 1-10  …  871-890  891-910  911-930  931-950  951-970  …  1851-1859
7777.911 In reply to 7777.910
Merci Pilou,
just edited the old post...
Ralf:)
looking for moments of inspiration...
7777.912 In reply to 7777.911
Funny is that you can Deform, Copy, Replace with any volumes 3 sets of "named" objects "M", "O", "I"! :)
(if you don't want have some headaches to add more 3 sets of letters! )
Idem for the path itself!
Just make all that before call the node!
EDITED: 20 Dec 2017 by PILOU
7777.913 In reply to 7777.912
Yes thats easy!
If you have only one object following a path - its pretty easy but if you have 3 or more objects following the same path they should have some distance - this gives some headaches..
because they have to jump to different points...and because you can change the number of points on the path with Smoothness its needs some math...
Ralf:)
7777.914 In reply to 7777.913
Users don't want use math! :)
they want just click object(s) then a path! ;)
And eventually move the sliders! :D
7777.915 In reply to 7777.914
Hello Pilou,
are you talking about users or consumers;-)
7777.916 In reply to 7777.915
Alas we can't be all coders even pseudo coders! ;)
Nodes are on the extrem limit of facility!
A node or assembly of nodes ready to be used is perfect for no coders!
https://www.nodebox.net not so evident! :)
7777.917 In reply to 7777.916
7777.918 In reply to 7777.917
>> Don't take everything I write so seriously;-)
Same for me! :)
7777.919
Hi Friends
Some dynamic structures ........
file a this link :
http://www.mediafire.com/file/5ll93as3623zff5/Dynamic_Frames.rar
Have a nice day to all
alberto
7777.920
Hi Santa,
I have tried to create a node that takes an input from a widget knob and and outputs until a condition is met then stops.
ie: Knob 0 to 100; if condition met at say 40 and I turn the knob further the output would remain at 40.
So HELP please I'd like idea's for Xmas.
Barry
7777.921
Hi Barry
I am not able to create a new node, therefore, using " what
passes the Convent " I managed to do this:
http://www.mediafire.com/file/62c4anibe48kek8/Collide_Circle_Move_Versus.rar
Surely not just what you are looking for, but I hope you can
find some ideas to reach your goal
Have a nice evening
alberto
7777.922 In reply to 7777.920
Ho Ho Ho Barry,
I will have a look in my bag!
A nice day to all
Karsten
Before translate nodes of extension! :)
7777.924 In reply to 7777.923
Ups! Sorry for that!
p.s.: I have some more - not shared!
EDITED: 21 Dec 2017 by KMRQUS
After first try! just some few are missing! :)
(only extensions Nodes! )
Array Logger are what ?
7777.926
Thank you Santa's
now I will have something to play with on Xmas day.
Many thanks have a nice Xmas.
Barry
7777.927 In reply to 7777.925
Hi Pilou!
"Array Logger" is an old node I have written many months ago.
If I remember well it takes a "PointArray" in input and writes into its UI the value of each array element.
Very useful for debugging purposes.
Marco (mkdm)
7777.928 In reply to 7777.925
.....final notes about "ArrayLogger"...
An example :
And this is the captured output (simply select the ArrayLogger node and select all the text shown into the NE's Info area)
Ciao!
Ok Thx!
So here the French version of all nodes extentions! :)
For Max and all nodes lovers! :D
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_12_17_vf.zip
7777.930 In reply to 7777.920
HoHoHo,
this does the job
40.png" />
Ralf:)
Show messages:  1-10  …  851-870  871-890  891-910  911-930  931-950  951-970  971-990  …  1851-1859
