpendicular to the surface at each copied location. But that option is for making copies of something that sticks up vertically along the surface normal like a little spike or cylinder or something like that. If you're copying a curve instead like you're doing it does not guarantee that the copied curves are on the surface at every spot along the curve. In general ArrayCurve can't guarantee that for curves it is copying because it only does a move and rotation of the base object, it does not try to morph or warp the curve to make it stick down to the surface at all points along the curve.
Show messages: All  1  2-3
