 1-3  …  784-803  804-823  824-843  844-863  864-883  …  1844-1859
7777.824 In reply to 7777.823
Hi Ralf,
are you referring to the Collision.js file ?
It as this at the moment Collision.prototype.onExecute = function()
Barry
7777.825 In reply to 7777.824
Hi Barry,
i only have the Barry.js which still has the boolean output
Where can i fin the collision.js?
But while developing other extensions i got the same error and i was able to correct this by adding defaults in the onSdded function...
Can you post the collision.js and the nod you playing with?
Ralf:)
looking for moments of inspiration...
7777.826 In reply to 7777.824
Hello Barry,
the Problem is not in your node - it's the Feedback effect of the nodefile itself. The Output of collision becomes, by detours to the Input.
I think that is catched by the nodeeditor to avoid infinity running. A Problem that has to be solved for optimisations or by a node itself.
I think about it, nevertheless we have to ping Max for his opinion.
Have a nice day
Karsten
p.s.: I don't think that you Need a new node - and try to avoid boolean in nodeeditor progamming - Max has made a decission to use numarray for that Look at his logic nodes. At the end it's the same. Only difference you can directly calculate with a result of a logical comperation.
7777.827 In reply to 7777.826
Hi Karsten,
attached are my Barry/Collision node and the Collision.nod file.
It's a work in progress.
Am I using a Boolean in the node ?
Thanks for the clash.nod will try to see if I can use it instead but
not sure how I automate the movement yet.
Barry
EDITED: 30 Jan 2021 by BARRY-H
7777.828 In reply to 7777.826
Hi Karsten,
looks like you are right in every point...
Ralf:)
7777.829 In reply to 7777.828
Cool nothing to translate for this one... a miracle! ...
... but how do use it? :D
(Collision tittle is in red (?) )
Must I use also the Barry.js and where i must put it ? Normal folder or extensions ? or...
EDITED: 7 Dec 2017 by PILOU
7777.830 In reply to 7777.829
it's a work in progress at the moment so the final aim is to auto place objects touching or with a given gap.
If you place Barry.js in extensions you will be able to try the Collision.nod.
Draw 2 objects make them overlap and press run ( close error report ) and they will automatically move till they do not overlap.
To reset the quartz node value as to be manually reset to 0.
Barry
Hi Barry,
I cannot say if "feedback" is a problem, but note that many months ago, near the beginning of NodeEditor,
I read a post in Grasshopper, of a way to do "feedback," wiring,
which as far as I know, is not normally possible...
Back then, I think I posted a brief sentence about it...
ps: General information: The barry.js file goes in the extensions folder of nodeeditor.
EDITED: 7 Dec 2017 by BEMFARMER
7777.832
Hi all.
My little contribution in the NodeEditor.
Added: Arc3pt, ArcCenter, Circle3pt, CircleDiameter, Ellipse3pt, EllipseCenter.
Allowed: node - test, and me to criticize :)
Vladimir.
7777.833 In reply to 7777.832
Hi Vladimir
Your node contributions are great & long overdue.
It is hard to see how they could be improved upon,
except maybe compiling them into meta-nodes with RMB sub-options.
Also it would be a real improvement if arcCenter node emulated the tool's function
of having "start point" & "angle" options"
Nevertheless, as they are, they will be extremely useful,
so thank you
PS one thing you should probably consider is putting them under
their own menu heading "Curves2" below the line.
It has been agreed practice that Max's nodes are sacrosanct,
& extension node are kept separate.
EDITED: 11 Dec 2017 by JFH
7777.834 In reply to 7777.831
About collision :nothing arrives! (collision node is not yet red ! :)
Must i "name" each object ? These can be volumes ?
When you say put Barry.js inside nodes\extensions it's inside or outside
...\ui\nodeeditor\nodes\extensions\libs ?
7777.835 In reply to 7777.834
Under extensions, same place construct2.js is located.
- B
By the way, while playing with the stock Construct/intersect node, with a circle and a rectangle, the stock intersect node does not yield the same
results as the MoI intersect script.
7777.836 In reply to 7777.835
Hum hum done but nothing arrives!
I have 2 closed curves each named with a different name. Overlaped on the same plane.
What collision? Take your or the Ralph Collision ?
And after : select the 2 forms then "Run" ? or ...
Ps How reset a Node(s ? Stop then Run ? or...
How erase a node ? Select it then remove, then reload or...
7777.837 In reply to 7777.832
Hello Vladimir,
that's good News. I haven't the time to test your new nodes, but I'm glad to hear about new contributions!
Thank you very much for sharing!
Have a nice day
Karsten
7777.838
Hi Vlad, i tested your's new node
it's work perfectly
Many thanks ,Bravo...
alberto
7777.839 In reply to 7777.831
I did a Google search and found grasshopper as a plugin called Hoopsnake that allows feedback.
This is the link http://www.grasshopper3d.com/group/hoopsnake.
Perhaps Max or Karsten will have a look and see if it's possible to create something similar.
Barry
7777.840 In reply to 7777.839
Hi Barry,
Yes, hoopsnake. I wonder if nodeeditor has "feedback" detection code?
There is also a Grasshopper way to feedback to (say multiple) sliders, to increase sliders, potentially up to their maximum,
written by the author of grasshopper.
I'll post the link tonight.
Maybe sliders could have range multipliers controlled by the bounding box(s)...(?)
7777.841 In reply to 7777.839
Hello Barry,
yep! Thats exectly what I thought. Possible to make global container to place results and read them in a next iteration back. Ralf - thanks for the contribution - has used something similar in the stream node - only problem - more than one of this node.
I need to have a deeper look - next days.
A nice weekend to all
Karsten
EDITED: 8 Dec 2017 by PILOU
By David Rutten (the Max Smirnov of Grasshopper ! ;)
Show messages:  1-3  …  764-783  784-803  804-823  824-843  844-863  864-883  884-903  …  1844-1859
