 1-3  …  884-903  904-923  924-943  944-963  964-983  …  1844-1859
7777.924 In reply to 7777.923
Ups! Sorry for that!
p.s.: I have some more - not shared!
EDITED: 21 Dec 2017 by KMRQUS
After first try! just some few are missing! :)
(only extensions Nodes! )
Array Logger are what ?
7777.926
Thank you Santa's
now I will have something to play with on Xmas day.
Many thanks have a nice Xmas.
Barry
7777.927 In reply to 7777.925
Hi Pilou!
"Array Logger" is an old node I have written many months ago.
If I remember well it takes a "PointArray" in input and writes into its UI the value of each array element.
Very useful for debugging purposes.
Marco (mkdm)
7777.928 In reply to 7777.925
.....final notes about "ArrayLogger"...
An example :
And this is the captured output (simply select the ArrayLogger node and select all the text shown into the NE's Info area)
Ciao!
Ok Thx!
So here the French version of all nodes extentions! :)
For Max and all nodes lovers! :D
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_12_17_vf.zip
7777.930 In reply to 7777.920
HoHoHo,
this does the job
40.png" />
Ralf:)
looking for moments of inspiration...
7777.931 In reply to 7777.920
Uuuups Karsten was the faster Santa <:-)>
But for extra nice boys there is a also -180><180 macro...
Ralf:)
7777.932 In reply to 7777.931
Hi Ralf,
Ref: -180><180 macro...
the Data node and output node are macro blocked what does that mean ?
Merry Xmas.
Barry
7777.933 In reply to 7777.932
Its a macro...
Import it as macro..
Right MouseClick -> Macro -> import choose the -180><180.nod
Or just delete the in and outputs and use it as a normal nod..
Ralf:)
7777.934 In reply to 7777.933
Thanks Ralf,
got it now.
Ref: your memory node, have you developed it anymore as I am still trying to get round the feedback issue.
I have pinged Max about it but no response yet so any help would be great.
Merry Xmas and again thanks.
Barry
7777.935 In reply to 7777.934
Hi Barry,
no, i didn't work on the memory node anymore... it goes over the end of my knowledge about the system and javascript..
Somehow it works until you add a second one - than they mix up...
But also for you Happy Xmas and happy nodeling
Ralf:)
7777.936
Someone put something into my stinky socks... <;-)>
"Text2"
EDITED: 21 Dec 2017 by R2D3
7777.937
Hi Ralf
Great Ralf, the new Text node is much appreciated ,
I think it will be very used in the future ...
I think , however, that we will need to have a Node
similar to the Watch node / Ref.Dynamo Autodesk .... ,
that reads the contents of an operation,math or
data referring to points, arrray etc. etc-
The only node that returns a value is currently Curve Length;
even length node , does not read the value .....
I think it's a great help to have this tool-
For you , who are practical scripts , I do not think it's a great work......
give us this gift ...
even if the Xmas now and next, we hope to have it for the "Befana"
ha. ha. ha.....
Happy Xmas and Happy New Year
alberto
7777.938 In reply to 7777.937
Hi alberto,
You didnt look deep enough into the stinky sock... ;-)
There is "Display" in my extensions... its not as shiny like this "watch" thing but it displays numbers...
Happy Solstice
EDITED: 22 Dec 2017 by R2D3
7777.939
You're right Ralf, maybe the smell has prevented me
to do it .....
in any case , with numerical results Displai is Ok ,
but can not read, point or array
we can remedy .....
I hope so
alwais great
alberto
Some one has a very simple example of the Construct2 and Node Fillet ?
My Moi French Site My Gallery
7777.941 In reply to 7777.940
Hello Pilou,
an example file will not help. It's a question of the workflow. At first, it works only for solids and joined surfaces. To use, you have to use it in combination with the BrepNameSubObj node.
Start with a creation of a solid with edges you want to fillet. After that, insert the BrepNameSubObj node. Wire from the solid to the BrepNameSubObj. Node and press run. The node names the edges and faces and displays the geometry. Now select the edges like in the normal moi environment. Then insert the fillet node. It tooks the names of the selected edges and stores it. After that wire the fillet node, that it gets the geometry.
Wire the result to the output and switch of the visible in the BrepNameSubObj node.
Be careful - the fillet node can crash moi, if the factory can't find a result.
Have a nice day
Karsten
7777.942 In reply to 7777.941
Works when i take a Polyhedron (like on your example)
and not when I take a simple Cube! ...(Get_ByName a cube named "kubo" ) I must miss again something! :)
(1 as radius is of course admissible for this cube size)
PS
So from your example seems we can't used a node "Slider" for enter Fillet variation ?
7777.943 In reply to 7777.942
EEhm ...
Get by Name Shows "0". No geometry - no Output - otherwise it should work.
p.s.: The objectname in fillet is given automaticly:-)
p.s.:p.s.: You can use a slider...
EDITED: 9 Jan 2018 by KMRQUS
Show messages:  1-3  …  864-883  884-903  904-923  924-943  944-963  964-983  984-1003  …  1844-1859
