 1-15  …  836-855  856-875  876-895  896-915  916-935  …  1856-1859
7777.876 In reply to 7777.875
Hello Max,
that's a good idea to write extensions ;-) I don't have access to octane, but I always enjoy to read your code.
So have a nice evening and many thanks
Karsten
@Max
Never use that but for the glory! :)
last French lang.js for Node Classic & deviant! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
and last French nodeeditor :)
last http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 16 Dec 2017 by PILOU
7777.878
Path animation
actually very easy with the existing nodes... but (sorry Karsten ich habs schon wieder gemacht... ;-) the quarz nod needed just a little tweak.. to sync the quarz with the path_array Div i added Min and Max as an input.
Max's new SWITCH got also i nice place in the CameraMacro (which now also follows pathes)
EDITED: 20 Dec 2017 by R2D3
7777.879 In reply to 7777.878
Hello Ralf,
Thumbs up!
Looks like you having fun! Every change is allowed here! Hauptsache wir haben Spass!
Have a nice evening
Karsten
7777.880
can anybody tell me how to run the latest nodeeditor in moi V4 portable. i have tried the usual method and the latest as below.
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Barry
7777.881 In reply to 7777.880
Hello Barry,
I've placed it in the standard UI folder with >>> moi.ui.createDialog( 'nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); <<<<<
Should work also for you.
Have a nice day
Karsten
7777.882 In reply to 7777.881
Hi Karsten,
did that to start with I am only getting a white window.Installing previous version of node editor same result.
There was some discussion between Max and Michael about the portable version not sure if it's been resolved.
Barry
7777.883 In reply to 7777.879
Genau!
Lets have some funny nodeling !
Ralf:)
looking for moments of inspiration...
7777.884 In reply to 7777.882
Hello Barry,
please check your path in detail - if there is no fault, try a complete/absolute path e.g. moi.ui.createDialog( 'X:\MoI_V4 beta\ui\nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Hope it helps
Karsten
7777.885 In reply to 7777.884
Hi Karsten,
still no luck perhaps this discussion http://moi3d.com/forum/index.php?webtag=MOI&msg=8704.48
as something to do with it.
I have looked at the index.html and it references the appdata path, if that means anything.
Barry
7777.886 In reply to 7777.884
Hi Karsten,
this is the error from a direct path.
SyntaxError: \u can only be followed by a Unicode character sequence
line 1
1: >> moi.ui. createDialog ('D:\MoI V4 beta\ui\ nodeeditor.v.0.99.2017.12.18/index. html', 'resizeable,defaultWidth:680 , defaultHight:420',moi.ui.mainWindow );
Barry
7777.887 In reply to 7777.886
Hi Barry,
In a JavaScript string the backslash \ character is used as an "escape" so you can make characters like \t meaning tab, or \uXXXX for a unicode character. If you want to make an actual backslash you need to put in \\ .
But it also looks like you may have some extra spaces in various places causing problems, especially "index. html".
I'd recommend trying 'nodeeditor.v.0.99.2017.12.18/index.html' - that should look for it in your MoI ui folder. Note there should not be any space in the middle of index.html
7777.888 In reply to 7777.886
Hello Barry,
fits the path exactly to your configuration? Please open the file path to the index.html and post a screenshot of the explorer or dolphin or other file manager, depending of your OS. then we can have a look.
Until soon
Karsten
7777.889 In reply to 7777.888
Hi Karsten,
here it is.
Barry
7777.890
Hi Michael/Karsten,
sorted my typing leaving spaces seems to have been the problem.
Many thanks
Barry
7777.891 In reply to 7777.889
Hello Barry,
sorry I have placed backslashs as slashs in my path example. But is it possible that there is a space in the relative path as Michael mentioned. I don't know how spaces are handled in js for a absolute path - in windows are used "x x " as I remember. So I don't have a solution:-(
Sorry
7777.892 In reply to 7777.878
@r2d3
Does your file r2d3.js is the previous one increased with new functions or it's a totally new one at each time ?
Else!
(not yet translate all your new buttons! ;)
EDITED: 18 Dec 2017 by PILOU
7777.893 In reply to 7777.878
Hello Ralf!
...WOW !!!
Supercool!!!!
Congratulations :)
7777.894 In reply to 7777.892
Hello Pilou,
the error comes typically up, when basicFunctions.js is missing in the nodes/extensions/libs folder. It contains some basic vector math functions. Pick it up from a previous installation and copy it to the folder.
Have a nice day
Karsten
EDITED: 19 Dec 2017 by KMRQUS
7777.895 In reply to 7777.892
<<<<Does your file r2d3.js is the previous one increased with new functions or it's a totally new one at each time ?
Hi Pilou, yes my r2d3.js is a work in progress... this time the quartz2 (with the new inputs) is in it.. so just override the existing one with the new one.
Ralf:)
Show messages:  1-15  …  816-835  836-855  856-875  876-895  896-915  916-935  936-955  …  1856-1859
