 1-6  …  807-826  827-846  847-866  867-886  887-906  …  1847-1859
EDITED: 9 Dec 2017 by PILOU
7777.848 In reply to 7777.840
Hello Brian,
<<<Yes, hoopsnake. I wonder if nodeeditor has "feedback" detection code?>>>
I think that's a general problem - no special code is needed. The nodeeditor needs startpoints/nodes to start the calculation from an independent node. In a closed loop we need a intial startpoint and initial value(chicken-egg-problem). At a minimum we need an independent node that defines the step in to the loop and gives the initial value. I think it's possible to solve.
Have a nice day
Karsten
7777.849 In reply to 7777.846
Hello Ralf,
thanks for sharing. I have to study your nodes now.
Have a nice day
Karsten
7777.850
Hi All,
while searching for Hoopsnake came across these video's
https://www.youtube.com/watch?v=QefqhzIz_ak
https://www.youtube.com/watch?v=SSWudanJc7c
Barry
7777.852
Hi Barry,and Friends
in Grasshopper besides " Hoopsnake ", there is also
another Plug called "Anemone ", which also works maybe better,
and there is also the possibility of using " Kangaroo " a physics engine to move
rigid bodies, in various ways ,
but all these tools use a Button , True / False, and a connection Timer, to activate
or deactivate the action .......
and , the input data can all be adjusted by a Slider or direct links to the data in the Canvas-
I have not knowledge of Java Script, but I think it is not very easy
create a Collide / Repulsive tool
in any case, your attempts are very appreciable
do not give up......
alberto
7777.853
Hi all,
is it possible to create a nod from existing node's that stores a count and would not be cleared till it is reset or create a new node that does that.
Barry
7777.854 In reply to 7777.853
Storing a value seems to be a problem...
I didnt find a way to do it with existing nodes and i created a extension with a memory node.
if you set it to 0 it gives the IN values to the OUT if you set it to 1 it stores the last value and gives this to out...
BUT: if you add a second one it doesnt work anymore...
Somehow both react like one.
Perhaps Karsten finds a solution...
Ralf:)
looking for moments of inspiration...
7777.855
2 fully interwoven screens.
EDITED: 14 May 2019 by JFH
7777.856 In reply to 7777.855
Wanderful!
All these stuff are very useful for renderings of 3D concepts and/or geometric art to include into 2D works (after some post process elaboration)
Thanks a lot.
Message 7777.857 deleted 14 May 2019 by JFH
Intricated!
7777.859 In reply to 7777.857
Thanks James.
Wanderful as usual!!
Math made art :)
7777.860 In reply to 7777.857
Hello James,
great result. Thanks for sharing!
A nice day to all
Karsten
7777.861
New Camera nod..
Now setCameraAndTarget is working again in V4 i desided to play with the camera nod ... the original is not working like expected and i changed it a little.
Now its camera2 and it can circle around objects, render picts and even make a video out of them...
For Mac:
to enable video you need ffmpeg in /usr/local/bin/ffmpeg put this path in the encoder field
in the FilePath field write something like /users/ralfnaumann/Documents/CAD/camera/
You will find the camera2 nod in attached r2d3.js -> put this to the extension folder (there are also some other nods inside - but not all are working perfect...)
As example to use the camera2 you can open camera1.nod
Ralf:)
7777.862 In reply to 7777.861
Amazing node Ralf!!
Thanks a lot!!!
7777.863 In reply to 7777.861
Hello Ralf,
thanks for playing and improving the node. I think you were the first that was really interested in. I have never finished the node really - zu wenig Zeit, zu viele Aspekte!
Bis dann
Karsten
Question about genious creators of nodes!
Have you a place on the Net where we can find your true gems ?
(French version of camera is pretty soon ready :)
Done! :)
where I must put the .js file (in extensions ? )
because now the only thing I have is the centering and blockage of the object in the 3 D view... :D
using cursors don't get nothing special!
What I miss ?
a pedagogic gif is need! :)
Tested in the V4 11 november...
EDITED: 14 Dec 2017 by PILOU
7777.865 In reply to 7777.864
There is just one more gem... www.esherpa.ch ... makes my life as a tandem pilot much more easier... with the help of MoI!
Winter time is not very busy for me and instead of SuDoKu i play with nodes...
Merci pour la traduction
Ralf:)
7777.866 In reply to 7777.865
You're right Ralf!
@You : "...instead of SuDoKu i play with nodes..."
Moi is really the "funniest 3D Cad" ever !!! A sort of video game into the CAD world ;)
And, above all, although it is so funny it's also awfully powerful for serious things!!
Show messages:  1-6  …  787-806  807-826  827-846  847-866  867-886  887-906  907-926  …  1847-1859
