Planar not working on closed curve
All  1-2  3-10
7800.3 In reply to 7800.2
Doh, the curve is not flat (0,0029 in Z direction).
Thanks!
7800.4
Hi Nic :
a quick method is to project your closed curve on a flat plane,select the projected one and hit - planar surface- command
M
7800.5
Select curve, show points, go in the front view, align top.
That's the cleanest way to make it planar without rebuilding the structure.
M.
7800.6 In reply to 7800.5
The edit frame has a "flat" snap that works well for this.
7800.7 In reply to 7800.6
Yeah I like using the edit frame for this, here's an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3378.4
If you don't see flat snap engage it means it was already flat.
7800.9 In reply to 7800.8
Hey frenchy,
The cost of that looks to be around 2 bits!
7800.10 In reply to 7800.9
@Burr
A flat coin indeed! ;)
Show messages: All  1-2  3-10
