 1-10  …  691-710  711-730  731-750  751-770  771-790  …  1851-1859
7777.731 In reply to 7777.729
Hi All,
Attached is .nod file to produce result as shown.
(not exactly as pattern is randomly generated)
It is a requirement for execution that "object2.js"
attached to my earlier post replaces similar in
"nodeeditor/nodes/extensions".
Also requires most recent NE mod (Karsten's cleanup menu):
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
It appears to be robust, but rename original
so you may easily revert to it if problems arise.
EDITED: 14 May 2019 by JFH
7777.732 In reply to 7777.731
Wow!
Wanderful node James.
You rock!!
Ciao!
7777.733 In reply to 7777.731
Looks cool James.
7777.734
Hi friends
This is my last Macro- Rhombic Grid,
I thought of it as my utility for
the creation of the Clifford Torus-
Anyway I think it can be a tool
of wide use ...
at least I hope ,
the exercise at this link:
http://www.mediafire.com/file/0lpo8m4fxsselje/M-Rhombic_Grid.rar
Have a nice day to all
alberto
7777.735 In reply to 7777.734
Nice node Alberto.
(note, getting an error with MoIV4 NEv0.97)
7777.736
Many thanks Brian....
I have not yet tried Elephant with the New Beta V4
just released, my philosophy is to wait
Max puts his hand to new versions making
compatible
Thanks again.....
Have a nice day
alberto
7777.737 In reply to 7777.736
Agreed alberto.
Tried out Motor2017 node, and CycloidGear node with V4, and they work well.
- B
7777.738
Hi Friends
I want to share this last search
in the field of Special Surfaces, I tried to make a Variation
to Boy's Surface ...
some parts are similar to those next to (polo)
the rest I changed by doing it maybe
more feasible, I think....
file to this link:
http://www.mediafire.com/file/x13bn7kpkm11mq1/BOY_%27S_Variation.rar
Have a great weekend to all
best
alberto
7777.739
Hi All,
Please find .nod file with spaceFrame macro.
It is a requirement for execution that extractEdges node be present.
"object2.js" to replace similar in "nodeeditor/nodes/extensions".
can be found in my earlier post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.729
Be warned that generation time may be approx. 20 secs
7777.740
Hi Friends
I want to share this new one
exercise of Sub Poly Triacontahedron
really interesting I think ......
file to this link:
http://www.mediafire.com/file/024zcfv5ctinjpp/New_Triacontahedron_Subd.rar
alberto
Ps- James nice result gives you exercise frame
Message 7777.741 deleted 22 Nov 2017 by JFH
7777.742
Hi Karsten,
how's everything okay?
... it's been a while since I did not live alive ..
I wanted to ask you , if it was possible to improve the tools
Fillet and Bridge ....
When you created these Extensions, if i 'm not wrong ,there were not
Extraxt and Extract Edge (James's paternity).
Now, I ask you, using the latter, you can not improve and make it
easier the procedure currently in use, which I personally believe
very laborious and unstable time ...
I wait for your new ones
Have a nice day
alberto
7777.743 In reply to 7777.740
Hi Alberto,
I was inspired by your node to make simple*
nod file to create pentakis Dodecahedron
derived from solid/polyhedron.nod with Dodecahedron option.
UPDATED:
Super simple method for truncated icosahedron (well almost) included.
*It should be simpler. Hopefully we will soon have new info nodes for finding center point of a regular closed curve.
7777.744
Hi James
I am very happy to be one of your "inspirers" Yeha ...... ,
and , even though I did not open the file, I must tell you that
PentakisPolyhedron is very usefulll for triangular tassellation
of domes or spheres-
For this purpose I send you the Truncated Icosahedron file , to get
a base for classic soccer ball construction
file to this link:
http://www.mediafire.com/file/pc5les5y6cqp4u3/CP-Truncated_Icosahedron.rar
Nb - the files are about a half ago, I think, February,
I do not know if they had been implemented by Max Polyhedron tools
in any case, in the nod. file there is all the classical construction
of the icosahedron
Have a nice day
alberto
Hello
For the beta V4
I have downloaded the Pentakis... familly nodes inside the last Max Smirnov
November nodeeditor.v.0.97.2017.10.05.zip + New EditorCss + Editor.js
I have "red nodes"
What is the method for make these nodes efficient ?
Does it possible ?
Or I must load a // Elephant (What is its last version ? And it's working in the beta V4)
Message 7777.746 deleted 23 Nov 2017 by JFH
7777.747 In reply to 7777.746
Thx
So junction between the 2 versions are not yet made!
Must have two Node editors folders specialized under the hood! :)
And that works on the Beta V4 ?
EDITED: 23 Nov 2017 by PILOU
Hum it's not very clear to install! :) (Windows 10 OS )
Does not exist a complete folder ziped "ready to use" ?
7777.749 In reply to 7777.748
@You : "...Does not exist a complete folder ziped "ready to use" ?..."
....It's the million-dollar question!!
7777.750 In reply to 7777.748
Hi Pilou
Unzip attachment and replace "nodeeditor/nodes/extension" folder.
I contains "ExtractEdges" node, so you are good ti go.
<<For the beta V4>>
You will likely encounter error messages attempting to run in V4
It seems that v4 is more stringent in parsing js code.
I could not get "pentakisDodeca&TruncIcosa.nod" to execute.
Show messages:  1-10  …  671-690  691-710  711-730  731-750  751-770  771-790  791-810  …  1851-1859
