 1-6  …  927-946  947-966  967-986  987-1006  1007-1026  …  1847-1859
7777.967 In reply to 7777.965
Ralf:)
looking for moments of inspiration...
7777.968 In reply to 7777.967
Thanks!
ASAP I will try.
Ciao.
7777.969
Hello Friends
a new exercise, just to keep the mind trained
nothing special, but the result seems
to me quite high-performance-
have a nice evening everyone
alberto
file a this link:http://www.mediafire.com/file/brdhd15a2kv9jx6/PolySolid.rar
7777.970
Hi Friends
an animation test of a
Mechanical Iris, entirely made in Elephant ....
I think because of the numerous Booleans made
the file is heavy, and this undoubtedly affects
on the yield of the Quartz Knot ...
in any case, for those interested
the file at this link:
http://www.mediafire.com/file/a1zwk4ha6f91dbo/Anim.Mechanical_Iris.zip
best
alberto
7777.971 In reply to 7777.970
Ciao Alberto!
...ma come cacchio fai a creare certi "mostri" ?
:) :) :) scherzo...
ma...no mi funziona. Mi da in rosso i nodi "Quartz2" e "Display".
In English :
But...how do you create such "monsters" ?
:) :) :) I'm just kidding.
Anyway...it doesn't work for me. I see these nodes in red "Quartz2" and "Display".
Ciao!
P.S. I've tested with latest Moi V4
Marco (mkmd)
7777.972
Ciao Marco
display e quartz 2 sono nodi di Ralf
Hello Marco
display end quartz 2 it Ralf's extention ,
go to this link for download
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
Have a nice day
alberto
7777.973 In reply to 7777.972
Thanks for the link but...I really have no time to follow that discussion :)
If you can, please post the two nodes as they're form your actual config.
Thanks!
7777.974
Hello Friends
an interesting example, I think, of creating a surface
transition between two existing ones
also quite stable ......
files at this link :
http://www.mediafire.com/file/5nznz8i85jazkm7/Between_Surf.7z
best
alberto
7777.975 In reply to 7777.974
StuffitExpander on Mac says:
Ralf:)
7777.976 In reply to 7777.973
Quartz2 is inside here:
Ralf:)
7777.977 In reply to 7777.976
Wanderful!
...some use case or example ?
Thanks.
7777.978 In reply to 7777.977
I changed Karstens Quartz node to Quartz2 with the min and max as a input to sync it with the numbers of control points for my path animation Node...
Ralf:)
7777.979 In reply to 7777.978
Ralf....I've no words!!
What a wanderful thing you did with the Node Editor!!!
I'm pretty sure that Michael never imagined that one day Moi could have been an animation software !!!
Very funny!
My Moi French Site My Gallery
7777.981 In reply to 7777.242
Now we have a free terrific solver who will avoid some headaches of the Nodes Builders fans!
http://moi3d.com/forum/index.php?webtag=MOI&msg=8858.1 :)
EDITED: 12 Mar 2018 by PILOU
7777.982
Hi Friends
I want to share this exercise
a famous mechanism .... " geneva well "
in the attached images I also show the set-up
to create the animation ...
the file is parameterized, so it is possible to modify
the number of slots in the well ...
For interested poeple the file at this link:
http://www.mediafire.com/file/hur565zl2135vsc/Mechanical_Geneva.zip
best
alberto
7777.983 In reply to 7777.982
Hello Alberto!
As I've said many times here....YOU'RE A MASTER OF NODES!!!
Amazing :)
Here's a quick video : http://take.ms/bV1qz
Ciao!
7777.984
Marco thanks for the nice words..
and for the video you made as a service to all nodeeusers ...
Thanks again
Have a nice evening
alberto
7777.985 In reply to 7777.984
You're welcome Alberto!
If I may, let me give you only one little suggestion, that maybe you already know.
If you want, you could post a simple capture of Moi's screen with some, or at least, one use case of the wanderful nodes you're post here from time to time.
In this way it's easier for any user to get a quick look of what that particular node does.
And also the user is "encouraged" to download the stuff and play with it.
My two cents :)
Thanks for all your wanderful nodes!
Ciao.
7777.986
Hi Friends
I want to share this Macro with you,certainly useful I Hope
M_Pipe
input:
-curves
-radius
- cap round =0
- cap flat = 1
If the input curves overlap the result
it is only one Brep-
file at this Link :
http://www.mediafire.com/file/wqnulsmi5hn2m3b/M_Pipe.nod
have a nice evening to all
alberto
Show messages:  1-6  …  907-926  927-946  947-966  967-986  987-1006  1007-1026  1027-1046  …  1847-1859
