 1-4  …  705-724  725-744  745-764  765-784  785-804  …  1845-1859
Hello
For the beta V4
I have downloaded the Pentakis... familly nodes inside the last Max Smirnov
November nodeeditor.v.0.97.2017.10.05.zip + New EditorCss + Editor.js
I have "red nodes"
What is the method for make these nodes efficient ?
Does it possible ?
Or I must load a // Elephant (What is its last version ? And it's working in the beta V4)
Message 7777.746 deleted 23 Nov 2017 by JFH
7777.747 In reply to 7777.746
Thx
So junction between the 2 versions are not yet made!
Must have two Node editors folders specialized under the hood! :)
And that works on the Beta V4 ?
EDITED: 23 Nov 2017 by PILOU
Hum it's not very clear to install! :) (Windows 10 OS )
Does not exist a complete folder ziped "ready to use" ?
7777.749 In reply to 7777.748
@You : "...Does not exist a complete folder ziped "ready to use" ?..."
....It's the million-dollar question!!
7777.750 In reply to 7777.748
Hi Pilou
Unzip attachment and replace "nodeeditor/nodes/extension" folder.
I contains "ExtractEdges" node, so you are good ti go.
<<For the beta V4>>
You will likely encounter error messages attempting to run in V4
It seems that v4 is more stringent in parsing js code.
I could not get "pentakisDodeca&TruncIcosa.nod" to execute.
EDITED: 14 May 2019 by JFH
7777.751 In reply to 7777.750
<< Unzip attachment and replace "nodeeditor/nodes/extension" folder.
Perfect for the V3 (for me it's "extentionS" folder ! ;)
So just one folder to name/rename for use the //node editor or return to Max one!
Maybe a day i will translate all English tittles' nodes in French who are not yet made! :)
Alas seems not the same for the Truchet.nod above! I keep the James one above:)
Some nodes stay in "red"! i have made some try with objects.js, objects2.js (must they live bother, kill one, rename one ?...)
but without result!
So a new zip "extensions" package (or more) will be profitable for not lose too much times and headaches for old brain! :)
7777.753 In reply to 7777.752
Hi Pilou
<< Alas seems not the same for the Truchet.nod above!>>
For me "Truchet.nod" works in both v3 & v4 with extensions folder replacements:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.750
Don't worry about "objects2.js", it is already included in extensions folder.
Try downloading "Truchet.nod" again. It is possible it has been updated
since the version you originally downloaded.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.731
It is curious because I have found that most of my NE experiments
will not run in v4. For example my earlier experiment "spaceFrames2.nod"
give this runtime error message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.739
So, we know that none of the nodes used in "Truchet.nod" cause problems
and at least one or more of the culprit nodes is in the macro of "spaceFrames2.nod".
UPDATE: I tried pulling nodes out of macro and rebuilding on main tier, to see if
macros themselves were the issue. But no, I still recieved the same error alert.
EDITED: 23 Nov 2017 by JFH
7777.754 In reply to 7777.753
Hi James
could you send me this nod-file and all files from your extensions folder?
7777.755 In reply to 7777.754
Hi Max,
Please find files attached.
FYI I'm a mac user (10.13.1).
7777.756 In reply to 7777.755
Hi James,
this error caused by Infos/GetBBoxes BoundingBoxes (infonodes.js)
line 477: bbox.pushPoint(input.item(i).getBoundingBox().center);
You need to set boolean parameter for getBoundingBox() function
change this line to: bbox.pushPoint(input.item(i).getBoundingBox(false).center);
7777.757 In reply to 7777.756
Thanks Max
That has fixed the problem.
I have attached "extension.zip"
with fixed infonodes.js included
Thanks again
PS Attempt to run "pentakisDodeca&TruncIcosa.nod" (attached)
gives the error message in red box, however does generate result
albeit with pentakisDodecahedron in default colour rather than red.
Generally, I get the main error alert showing when navigating in
NE interface.
Hope this helps!
Size: 44.6 KB, Downloaded: 106 times, Dimensions: 800x465px
About Truchet above
Seems it's these red nodes who give problem! (Windows 10, NE modified, Moi V 3)
<< Also requires most recent NE mod (Karsten's cleanup menu)
Hum hum ... so need them ? Give me a zip package! :)
If i have not an easy way (for me), how do you want i can help for other French people! :)
7777.759 In reply to 7777.756
Hi Max & James,
This is a bug where v4 has that marked as a required argument while v3 had it as optional with a default value of false. I've updated it so it will behave the same as v3 in the next beta.
Message 7777.760 deleted 23 Nov 2017 by JFH
7777.761 In reply to 7777.760
hum hum :)
After some reinstalls of all ! (Windows 10 - V3 ) with editor.js & last editor.css
I have that who works fine for the Penta node...but not for the truchet.nod !
Some different authors for differents trees for differents versions goes naturally to some mess! :)
I dont understand why each new node is not posted with its entiere nodeeditor folder ?
That avoid all this mess for simple user! Not ecologic but efficient! :)
7777.762 In reply to 7777.761
OK Pilou, I've attached my NE directory.
Let me know if problems persist.
EDITED: 12 May 2019 by JFH
7777.763 In reply to 7777.761
Hi Pilou
It's a bad idea to keep old files in extensions directory.
NE loads all extensions automatically. So it loads basicFunctions first, and then loads basicFunctionsOLD which replaces a new functions with old ones.
7777.764 In reply to 7777.763
Hi Max & Pilou
<< It's a bad idea to keep old files in extensions directory.>>
Sorry, that's on me. I had already removed it before uploading complete NE folder.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.762
Pilou, did my NE folder work for you?
Show messages:  1-4  …  685-704  705-724  725-744  745-764  765-784  785-804  805-824  …  1845-1859
