 1-2  …  723-742  743-762  763-782  783-802  803-822  …  1843-1859
7777.763 In reply to 7777.761
Hi Pilou
It's a bad idea to keep old files in extensions directory.
NE loads all extensions automatically. So it loads basicFunctions first, and then loads basicFunctionsOLD which replaces a new functions with old ones.
7777.764 In reply to 7777.763
Hi Max & Pilou
<< It's a bad idea to keep old files in extensions directory.>>
Sorry, that's on me. I had already removed it before uploading complete NE folder.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.762
Pilou, did my NE folder work for you?
7777.765 In reply to 7777.764
@James
Bravo!
Perfect and the magic is that : Nodes's titles & Functions (that I have yet translated) are preserved!
What is this prodigy ? You have a French version or Max put it inside it own code ?
Excellent! V 3 : Truchet & Dodeca & truncated... ok !
For V4 Truchet OK ! Dodeca & truncated...
a little bug! And only one volume calculated!
Ps A little graphic glitch "?" inside blue square ! (surely an image missing inside the data image of the V4)
EDITED: 24 Nov 2017 by PILOU
7777.766
Friends,
yesterday, November 23 was the Fibonacci
day (11/23 as the numbers contained in its progression),
with pride I can say a "Great Italian "
I send a small tribute to this ingenious mind-
File this link:
http://www.mediafire.com/file/loyv9703apml409/Fibonacci2.rar
To all script experts, I suggest you enter
a series of Fibonacci (see tool Progression ) -
Have a Great Weekend to all
alberto
7777.767 In reply to 7777.766
Hi AL (Ciao AL!)
@You : "...with pride I can say a "Great Italian "..."
YES!!!!
Ciao a tutti! (Hi everyone)
7777.768
7777.769
Just playing with nodes i came to a funny thing....
This thing not only moves - it collects the incoming points to draw a curve...
Because i was not able to do this with a existing node i made my own... Stream2Array (just put stream.js into the extension folder and you will find it listed under ArraysExt)
it works on MoiV4 and @y@0.99
This is my first extension so HANDLE WITH CARE ;-)
Perhaps someone can add some physics to this :-)
Ralf
EDIT:WOW in 3D! Or is it 2.5D? >>pentagraf3D.nod
EDITED: 1 Dec 2017 by R2D3
7777.770 In reply to 7777.769
Genious!
I will test the translation on an extension!
Seems perfect !
You must precise precise inside extensions/ Libs/...
Ok for the translation (not for the nodes because I believe that I have not used the last version of Max Smirnov! )
I have 2 red nodes! :)
SplitPts & ArrayLogger
Does these 2 nodes are from the nodeeditor modified and not from the native original?
EDITED: 30 Nov 2017 by PILOU
7777.771 In reply to 7777.769
Thanks a lot r2d3!!!
Huge...great...amazing contribution!!!
Thanks again :)
7777.772 In reply to 7777.770
Merciii! You translate faster then i program... :-)
the splitPts and ArrayLogger are actualy in the 0.99 from MAX site... build in..
The logger you dont need > delete
the splitPts just takes the X and the Y from the bbox center - pretty sure ther is a similar one which can do it..
most important the "Trame flot2" is NOT red :-)
Just made a nice vase with the pentagraph....
Ralf
7777.773 In reply to 7777.769
That's a really cool one Ralf! - Michael
7777.774 In reply to 7777.772
<< the splitPts just takes the X and the Y from the bbox center - pretty sure ther is a similar one which can do it..
Sorry i don't see it! Have you renamed the tittle of this node ?
What is this mystery? :)
The only Split i see is this one! (and it's not SplitPts ! :)
EDITED: 1 Dec 2017 by PILOU
7777.775 In reply to 7777.774
The splitPts is in the point2 extension..
ore you can use the basic/extract node (two of them)
These are the newest extensions by MAX
Ralf
7777.776
I start to like vases... :-) made by pentagraf...
Ralf
7777.777 In reply to 7777.776
Hello Ralf!
I echo the words I said yesterday.
WANDERFUL THINGS!!!
Very fascinating and interesting.
My congratulation :)
7777.778
Welcome among us Ralf ,Nice entrance.....
nice node, and beautiful Extension "Stream"Script
compliments...
I just uploaded the file in V3 and launched in v 0.99
Max's last version, all right, I noticed a single drawback ,
all outputs are locked ...
I can not unload them with the usual click....
Someone has the same problem....
or, maybe i have badly installed v 0.99?
Very most welcome your info-
best
alberto
Ok I have all nodes this time! :)
If i good undertstand now there is no necessary to have a Nodeditor modified just extentions enable or not
and of course the new nodes, libs...
But Now I need the manual! For 2D first! :)
Curve? Lines ? ... names them ... the big fog! :)
Because nothing Pentographing for the moment! (2 Get Name are pinky! :)
7777.780 In reply to 7777.779
TRES BIEN!
dont think about the pinkys - they are only colored to identify the axes..
MANUAL:
1:open the pentagraf.3dm
2:oben nodeditor
3:load the pentagraf3D.nod (much more funnyer :)
4:hit run and enjoy
these settings makes vases:
you can also make your own pentagraf (actualy this things are called PANTOGRAPH..)
important is only that you name the axes and levers like the original (i just made one only with just circles and lines)
Ralf
7777.781 In reply to 7777.777
THX!
but take care... its edictive! ;-)
Ralf
OK! That was a long way to work! :)
Thx for all infos!
Funny of your crazzy toy is that you can make an animation on the same time!
I had just forgotten to load the "file.3dm" !!!
Now I will try the 3D one!
Show messages:  1-2  …  703-722  723-742  743-762  763-782  783-802  803-822  823-842  …  1843-1859
