 1-11  …  772-791  792-811  812-831  832-851  852-871  …  1852-1859
Here the French last! :)
EDITED: 6 Dec 2017 by PILOU
7777.813 In reply to 7777.811
>> How do you attach something to a Macro node ? <<
A macro node is just an empty container until node circuitry is put inside.
To do something it needs input/s & output/s that may be connected.
Try double clicking on an existing macro to discover what is inside,
or alternatively create a new macro, double click on it, and add some node/s
include input and output from menu drop down, and then click BACK on the nav bar.
It will all become clear,
7777.814 In reply to 7777.813
Aaaaaaaaaaaah damned! :)
Things hidden from the beginning world! :D
So more nodes to translate! :D
I will obtain an Universalis Encyclopedia! :)
And yes all is quasi clear now! :)
PS Can we put a macro inside a macro ?
And does exist something to alert when you create a node with a name yet existing ?
EDITED: 5 Dec 2017 by PILOU
7777.815 In reply to 7777.814
A macro can contain a macro.
- B
So Fractal world! :)
Missing a paradigm! :)
Circle is drawn inside the macro, not outside the macro!
What i missed ?
7777.817 In reply to 7777.816
Hi Pilou
>> What i missed ? <<
Right Mouse Button click on "Out" in macro
select "Objects" (the default is "Numbers", no appropriate for a curve)
Also remove regular "Output" inside macro, as this will create problems.
Hope this helps
7777.818 In reply to 7777.817
Bravo! Excellent!
Now the more difficult will be to not use this marvelous toy before the next year! :D
So the secret was to take "object" on the "output" in the Macro!
7777.819 In reply to 7777.818
WOW!
yes, the secrets of the macros are finally discovered!
And you can save macros for reuse.
In the animator11.nod there are a couple of macros inside a macro inside a macro....
for example i made a if/else macro (f.e.: ><180) which i used for different cases...
Once you figured out a funtion -> save it as macro and reuse it for a different case...
Bon Noël <:-)
Ralf:)
looking for moments of inspiration...
French Translation of the animator11.nod + Mini Manual of a Macro!
then Macro / animator11
7777.821
Hello to all
a little exercise that starts
from a very interesting surface
the Oloid -
Some deformations , a wire that starts from
surface structure.... et voilà .....
How many interested people find the file at this link:
http://www.mediafire.com/file/qhvj5752j9y7x3f/Oloid_Bracelet.rar
have a nice evening everybody
alberto
7777.822
Hi All,
I have had this error report when pressing run on my test collision nod.
but after I clear the error report the nod file runs ok.
Not sure if it's a bug or my nod file setup ?
The nod takes 2 objects and checks for a collision and if so moves the second object till clear.
Any thoughts ?
Barry
7777.823 In reply to 7777.822
For me it looks like there is a value not set in the beginning..
Try to set defaults in the "prototype.onAdded = function()"
Ralf:)
7777.824 In reply to 7777.823
Hi Ralf,
are you referring to the Collision.js file ?
It as this at the moment Collision.prototype.onExecute = function()
Barry
7777.825 In reply to 7777.824
Hi Barry,
i only have the Barry.js which still has the boolean output
Where can i fin the collision.js?
But while developing other extensions i got the same error and i was able to correct this by adding defaults in the onSdded function...
Can you post the collision.js and the nod you playing with?
Ralf:)
7777.826 In reply to 7777.824
Hello Barry,
the Problem is not in your node - it's the Feedback effect of the nodefile itself. The Output of collision becomes, by detours to the Input.
I think that is catched by the nodeeditor to avoid infinity running. A Problem that has to be solved for optimisations or by a node itself.
I think about it, nevertheless we have to ping Max for his opinion.
Have a nice day
Karsten
p.s.: I don't think that you Need a new node - and try to avoid boolean in nodeeditor progamming - Max has made a decission to use numarray for that Look at his logic nodes. At the end it's the same. Only difference you can directly calculate with a result of a logical comperation.
7777.827 In reply to 7777.826
Hi Karsten,
attached are my Barry/Collision node and the Collision.nod file.
It's a work in progress.
Am I using a Boolean in the node ?
Thanks for the clash.nod will try to see if I can use it instead but
not sure how I automate the movement yet.
Barry
EDITED: 30 Jan 2021 by BARRY-H
7777.828 In reply to 7777.826
Hi Karsten,
looks like you are right in every point...
Ralf:)
7777.829 In reply to 7777.828
Cool nothing to translate for this one... a miracle! ...
... but how do use it? :D
(Collision tittle is in red (?) )
Must I use also the Barry.js and where i must put it ? Normal folder or extensions ? or...
EDITED: 7 Dec 2017 by PILOU
7777.830 In reply to 7777.829
it's a work in progress at the moment so the final aim is to auto place objects touching or with a given gap.
If you place Barry.js in extensions you will be able to try the Collision.nod.
Draw 2 objects make them overlap and press run ( close error report ) and they will automatically move till they do not overlap.
To reset the quartz node value as to be manually reset to 0.
Barry
Hi Barry,
I cannot say if "feedback" is a problem, but note that many months ago, near the beginning of NodeEditor,
I read a post in Grasshopper, of a way to do "feedback," wiring,
which as far as I know, is not normally possible...
Back then, I think I posted a brief sentence about it...
ps: General information: The barry.js file goes in the extensions folder of nodeeditor.
EDITED: 7 Dec 2017 by BEMFARMER
Show messages:  1-11  …  752-771  772-791  792-811  812-831  832-851  852-871  872-891  …  1852-1859
