 1-16  …  797-816  817-836  837-856  857-876  877-896  …  1857-1859
7777.837 In reply to 7777.832
Hello Vladimir,
that's good News. I haven't the time to test your new nodes, but I'm glad to hear about new contributions!
Thank you very much for sharing!
Have a nice day
Karsten
7777.838
Hi Vlad, i tested your's new node
it's work perfectly
Many thanks ,Bravo...
alberto
7777.839 In reply to 7777.831
I did a Google search and found grasshopper as a plugin called Hoopsnake that allows feedback.
This is the link http://www.grasshopper3d.com/group/hoopsnake.
Perhaps Max or Karsten will have a look and see if it's possible to create something similar.
Barry
7777.840 In reply to 7777.839
Hi Barry,
Yes, hoopsnake. I wonder if nodeeditor has "feedback" detection code?
There is also a Grasshopper way to feedback to (say multiple) sliders, to increase sliders, potentially up to their maximum,
written by the author of grasshopper.
I'll post the link tonight.
Maybe sliders could have range multipliers controlled by the bounding box(s)...(?)
7777.841 In reply to 7777.839
Hello Barry,
yep! Thats exectly what I thought. Possible to make global container to place results and read them in a next iteration back. Ralf - thanks for the contribution - has used something similar in the stream node - only problem - more than one of this node.
I need to have a deeper look - next days.
A nice weekend to all
Karsten
EDITED: 8 Dec 2017 by PILOU
By David Rutten (the Max Smirnov of Grasshopper ! ;)
Permutations above
7777.846 In reply to 7777.841
<<<< Ralf - thanks for the contribution - has used something similar in the stream node - only problem - more than one of this node.
Yes - thats right i also did a memory extension which works good .... until you add a second one..
For me there is the end of my understanding of js and the system.....
But there is still Karsten :-)
Ralf:)
looking for moments of inspiration...
EDITED: 9 Dec 2017 by PILOU
7777.848 In reply to 7777.840
Hello Brian,
<<<Yes, hoopsnake. I wonder if nodeeditor has "feedback" detection code?>>>
I think that's a general problem - no special code is needed. The nodeeditor needs startpoints/nodes to start the calculation from an independent node. In a closed loop we need a intial startpoint and initial value(chicken-egg-problem). At a minimum we need an independent node that defines the step in to the loop and gives the initial value. I think it's possible to solve.
Have a nice day
Karsten
7777.849 In reply to 7777.846
Hello Ralf,
thanks for sharing. I have to study your nodes now.
Have a nice day
Karsten
7777.850
Hi All,
while searching for Hoopsnake came across these video's
https://www.youtube.com/watch?v=QefqhzIz_ak
https://www.youtube.com/watch?v=SSWudanJc7c
Barry
7777.852
Hi Barry,and Friends
in Grasshopper besides " Hoopsnake ", there is also
another Plug called "Anemone ", which also works maybe better,
and there is also the possibility of using " Kangaroo " a physics engine to move
rigid bodies, in various ways ,
but all these tools use a Button , True / False, and a connection Timer, to activate
or deactivate the action .......
and , the input data can all be adjusted by a Slider or direct links to the data in the Canvas-
I have not knowledge of Java Script, but I think it is not very easy
create a Collide / Repulsive tool
in any case, your attempts are very appreciable
do not give up......
alberto
7777.853
Hi all,
is it possible to create a nod from existing node's that stores a count and would not be cleared till it is reset or create a new node that does that.
Barry
7777.854 In reply to 7777.853
Storing a value seems to be a problem...
I didnt find a way to do it with existing nodes and i created a extension with a memory node.
if you set it to 0 it gives the IN values to the OUT if you set it to 1 it stores the last value and gives this to out...
BUT: if you add a second one it doesnt work anymore...
Somehow both react like one.
Perhaps Karsten finds a solution...
Ralf:)
7777.855
2 fully interwoven screens.
EDITED: 14 May 2019 by JFH
7777.856 In reply to 7777.855
Wanderful!
All these stuff are very useful for renderings of 3D concepts and/or geometric art to include into 2D works (after some post process elaboration)
Thanks a lot.
Show messages:  1-16  …  777-796  797-816  817-836  837-856  857-876  877-896  897-916  …  1857-1859
