 1-20  …  741-760  761-780  781-800  801-820  821-840  …  1841-1859
7777.781 In reply to 7777.777
THX!
but take care... its edictive! ;-)
Ralf
OK! That was a long way to work! :)
Thx for all infos!
Funny of your crazzy toy is that you can make an animation on the same time!
I had just forgotten to load the "file.3dm" !!!
Now I will try the 3D one!
Yep funny indeed! :)
7777.784 In reply to 7777.778
ciao alberto,
the outputs are locked??...
Make sure you open first the pentagraf.3dm...
and than the nodeeditor...
Ralf:)
7777.785 In reply to 7777.783
WOW nice one!
Did you mention, that if you go with the mouse over the animation ore Moi is in background it produces some different curves...
Ralf:)
7777.786
Thank you Ralf, but this malfunction does not occur
only with your file, the procedure for uploading your file
that's exactly what you said,
the defect I believe is in the folders I uploaded in V.099
but I can not figure out where the mistake is-
alberto
French version and manual of the Pentagraph 2D / 3D ! :)
7777.788 In reply to 7777.787
Merci beaucoup!!!
That looks great :-)
The stream.js is now a little bit more robust for bad inputs..
perhabs you can update it
Ralf:)
looking for moments of inspiration...
7777.789
Hi All,
I would like to be able to move an object automatically if it intersects another.
The logic is.
1) Select object 1 and 2
2)Check if they intersect.
3) If Yes move object 2 a given amount 'X+' and keep looping till No intersection or move limit reached.
4) If No move object 2 a given amount 'X-' and keep looping till Yes intersection or move limit reached.
5) When either steps 3 or 4 have been achieved set a flag to indicate loop end.
I know we have an intersect node but I need a true or false or 0 or 1 output.
Any ideas how to achieve this ?
Barry
7777.790 In reply to 7777.789
Hi Barry,
(precision)Bounding box would give an estimate of the size of the objects, and how far to "nudge" one or both, in some direction.
If the intersect factory, via factory.calculate(), has its intersect curves or points sent to an objectlist, and the length is zero, there is no intersection. (?)
(I'll await Michael response :-)
7777.791 In reply to 7777.790
I used the bounding box in my original trials but wanted to use the intersect node to give a more accurate layout (allowing for nesting within the bounding box). My problem is to find away of using the output of intersect node as a true or false or 0 or 1 so I can then trigger the movement.
I looked at the JS code of the intersect node to see if the output could be changed to give a 0 or 1 and then create a new node but my limited JS knowledge is a problem hence my post.
Barry
7777.792 In reply to 7777.791
Instead of factory.commit(), putting the intersecting lines/curves/points in the geometry database,
objList = factory.calculate() would put the curves & points in an objectlist, which could be counted/ checked for length.
I'll defer to the professional programmers, due to my very limited knowledge, and limited time :-)
- B
7777.793 In reply to 7777.791
Hi Barry, it looks like you'd need to do 2 things - you'd need to change the output type of the node which is defined by this line in objIntersect():
It sounds like you want it to output a boolean value, it looks like you can put in "boolean" for that, so change that to:
this.addOutput("Out","boolean");
Then to actually make the boolean value you will need to change the onExecute function for objIntersect, the last line currently looks like this:
To change that to a boolean value instead of outputting the object list try this:
this.setOutputData(0, output.length > 0);
So that should then output true if anything was generated from the intersection or false if nothing was generated.
Does that maybe do what you need?
7777.794 In reply to 7777.793
yes that’s what I need to achieve a node that indicates a collision.
Thanks a lot.
Barry
7777.795 In reply to 7777.793
I modified Max's node as your suggestions but cannot find anyway to connect it to the maths node.
Is the output a numeric number ?
Barry
EDITED: 30 Jan 2021 by BARRY-H
7777.796 In reply to 7777.795
Hi Barry, the output for that case is a boolean value, not a number value. But if you want a number to be output instead, try switching the output type to:
this.addOutput("Out","number");
Then in onExecute, try this:
this.setOutputData(0, output.length == 0 ? 0 : 1);
The "output.length == 0 ? 0 : 1" part is a compact way of saying: "if output length is 0 output 0 else output 1".
7777.797 In reply to 7777.796
changed code as your reply only thing had to change was "number" to "numarray".
works just as I needed so again many thanks for sorting it for me.
Barry
7777.798 In reply to 7777.796
I was a little premature thinking by altering the this.addOutput(“Out”,”number”);
to this.addOutput(“Out”,”numarray”); worked, it only allowed connection to maths node but the maths node does not recognise the input. So back to square one.
Any more ideas gratefully received.
Barry
7777.799
Animate going easy..
Just take the 3 axes from the 3dm file -> place it over the axes points of your favourit piston > name the parts like in the 3dm file -> open nodeeditor with the nod file -> press play and enjoy...
runs fine on nodeeditor @'y'@ 0.99 without any special extensions....
Ralf:)
7777.800 In reply to 7777.798
Hi Barry, well I'd guess numarray would need an array of numbers to be returned instead of just a single individual number.
In Javascript you can make an array by using [], like [ 'a', 'b', 'c' ] . So try changing the onExecute part to this:
this.setOutputData(0, output.length == 0 ? [0] : [1]);
Show messages:  1-20  …  721-740  741-760  761-780  781-800  801-820  821-840  841-860  …  1841-1859
