 1-12  …  813-832  833-852  853-872  873-892  893-912  …  1853-1859
7777.853
Hi all,
is it possible to create a nod from existing node's that stores a count and would not be cleared till it is reset or create a new node that does that.
Barry
7777.854 In reply to 7777.853
Storing a value seems to be a problem...
I didnt find a way to do it with existing nodes and i created a extension with a memory node.
if you set it to 0 it gives the IN values to the OUT if you set it to 1 it stores the last value and gives this to out...
BUT: if you add a second one it doesnt work anymore...
Somehow both react like one.
Perhaps Karsten finds a solution...
Ralf:)
looking for moments of inspiration...
7777.855
2 fully interwoven screens.
EDITED: 14 May 2019 by JFH
7777.856 In reply to 7777.855
Wanderful!
All these stuff are very useful for renderings of 3D concepts and/or geometric art to include into 2D works (after some post process elaboration)
Thanks a lot.
Message 7777.857 deleted 14 May 2019 by JFH
Intricated!
7777.859 In reply to 7777.857
Thanks James.
Wanderful as usual!!
Math made art :)
7777.860 In reply to 7777.857
Hello James,
great result. Thanks for sharing!
A nice day to all
Karsten
7777.861
New Camera nod..
Now setCameraAndTarget is working again in V4 i desided to play with the camera nod ... the original is not working like expected and i changed it a little.
Now its camera2 and it can circle around objects, render picts and even make a video out of them...
For Mac:
to enable video you need ffmpeg in /usr/local/bin/ffmpeg put this path in the encoder field
in the FilePath field write something like /users/ralfnaumann/Documents/CAD/camera/
You will find the camera2 nod in attached r2d3.js -> put this to the extension folder (there are also some other nods inside - but not all are working perfect...)
As example to use the camera2 you can open camera1.nod
Ralf:)
7777.862 In reply to 7777.861
Amazing node Ralf!!
Thanks a lot!!!
7777.863 In reply to 7777.861
Hello Ralf,
thanks for playing and improving the node. I think you were the first that was really interested in. I have never finished the node really - zu wenig Zeit, zu viele Aspekte!
Bis dann
Karsten
Question about genious creators of nodes!
Have you a place on the Net where we can find your true gems ?
(French version of camera is pretty soon ready :)
Done! :)
where I must put the .js file (in extensions ? )
because now the only thing I have is the centering and blockage of the object in the 3 D view... :D
using cursors don't get nothing special!
What I miss ?
a pedagogic gif is need! :)
Tested in the V4 11 november...
EDITED: 14 Dec 2017 by PILOU
7777.865 In reply to 7777.864
There is just one more gem... www.esherpa.ch ... makes my life as a tandem pilot much more easier... with the help of MoI!
Winter time is not very busy for me and instead of SuDoKu i play with nodes...
Merci pour la traduction
Ralf:)
7777.866 In reply to 7777.865
You're right Ralf!
@You : "...instead of SuDoKu i play with nodes..."
Moi is really the "funniest 3D Cad" ever !!! A sort of video game into the CAD world ;)
And, above all, although it is so funny it's also awfully powerful for serious things!!
7777.867 In reply to 7777.864
<<<where I must put the .js file (in extensions ? )
Yes, into the extensions.
than open the camera1.nod adjust the camera x/y/z and the target x/y/z
Hit run and the camera circles around the target (if speed>0 and its not on Stop)
EDIT: IMPORTANT: You have to use the last V4 the earlier Nov version has a bug in "setCameraAnd Target"
EDITED: 14 Dec 2017 by R2D3
7777.868 In reply to 7777.867
<< EDIT: IMPORTANT: You have to use the last V4 the earlier Nov version has a bug in "setCameraAnd Target"
So very unlucky!
I used it for avoid to copy move the Nodeeditor! :D
Let's go to see if this is better with last version! :)
Edit all is perfect ! Total success! I can now add this one to my French site! :)
Message 7777.869 deleted 16 Dec 2017 by BEMFARMER
7777.870 In reply to 7777.869
LOL :)
7777.871 In reply to 7777.869
The other way around its even harder 8-|
Ralf:)
7777.872 In reply to 7777.871
Sherif: From here until the other side, no water but what we carry. For the camels, no water at all. If the camels die, we die. And in twenty days they will start to die.
Lawrence: There's no time to waste then, is there?
Lawrence: Nothing is written;-)
Show messages:  1-12  …  793-812  813-832  833-852  853-872  873-892  893-912  913-932  …  1853-1859
