 1-13  …  754-773  774-793  794-813  814-833  834-853  …  1854-1859
7777.794 In reply to 7777.793
yes that’s what I need to achieve a node that indicates a collision.
Thanks a lot.
Barry
7777.795 In reply to 7777.793
I modified Max's node as your suggestions but cannot find anyway to connect it to the maths node.
Is the output a numeric number ?
Barry
EDITED: 30 Jan 2021 by BARRY-H
7777.796 In reply to 7777.795
Hi Barry, the output for that case is a boolean value, not a number value. But if you want a number to be output instead, try switching the output type to:
this.addOutput("Out","number");
Then in onExecute, try this:
this.setOutputData(0, output.length == 0 ? 0 : 1);
The "output.length == 0 ? 0 : 1" part is a compact way of saying: "if output length is 0 output 0 else output 1".
7777.797 In reply to 7777.796
changed code as your reply only thing had to change was "number" to "numarray".
works just as I needed so again many thanks for sorting it for me.
Barry
7777.798 In reply to 7777.796
I was a little premature thinking by altering the this.addOutput(“Out”,”number”);
to this.addOutput(“Out”,”numarray”); worked, it only allowed connection to maths node but the maths node does not recognise the input. So back to square one.
Any more ideas gratefully received.
Barry
7777.799
Animate going easy..
Just take the 3 axes from the 3dm file -> place it over the axes points of your favourit piston > name the parts like in the 3dm file -> open nodeeditor with the nod file -> press play and enjoy...
runs fine on nodeeditor @'y'@ 0.99 without any special extensions....
Ralf:)
looking for moments of inspiration...
7777.800 In reply to 7777.798
Hi Barry, well I'd guess numarray would need an array of numbers to be returned instead of just a single individual number.
In Javascript you can make an array by using [], like [ 'a', 'b', 'c' ] . So try changing the onExecute part to this:
this.setOutputData(0, output.length == 0 ? [0] : [1]);
7777.801 In reply to 7777.799
<< Animate going easy..
...easy to use your tricky Nodeling ...but maybe not so easy to create it from zero! ! ;)
There is a (minor) difference in the behavior of the concat2 node in MoI4beta.
It is a failure to release the mouse attachment to the node, under certain circumstances.
By clicking RMB on top of the concat2 node, one of three input configurations may be selected,
called Numbers, (numarray), Points, (pointarray), or Objects.
This should be done before attempting to wire the input with the wrong type.
In MoI4beta, "Dragging" a gold wire for Objects to the wrong input, Numbers or Points, and then pushing RMB and selecting Objects,
results in the proper input being changed to, and the wire attaches, but the mouse is then locked onto the node box.
The only way I've found to release the lock is to press ESC, and reload the file.
This does not happen in MoI3. Clicking the RMB releases the attempt to wrongly attach the wire.
7777.803 In reply to 7777.800
that’s seem’s to be the answer.
Many thanks.
Barry
7777.804 In reply to 7777.801
<< ...easy to use your tricky Nodeling ...but maybe not so easy to create it from zero! ! ;)
EASY!
1. reinvent the cosinus
2. discover javascript
3. enjoy nodeling
4. keep nodeling
There is still a more EASY version:
Ralf:)
7777.805 In reply to 7777.804
>>2: Discover Javascript
Step 2 is maybe the pitfall hurdle obstacle stumbling block! :)
PS Nodes used are all native nodes renamed ?
As I have yet translated all native nodes in French that will be cool if you have a version with only native ones! :)
For example I don't see "CrankL" in my native list!
I follow this guy every day, day after day, but only for the pleasure of the show! ;)
(and i put Speed 2 : because we have only one life (not like cats who have nine! :D
EDITED: 5 Dec 2017 by PILOU
7777.806 In reply to 7777.804
Uuuuups..
same picture different file.. ;-)
Ralf:)
With the Animator 10 in French native
Animator 11 works very fine!
As you can see i must translate all! :)
Here just translated the "-Limit"!
Look "- Limite" and "+ Limit"
in fact i was too speedy I must translate in French like this "Limite -" :)
Can we have a look of the code of the macro is ?
So a very big metaphysic problem for me : must i translated all nodes or only nodes that please to me! :D
7777.809 In reply to 7777.805
<<<(and i put Speed 2 : because we have only one life (not like cats who have nine! :D
var LengthOfLive=moi.GetDistance(birth,death)/speed;
if(speed<=Math.PI/2){break;}else{return;}
PS translating the nodenames makes only sense for the nodelist... if you have a LOT of nodes you have to give them relating names......
So the French version :)
But no exactly complete because you hid some nodes that i discovered in moving some ones !!! ;)
<< PS translating the nodenames makes only sense for the nodelist
Sure and for the Anglophobic user who has the illusion to understand a little bit of what's happening on the screen! :) :) :)
PS Thx for the Macro : indeed 2 lines can animated the world! :)
So 2 missing! (will be complete on my site! :) http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 6 Dec 2017 by PILOU
Just a silly question! :)
Not for make it, just for info!
How do you attach something to a Macro node ?
Here the French last! :)
7777.813 In reply to 7777.811
>> How do you attach something to a Macro node ? <<
A macro node is just an empty container until node circuitry is put inside.
To do something it needs input/s & output/s that may be connected.
Try double clicking on an existing macro to discover what is inside,
or alternatively create a new macro, double click on it, and add some node/s
include input and output from menu drop down, and then click BACK on the nav bar.
It will all become clear,
Show messages:  1-13  …  734-753  754-773  774-793  794-813  814-833  834-853  854-873  …  1854-1859
