 1-9  …  830-849  850-869  870-889  890-909  910-929  …  1850-1859
7777.870 In reply to 7777.869
LOL :)
7777.871 In reply to 7777.869
The other way around its even harder 8-|
Ralf:)
looking for moments of inspiration...
7777.872 In reply to 7777.871
Sherif: From here until the other side, no water but what we carry. For the camels, no water at all. If the camels die, we die. And in twenty days they will start to die.
Lawrence: There's no time to waste then, is there?
Lawrence: Nothing is written;-)
7777.873 In reply to 7777.865
Hi Ralf
Thanks for Camera2 node. Great stuff
I can't wait to see what other things you do.
>> instead of SuDoKu i play with nodes <<
I have some suggestions that may pique your interest for nodes to play with:
1) ExtrudeDir
Ideally this would be a RMB option to Extrude node, but for now can be stand-alone.
The ability to set set start & end points (thereby denoting direction) will solve problem of multiprocess extrudes of multiple curves flowed over a surface, each with unique normal.
2) IsoCurve2
Karsten's IsoCurve node is supremely useful, but it could be improved by the option of including the perimeter curves as well.
3) Fat Lines
This one is pretty self-explanatory; it is simply Max's "Fat Lines" script wrapped in a node.
These are by no means the most needed nodes missing from the toolkit, far from it... just some thoughts
Keep up the great work
EDITED: 15 Dec 2017 by JFH
7777.874 In reply to 7777.873
Thank you James,
yes, this are interesting ideas - thank you!
Perhaps i will dive into... :-)
BTW: the camera2 node doesnt need any in- or output so its ideal for a macro:
Just load the macro in one of your projects and you have also the cam control..
Ralf:)
7777.875
Today I wrote my first NE extension node. :) It converts points array to rotation matrices which can be used as an Octane render scatter node data.
EDITED: 7 Mar 2022 by SMIRNOV
7777.876 In reply to 7777.875
Hello Max,
that's a good idea to write extensions ;-) I don't have access to octane, but I always enjoy to read your code.
So have a nice evening and many thanks
Karsten
@Max
Never use that but for the glory! :)
last French lang.js for Node Classic & deviant! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
and last French nodeeditor :)
last http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 16 Dec 2017 by PILOU
7777.878
Path animation
actually very easy with the existing nodes... but (sorry Karsten ich habs schon wieder gemacht... ;-) the quarz nod needed just a little tweak.. to sync the quarz with the path_array Div i added Min and Max as an input.
Max's new SWITCH got also i nice place in the CameraMacro (which now also follows pathes)
EDITED: 20 Dec 2017 by R2D3
7777.879 In reply to 7777.878
Hello Ralf,
Thumbs up!
Looks like you having fun! Every change is allowed here! Hauptsache wir haben Spass!
Have a nice evening
Karsten
7777.880
can anybody tell me how to run the latest nodeeditor in moi V4 portable. i have tried the usual method and the latest as below.
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Barry
7777.881 In reply to 7777.880
Hello Barry,
I've placed it in the standard UI folder with >>> moi.ui.createDialog( 'nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); <<<<<
Should work also for you.
Have a nice day
Karsten
7777.882 In reply to 7777.881
Hi Karsten,
did that to start with I am only getting a white window.Installing previous version of node editor same result.
There was some discussion between Max and Michael about the portable version not sure if it's been resolved.
Barry
7777.883 In reply to 7777.879
Genau!
Lets have some funny nodeling !
Ralf:)
7777.884 In reply to 7777.882
Hello Barry,
please check your path in detail - if there is no fault, try a complete/absolute path e.g. moi.ui.createDialog( 'X:\MoI_V4 beta\ui\nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Hope it helps
Karsten
7777.885 In reply to 7777.884
Hi Karsten,
still no luck perhaps this discussion http://moi3d.com/forum/index.php?webtag=MOI&msg=8704.48
as something to do with it.
I have looked at the index.html and it references the appdata path, if that means anything.
Barry
7777.886 In reply to 7777.884
Hi Karsten,
this is the error from a direct path.
SyntaxError: \u can only be followed by a Unicode character sequence
line 1
1: >> moi.ui. createDialog ('D:\MoI V4 beta\ui\ nodeeditor.v.0.99.2017.12.18/index. html', 'resizeable,defaultWidth:680 , defaultHight:420',moi.ui.mainWindow );
Barry
7777.887 In reply to 7777.886
Hi Barry,
In a JavaScript string the backslash \ character is used as an "escape" so you can make characters like \t meaning tab, or \uXXXX for a unicode character. If you want to make an actual backslash you need to put in \\ .
But it also looks like you may have some extra spaces in various places causing problems, especially "index. html".
I'd recommend trying 'nodeeditor.v.0.99.2017.12.18/index.html' - that should look for it in your MoI ui folder. Note there should not be any space in the middle of index.html
7777.888 In reply to 7777.886
Hello Barry,
fits the path exactly to your configuration? Please open the file path to the index.html and post a screenshot of the explorer or dolphin or other file manager, depending of your OS. then we can have a look.
Until soon
Karsten
7777.889 In reply to 7777.888
Hi Karsten,
here it is.
Barry
Show messages:  1-9  …  810-829  830-849  850-869  870-889  890-909  910-929  930-949  …  1850-1859
