 1-16  …  857-876  877-896  897-916  917-936  937-956  …  1857-1859
Ok with the missing files basics in Libs folder that works better! (very labyrinthic to follow! :)
But now...does this normal ?
What is your parameters Smoothness and Speed ?
EDITED: 19 Dec 2017 by PILOU
7777.898 In reply to 7777.897
<<<<Is beautiful that please without concept!
Are you sure that the small MOI is following the objpath ? and the objpath is not hidden??
Ralf:)
looking for moments of inspiration...
7777.899 In reply to 7777.898
I just load the file 3dm, the nod file and launch! (Windows 10)
Nothing more! :)
7777.900 In reply to 7777.896
Hello Ralf,
separateObj uses the same factory as the MoI function separate. So it smashes joined objects like segmented curves, joined surfaces and solids into the lower level e.g. solids into faces. Is your input atomic, nothing will happens. To intersect something you need at least 2 intersecting geometries at the input for intersect objects. e.g. a curve and a surface -> output point. If you want to have all edges of a brep you can use the extractEdges node. For an overview for most of the factories, have a look to the document hosted by Max, if you don't know it already.
http://moi.maxsm.net/api/
Have a nice day
Karsten
7777.901 In reply to 7777.900
Hello Ralf,
there is also another half automatic way to extract an edge of brep (surfaces,joined surface, solids). BrepNameSubObjects takes the bRep and gives names to the faces and edges and displays the geometry. If you select something of the displayed geometry and you insert then the extract node it will evaluate the names and stores it. On run the node gives then the preselected geometry to the output. Without a pre selection while insert, the node has no names to store (empty names) and the node will give all faces and edges to the output, required you don't have a BrepNameSubObjects node as intput, means direct the brep.
I hope you can follow - here are the limits of my english:-(
Have a nice day
Karsten
p.s. same behavior for the filleting of a solid (preselection is always necessary)- but take care fillet problems are not catched and leads to crash of MoI!!!
EDITED: 19 Dec 2017 by KMRQUS
7777.902
Hi Friends
I want to share this exercise,
the construction of a Polygonal structure
starting from a modular piece , which is positioned
Interlocking...
Good day to all
enjoy ... Christmas is approaching-
File at this link:http://www.mediafire.com/file/leplm3y9iaadq17/PolyFrame.rar
With a little imagination the PolyFrame could be transformed
in a hanging "ball"
best wishes to everyone
alberto
7777.903 In reply to 7777.901
Thanks for going to the limit of your english! ;-)
Yes, i played with the BrepNameSubObjects node - its very interesting and studying how you programed it brings me to the limits of my Javascript...
But there must be a simpler way to just get a edge of a object...
Unfortunatly my objects2 extension doesnt have the ExtractEdges node... i am outdated:-{ and i cant run your select-extract.nod example.
But i think that node can be the solution to me simple problem..
First i have to search for the latest object2.js ...
Ralf:)
7777.904 In reply to 7777.903
Hello Ralf,
start reading here: http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.718
Some posts later James shares a object2.js file, with the node. The changes he made are are described above.
Have a nice day
Karsten
7777.905 In reply to 7777.878
Hi Ralf,
great path animation thanks for posting it.
I had same problem as Pilou but found if I deleted the Moi text that are not on the path it worked great.
Barry
7777.906 In reply to 7777.902
WOW! Thats a BIG nod.. Very well done and i am pretty sure you had a good time developing it..
Happy nodeling!
Ralf:)
7777.907 In reply to 7777.904
YES the extractEdges is doing the job....
Thanks a lot Karsten!
Now i have to find out how marco did this nice connections...
Ralf:)
7777.908 In reply to 7777.905
Hi Barry,
You are absolute right... in the uploaded 3dm file the little MOI is double - deleting the one which is already on the path solves the problem.
Pretty sure i saved the 3dm when nodeeditor wasnt closed... thats something i have to take care of..
Thanks for finding this out!
Ralf:)
7777.909 In reply to 7777.897
Hi Pilou, Barry found the problem - the little MOI which is on the path has to be deleted..
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.908
Ralf:)
7777.910 In reply to 7777.909
@r2d3
Excellent! Now all works like a charm!
(don't forget to edit your original post! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
So the French Version will be there in few minutes! Done!
Bravo!
7777.911 In reply to 7777.910
Merci Pilou,
just edited the old post...
Ralf:)
7777.912 In reply to 7777.911
Funny is that you can Deform, Copy, Replace with any volumes 3 sets of "named" objects "M", "O", "I"! :)
(if you don't want have some headaches to add more 3 sets of letters! )
Idem for the path itself!
Just make all that before call the node!
EDITED: 20 Dec 2017 by PILOU
7777.913 In reply to 7777.912
Yes thats easy!
If you have only one object following a path - its pretty easy but if you have 3 or more objects following the same path they should have some distance - this gives some headaches..
because they have to jump to different points...and because you can change the number of points on the path with Smoothness its needs some math...
Ralf:)
7777.914 In reply to 7777.913
Users don't want use math! :)
they want just click object(s) then a path! ;)
And eventually move the sliders! :D
7777.915 In reply to 7777.914
Hello Pilou,
are you talking about users or consumers;-)
7777.916 In reply to 7777.915
Alas we can't be all coders even pseudo coders! ;)
Nodes are on the extrem limit of facility!
A node or assembly of nodes ready to be used is perfect for no coders!
https://www.nodebox.net not so evident! :)
Show messages:  1-16  …  837-856  857-876  877-896  897-916  917-936  937-956  957-976  …  1857-1859
