 1-3  …  764-783  784-803  804-823  824-843  844-863  …  1844-1859
7777.804 In reply to 7777.801
<< ...easy to use your tricky Nodeling ...but maybe not so easy to create it from zero! ! ;)
EASY!
1. reinvent the cosinus
2. discover javascript
3. enjoy nodeling
4. keep nodeling
There is still a more EASY version:
Ralf:)
looking for moments of inspiration...
7777.805 In reply to 7777.804
>>2: Discover Javascript
Step 2 is maybe the pitfall hurdle obstacle stumbling block! :)
PS Nodes used are all native nodes renamed ?
As I have yet translated all native nodes in French that will be cool if you have a version with only native ones! :)
For example I don't see "CrankL" in my native list!
I follow this guy every day, day after day, but only for the pleasure of the show! ;)
(and i put Speed 2 : because we have only one life (not like cats who have nine! :D
EDITED: 5 Dec 2017 by PILOU
7777.806 In reply to 7777.804
Uuuuups..
same picture different file.. ;-)
Ralf:)
With the Animator 10 in French native
Animator 11 works very fine!
As you can see i must translate all! :)
Here just translated the "-Limit"!
Look "- Limite" and "+ Limit"
in fact i was too speedy I must translate in French like this "Limite -" :)
Can we have a look of the code of the macro is ?
So a very big metaphysic problem for me : must i translated all nodes or only nodes that please to me! :D
7777.809 In reply to 7777.805
<<<(and i put Speed 2 : because we have only one life (not like cats who have nine! :D
var LengthOfLive=moi.GetDistance(birth,death)/speed;
if(speed<=Math.PI/2){break;}else{return;}
PS translating the nodenames makes only sense for the nodelist... if you have a LOT of nodes you have to give them relating names......
So the French version :)
But no exactly complete because you hid some nodes that i discovered in moving some ones !!! ;)
<< PS translating the nodenames makes only sense for the nodelist
Sure and for the Anglophobic user who has the illusion to understand a little bit of what's happening on the screen! :) :) :)
PS Thx for the Macro : indeed 2 lines can animated the world! :)
So 2 missing! (will be complete on my site! :) http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 6 Dec 2017 by PILOU
Just a silly question! :)
Not for make it, just for info!
How do you attach something to a Macro node ?
Here the French last! :)
7777.813 In reply to 7777.811
>> How do you attach something to a Macro node ? <<
A macro node is just an empty container until node circuitry is put inside.
To do something it needs input/s & output/s that may be connected.
Try double clicking on an existing macro to discover what is inside,
or alternatively create a new macro, double click on it, and add some node/s
include input and output from menu drop down, and then click BACK on the nav bar.
It will all become clear,
7777.814 In reply to 7777.813
Aaaaaaaaaaaah damned! :)
Things hidden from the beginning world! :D
So more nodes to translate! :D
I will obtain an Universalis Encyclopedia! :)
And yes all is quasi clear now! :)
PS Can we put a macro inside a macro ?
And does exist something to alert when you create a node with a name yet existing ?
7777.815 In reply to 7777.814
A macro can contain a macro.
- B
So Fractal world! :)
Missing a paradigm! :)
Circle is drawn inside the macro, not outside the macro!
What i missed ?
7777.817 In reply to 7777.816
Hi Pilou
>> What i missed ? <<
Right Mouse Button click on "Out" in macro
select "Objects" (the default is "Numbers", no appropriate for a curve)
Also remove regular "Output" inside macro, as this will create problems.
Hope this helps
7777.818 In reply to 7777.817
Bravo! Excellent!
Now the more difficult will be to not use this marvelous toy before the next year! :D
So the secret was to take "object" on the "output" in the Macro!
7777.819 In reply to 7777.818
WOW!
yes, the secrets of the macros are finally discovered!
And you can save macros for reuse.
In the animator11.nod there are a couple of macros inside a macro inside a macro....
for example i made a if/else macro (f.e.: ><180) which i used for different cases...
Once you figured out a funtion -> save it as macro and reuse it for a different case...
Bon Noël <:-)
Ralf:)
French Translation of the animator11.nod + Mini Manual of a Macro!
then Macro / animator11
7777.821
Hello to all
a little exercise that starts
from a very interesting surface
the Oloid -
Some deformations , a wire that starts from
surface structure.... et voilà .....
How many interested people find the file at this link:
http://www.mediafire.com/file/qhvj5752j9y7x3f/Oloid_Bracelet.rar
have a nice evening everybody
alberto
7777.822
Hi All,
I have had this error report when pressing run on my test collision nod.
but after I clear the error report the nod file runs ok.
Not sure if it's a bug or my nod file setup ?
The nod takes 2 objects and checks for a collision and if so moves the second object till clear.
Any thoughts ?
Barry
7777.823 In reply to 7777.822
For me it looks like there is a value not set in the beginning..
Try to set defaults in the "prototype.onAdded = function()"
Ralf:)
Show messages:  1-3  …  744-763  764-783  784-803  804-823  824-843  844-863  864-883  …  1844-1859
