 1-8  …  709-728  729-748  749-768  769-788  789-808  …  1849-1859
7777.749 In reply to 7777.748
@You : "...Does not exist a complete folder ziped "ready to use" ?..."
....It's the million-dollar question!!
7777.750 In reply to 7777.748
Hi Pilou
Unzip attachment and replace "nodeeditor/nodes/extension" folder.
I contains "ExtractEdges" node, so you are good ti go.
<<For the beta V4>>
You will likely encounter error messages attempting to run in V4
It seems that v4 is more stringent in parsing js code.
I could not get "pentakisDodeca&TruncIcosa.nod" to execute.
EDITED: 14 May 2019 by JFH
7777.751 In reply to 7777.750
<< Unzip attachment and replace "nodeeditor/nodes/extension" folder.
Perfect for the V3 (for me it's "extentionS" folder ! ;)
So just one folder to name/rename for use the //node editor or return to Max one!
Maybe a day i will translate all English tittles' nodes in French who are not yet made! :)
EDITED: 23 Nov 2017 by PILOU
Alas seems not the same for the Truchet.nod above! I keep the James one above:)
Some nodes stay in "red"! i have made some try with objects.js, objects2.js (must they live bother, kill one, rename one ?...)
but without result!
So a new zip "extensions" package (or more) will be profitable for not lose too much times and headaches for old brain! :)
7777.753 In reply to 7777.752
Hi Pilou
<< Alas seems not the same for the Truchet.nod above!>>
For me "Truchet.nod" works in both v3 & v4 with extensions folder replacements:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.750
Don't worry about "objects2.js", it is already included in extensions folder.
Try downloading "Truchet.nod" again. It is possible it has been updated
since the version you originally downloaded.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.731
It is curious because I have found that most of my NE experiments
will not run in v4. For example my earlier experiment "spaceFrames2.nod"
give this runtime error message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.739
So, we know that none of the nodes used in "Truchet.nod" cause problems
and at least one or more of the culprit nodes is in the macro of "spaceFrames2.nod".
UPDATE: I tried pulling nodes out of macro and rebuilding on main tier, to see if
macros themselves were the issue. But no, I still recieved the same error alert.
EDITED: 23 Nov 2017 by JFH
7777.754 In reply to 7777.753
Hi James
could you send me this nod-file and all files from your extensions folder?
7777.755 In reply to 7777.754
Hi Max,
Please find files attached.
FYI I'm a mac user (10.13.1).
7777.756 In reply to 7777.755
Hi James,
this error caused by Infos/GetBBoxes BoundingBoxes (infonodes.js)
line 477: bbox.pushPoint(input.item(i).getBoundingBox().center);
You need to set boolean parameter for getBoundingBox() function
change this line to: bbox.pushPoint(input.item(i).getBoundingBox(false).center);
7777.757 In reply to 7777.756
Thanks Max
That has fixed the problem.
I have attached "extension.zip"
with fixed infonodes.js included
Thanks again
PS Attempt to run "pentakisDodeca&TruncIcosa.nod" (attached)
gives the error message in red box, however does generate result
albeit with pentakisDodecahedron in default colour rather than red.
Generally, I get the main error alert showing when navigating in
NE interface.
Hope this helps!
Size: 44.6 KB, Downloaded: 106 times, Dimensions: 800x465px
About Truchet above
Seems it's these red nodes who give problem! (Windows 10, NE modified, Moi V 3)
<< Also requires most recent NE mod (Karsten's cleanup menu)
Hum hum ... so need them ? Give me a zip package! :)
If i have not an easy way (for me), how do you want i can help for other French people! :)
7777.759 In reply to 7777.756
Hi Max & James,
This is a bug where v4 has that marked as a required argument while v3 had it as optional with a default value of false. I've updated it so it will behave the same as v3 in the next beta.
Message 7777.760 deleted 23 Nov 2017 by JFH
7777.761 In reply to 7777.760
hum hum :)
After some reinstalls of all ! (Windows 10 - V3 ) with editor.js & last editor.css
I have that who works fine for the Penta node...but not for the truchet.nod !
Some different authors for differents trees for differents versions goes naturally to some mess! :)
I dont understand why each new node is not posted with its entiere nodeeditor folder ?
That avoid all this mess for simple user! Not ecologic but efficient! :)
7777.762 In reply to 7777.761
OK Pilou, I've attached my NE directory.
Let me know if problems persist.
EDITED: 12 May 2019 by JFH
7777.763 In reply to 7777.761
Hi Pilou
It's a bad idea to keep old files in extensions directory.
NE loads all extensions automatically. So it loads basicFunctions first, and then loads basicFunctionsOLD which replaces a new functions with old ones.
7777.764 In reply to 7777.763
Hi Max & Pilou
<< It's a bad idea to keep old files in extensions directory.>>
Sorry, that's on me. I had already removed it before uploading complete NE folder.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.762
Pilou, did my NE folder work for you?
7777.765 In reply to 7777.764
@James
Bravo!
Perfect and the magic is that : Nodes's titles & Functions (that I have yet translated) are preserved!
What is this prodigy ? You have a French version or Max put it inside it own code ?
Excellent! V 3 : Truchet & Dodeca & truncated... ok !
For V4 Truchet OK ! Dodeca & truncated...
a little bug! And only one volume calculated!
Ps A little graphic glitch "?" inside blue square ! (surely an image missing inside the data image of the V4)
EDITED: 24 Nov 2017 by PILOU
7777.766
Friends,
yesterday, November 23 was the Fibonacci
day (11/23 as the numbers contained in its progression),
with pride I can say a "Great Italian "
I send a small tribute to this ingenious mind-
File this link:
http://www.mediafire.com/file/loyv9703apml409/Fibonacci2.rar
To all script experts, I suggest you enter
a series of Fibonacci (see tool Progression ) -
Have a Great Weekend to all
alberto
7777.767 In reply to 7777.766
Hi AL (Ciao AL!)
@You : "...with pride I can say a "Great Italian "..."
YES!!!!
Ciao a tutti! (Hi everyone)
7777.768
Show messages:  1-8  …  689-708  709-728  729-748  749-768  769-788  789-808  809-828  …  1849-1859
