 1-15  …  56-75  76-95  96-115  116-135  136-155  …  1856-1859
7777.96 In reply to 7777.95
Ciao speedy,
Tutti gli italiani sono vicini a tutti voi colpiti dal terremoto e vi sosteniamo!
Non mollate mai! Forza e coraggio !!
Buona giornata,
(in English)
All Italians are close to all of you stricken by the devastating earthquake and we support you!!
Never give up!!
7777.97 In reply to 7777.95
Hello Al,
I've heard about the tragedy and I wish you, your family and friends all the best. I hope, our earth, will find back to their peace.
All the best
Karsten
7777.98
Friends
thank you all for the soothing words
al
What a disater! Nature is unpredictable!
7777.100
Hi Karsten
I've only seen this ......
Wooh...... Great Karsten ,
this is my desired Series
al
Size: 256.9 KB, Downloaded: 166 times, Dimensions: 1920x1080px
7777.101 In reply to 7777.100
Hello Al,
that's only a waste product, as a matter of fact the node was made for a index selection - to select points from a pointarray sequence (have a look in structure2).Nevertheless you can use it also for that.
Have a nice day
Karsten
7777.102
Hi Friends,
my " Work Test" will continue....
Here's a small test of the new nodes ,
Extract-Sel Pattern- Curve Length
Have a nice day to all
al
Size: 322.2 KB, Downloaded: 203 times, Dimensions: 1920x1080px
7777.103 In reply to 7777.102
Hi AL,
...very interesting elaboration !
Thanks!
7777.104 In reply to 7777.95
Hi al, I've been very sad to hear about the terrible earthquakes over there. I hope for good luck and speedy rebuilding for you and your country.
7777.105 In reply to 7777.104
> "I hope for good luck and speedy rebuilding for you and your country."
Unfortunately all the recent disasters of my country, Italy, seems to have taught nothing to all our political class...
But we Italians never give up, despite of our politicians!
Best,
7777.106 In reply to 7777.105
Best wishes for all the Italian people to persevere, Marco!
7777.107 In reply to 7777.106
Heartfelt thanks Michael!
See you,
7777.108
Hi Michael and Friends
I endorse the words of Marco
Many thanks to all of you
al
7777.109
Hi Karsten and Friends
an exercise on use of new nodes
Index, Sel Pattern, Flow .....
I had to give up doing the Fillet and Blend
between the two tape forms,
The result was not stable ...
Flow works best with curved input
rather than surfaces
Good work everyone
best
al
Size: 277.4 KB, Downloaded: 172 times, Dimensions: 1920x1080px
7777.110 In reply to 7777.109
Hi AL,
I'm glad to see that you are doing many experiments with the PatternSelArray node.
I hope to find some free time in next few weeks to rewrite my (lost) boolean utility nodes for PointArray.
Best,
7777.111 In reply to 7777.109
Hello Al,
I'm testing also at the moment - here is an update of the structure:-)
I hope we will find a better solution for Fillet and blend some day!
Have a nice evening
Karsten
7777.112 In reply to 7777.109
Hi Al.
I am alway struck by how vast & sparse your wiring diagrams;
you must have one gigantic monitor (or possibly 2) :)
Anyway I find it very instructive to analyse your method.
So keep them coming...
Thank you....& I am glad to hear that you are OK,
but sorry to hear of the devastation to your town & community.
Karsten,
Thank you also for your new .nod file.
I have not had a chance to look at it yet.
FYI, while reworking Al's .nod file I discovered that your
brilliant Concat2 node has a small bug.
Concatenating objects, does not allow them to be joined.
The ouput dot is green rather than yellow.
I was forced to use Max's original Concat node which is fine,
but I thought you may like to know.
I have attached my version of Al's file below
(it of course, requires Al's .3dm file as well)
-James
EDITED: 14 May 2019 by JFH
7777.113 In reply to 7777.112
<< you must have one gigantic monitor (or possibly 2)
In general today a Latop + a Monitor! ;)
As Node's windows is a "flying windows" you can imagine how comfortable that is! :)
7777.114 In reply to 7777.112
Hello James,
thanks for reporting the bug. Is it right, that the bug comes up, when loading a node-file from disk and try to connect or rewire the output? In a continous session it seems, that all works fine?!
Anyway -I've made some changes and now i'm testing the node. If the result is positive, I will post an update.
Have a nice day
Karsten
p.s.: As mentioned - I didn't understand the functions of the nodeeditor at all.
7777.115 In reply to 7777.114
Hi Karsten,
>>Is it right, that the bug comes up, when loading a node-file from disk and try to connect or rewire the output?<<
I'm not sure. I could not repeat the error. I opened the .nod file and replaced concat with concat2 and it worked fine. Weird?>>Anyway -I've made some changes and now i'm testing the node. If the result is positive, I will post an update.<<
Great! What about offset node you mentioned earlier?
I appreciate all your nodes.
-James
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  1856-1859
