 1-12  …  953-972  973-992  993-1012  1013-1032  1033-1052  …  1853-1859
7777.993 In reply to 7777.988
P.S....
James, where can I find the retopoSurfs node ?
7777.994 In reply to 7777.993
Hi Marco,
Place the attached file into directory
~/Library/Application Support/Moi/nodeeditor/macros
EDITED: 14 May 2019 by JFH
7777.995 In reply to 7777.994
Hi James.
Thanks, but...where is this folder ? "~/Library/Application Support/Moi/nodeeditor/macros"
I have a Windows machine and my folders for Node Editor are :
1) For Moi V4 : C:\Users\<user name>\AppData\Roaming\Moi\<node editor folder>
2) For Moi V3 : C:\Program Files (x86)\MoI 3.0\ui\<node editor folder>
Any help ?
7777.996 In reply to 7777.995
Hi Marco,
Sorry the directory path was for a mac.
So rather it would be (for Moi V4)
C:\Users\<user name>\AppData\Roaming\Moi\nodeeditor\macros\retopoSurfs.nod
If there is not already a "macros" folder, make one.
Let me know if this doesn't work. I don't really know my way around PCs
7777.997 In reply to 7777.996
Thanks a lot James!
I've tested in V4 and it works :)
Does it work also with the latest Nodeditor for MoiV3 ?
7777.998 In reply to 7777.996
P.S.
I've made some experiment....what a wonderful Swiss-Army-knife for some situations where I simply want to turn a single surface to ALL QUADS!!!
Thank you very much!!!!
7777.999 In reply to 7777.988
Hi James,
just tried to run nod on half sphere surface and just a tangled result.
Are there any restrictions on what surfaces the nod can be applied to.
Update once surface goes wrong all following selections go wrong as well
even those that previously worked correctly.
Barry
EDITED: 19 Apr 2018 by BARRY-H
7777.1000 In reply to 7777.999
Hi Barry
<< Are there any restrictions on what surfaces the nod can be applied to.>>
Yes, it will only work with 4 edged surface patches.
<< just tried to run nod on half sphere surface and just a tangled result.>>
This is a difficult one because you can't start with sphere solid, because it won't work with trimmed surfaces.
Attached is method for retopologizing a 3 edged hemisphere made by networked curves.
7777.1001 In reply to 7777.1000
Hi James,
Ok that’s good will stipulate the 4 edge requirement in my other post.
However the concern I have is once a surface that does not meet that
requirement causes the macro to crash and the following correct
surfaces also crash.It would be good if a reset within the nod was possible.
The only way I see to reset the nod file is to close and reopen Moi ?
Anyway thanks for your help I think your macro is well worth developing.
Only wish I had the knowledge to be more help.
Barry
7777.1002 In reply to 7777.1001
Hi Barry
Can you send me the .3dm file so that I may reproduce the error
and perhaps find a work around.
7777.1003 In reply to 7777.1002
Hi James,
I'm using the file I posted(http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.987)
Just added a sphere and trimmed it on it's seam to make a dome surface and named it S8.
From the photo you can see the tangled result of the dome and when S7 was next applied
you can see it is also wrong.
I noticed the surfaces spike to drawing origin.
Barry
Size: 79.2 KB, Downloaded: 111 times, Dimensions: 500x293px
7777.1004
Hi All,
I feel nodeeditor has been neglected, so this weekend I decided I would play around with it.
Below is an unintended result of that play.
The other attachments are also outcomes of the same nod circuit:" surfTria.nod".
Have a great weekend
Size: 116.9 KB, Downloaded: 93 times, Dimensions: 750x600px
7777.1005 In reply to 7777.1004
Hi
How it works ?
7777.1006 In reply to 7777.1005
Hi Finema,
>> How it work <<.
I doubt this will be satisfactory, but the short answer is as follows:
Set up nodes to create base surface tesselation of hexagons, each lofted to a centre point to make triangular tiles and flow to target surface.
The underlying hexagonal pattern is variable in row and column , While the triangles are height variable of ctr.
Hope this helps
EDITED: 27 May 2018 by JFH
7777.1007 In reply to 7777.339
Cool!
7777.1008
Some further development based on previous nod file
7777.1009 In reply to 7777.1008
Hi James
Can you share the 3dm file and the library used in your nod ?
Thanks a lot
7777.1010 In reply to 7777.1009
Hi Finema,
>> Can you share the 3dm file <<.
The nod file works on its own, without input curves or the like.>> .....and the library used in your nod ? <<.
I take it by "library" you mean my "Extensions" folder of node editor. Please find attached.
Also ensure that you are using Max's most recent NE: can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.608
If you mean something else let me know.
Hope this helps
PS I update nod file in my previous post, which should generate quicker, albeit still approx 20 secs.
Message 7777.1011 deleted 14 May 2019 by JFH
7777.1012 In reply to 7777.1011
Thanks a lot James !
It's very interesting.
In fact, my goal is to find how mapping a pattern on an existing model with Nodeeditor.
Show messages:  1-12  …  933-952  953-972  973-992  993-1012  1013-1032  1033-1052  1053-1072  …  1853-1859
