 1-7  …  868-887  888-907  908-927  928-947  948-967  …  1848-1859
7777.908 In reply to 7777.905
Hi Barry,
You are absolute right... in the uploaded 3dm file the little MOI is double - deleting the one which is already on the path solves the problem.
Pretty sure i saved the 3dm when nodeeditor wasnt closed... thats something i have to take care of..
Thanks for finding this out!
Ralf:)
looking for moments of inspiration...
7777.909 In reply to 7777.897
Hi Pilou, Barry found the problem - the little MOI which is on the path has to be deleted..
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.908
Ralf:)
7777.910 In reply to 7777.909
@r2d3
Excellent! Now all works like a charm!
(don't forget to edit your original post! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
So the French Version will be there in few minutes! Done!
Bravo!
EDITED: 19 Dec 2017 by PILOU
7777.911 In reply to 7777.910
Merci Pilou,
just edited the old post...
Ralf:)
7777.912 In reply to 7777.911
Funny is that you can Deform, Copy, Replace with any volumes 3 sets of "named" objects "M", "O", "I"! :)
(if you don't want have some headaches to add more 3 sets of letters! )
Idem for the path itself!
Just make all that before call the node!
EDITED: 20 Dec 2017 by PILOU
7777.913 In reply to 7777.912
Yes thats easy!
If you have only one object following a path - its pretty easy but if you have 3 or more objects following the same path they should have some distance - this gives some headaches..
because they have to jump to different points...and because you can change the number of points on the path with Smoothness its needs some math...
Ralf:)
7777.914 In reply to 7777.913
Users don't want use math! :)
they want just click object(s) then a path! ;)
And eventually move the sliders! :D
7777.915 In reply to 7777.914
Hello Pilou,
are you talking about users or consumers;-)
7777.916 In reply to 7777.915
Alas we can't be all coders even pseudo coders! ;)
Nodes are on the extrem limit of facility!
A node or assembly of nodes ready to be used is perfect for no coders!
https://www.nodebox.net not so evident! :)
7777.917 In reply to 7777.916
7777.918 In reply to 7777.917
>> Don't take everything I write so seriously;-)
Same for me! :)
7777.919
Hi Friends
Some dynamic structures ........
file a this link :
http://www.mediafire.com/file/5ll93as3623zff5/Dynamic_Frames.rar
Have a nice day to all
alberto
7777.920
Hi Santa,
I have tried to create a node that takes an input from a widget knob and and outputs until a condition is met then stops.
ie: Knob 0 to 100; if condition met at say 40 and I turn the knob further the output would remain at 40.
So HELP please I'd like idea's for Xmas.
Barry
7777.921
Hi Barry
I am not able to create a new node, therefore, using " what
passes the Convent " I managed to do this:
http://www.mediafire.com/file/62c4anibe48kek8/Collide_Circle_Move_Versus.rar
Surely not just what you are looking for, but I hope you can
find some ideas to reach your goal
Have a nice evening
alberto
7777.922 In reply to 7777.920
Ho Ho Ho Barry,
I will have a look in my bag!
A nice day to all
Karsten
Before translate nodes of extension! :)
7777.924 In reply to 7777.923
Ups! Sorry for that!
p.s.: I have some more - not shared!
EDITED: 21 Dec 2017 by KMRQUS
After first try! just some few are missing! :)
(only extensions Nodes! )
Array Logger are what ?
7777.926
Thank you Santa's
now I will have something to play with on Xmas day.
Many thanks have a nice Xmas.
Barry
7777.927 In reply to 7777.925
Hi Pilou!
"Array Logger" is an old node I have written many months ago.
If I remember well it takes a "PointArray" in input and writes into its UI the value of each array element.
Very useful for debugging purposes.
Marco (mkdm)
Show messages:  1-7  …  848-867  868-887  888-907  908-927  928-947  948-967  968-987  …  1848-1859
