CustomUI
7813.1
Lighting Presets and Extscripts work perfectly, however ObjLibrary and Snapshot does not work
I tried to solve in different ways does not work
Lighting and Extscripts It works correctly
I need help to fix it
Thanks !!!!
Size: 1.1 MB, Downloaded: 198 times, Dimensions: 1920x1080px
Size: 1.1 MB, Downloaded: 113 times, Dimensions: 1920x1080px
Size: 1.1 MB, Downloaded: 78 times, Dimensions: 1920x1080px
Size: 313.9 KB, Downloaded: 96 times, Dimensions: 1920x1080px
Size: 622.6 KB, Downloaded: 74 times, Dimensions: 1920x1080px
Size: 1.1 MB, Downloaded: 91 times, Dimensions: 1920x1080px
Size: 596.1 KB, Downloaded: 60 times, Dimensions: 1920x1080px
7813.2 In reply to 7813.1
Hi Get Root, sorry I don't know why those would not work for you.
Do you see any different behavior if you launch MoI by right-clicking on the MoI shortcut and choose "Run as Administrator"? That may help if it's a file permission thing you are running into.
Also you might check that you're using the latest version and not an older one. I think you can get the latest from Max's file archive here: http://moi.maxsm.net/media/files/ - find the one named CustomUI.1.03.win.mac.zip
Message 7813.3 deleted 13 Jan 2016 by BEMFARMER
Message 7813.4 deleted 13 Jan 2016 by BEMFARMER
7813.5
Thank you all
this version worked CustomUI.1.03.win.mac.zip Sat Aug 29 20:44:22 2015 98761
Amazing Michael Gibson
It is solved
7813.6 In reply to 7813.2
As this version CustomUI.1.03.win.mac.zip worked Thanks man
7813.7 In reply to 7813.2
Running MoI as admin fixed the issue with the object library.
7813.8 In reply to 7813.6
Can someone share this file with me?
