 1  …  682-701  702-721  722-741  742-761  762-781  …  1842-1859
7777.722 In reply to 7777.721
Karsten
RE:Atomium...Ahh now I get you
RE: SeparateObj
Cheers, thanks for info
7777.723
how can I enter an adjustable range ( from calcs using maths nodes ) into the points node other than with the range slider.
Barry
7777.724 In reply to 7777.723
Hi Barry,
<<enter an adjustable range.... other than with the range slider>>
Use objects2/concat2 node, with RMB option Numbers
Let me know if you need further clarification
EDITED: 5 Nov 2017 by JFH
7777.725 In reply to 7777.723
Hello Barry,
of corse, you can. Start and end value can be calculated independent from each other. Then you have to concate them together as input for the points node.
Concate2 node can take numarray, pointarray and objects as input (RMB).
Have a nice day
Karsten
7777.726 In reply to 7777.724
Hi James,
thanks can't tell you how long I've messed about trying different permutations.
Not sure if my memory is correct but did Karsten do a spreadsheet with node definitions on it ?
Barry
7777.727 In reply to 7777.726
Hi Barry
Spreadsheet can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.200
7777.728 In reply to 7777.718
Hi James.
Thanks you very much!
This is a very useful nod file!
Ciao!
7777.729 In reply to 7777.728
Hi Marco (& others),
<<This is a very useful nod file!>>
Assuming you are talking about "convert.nod",
you may prefer to do what I have done,
which is to include new node in "objects2"
called "ExtractEdges"
It is simply Karsten's "Extract" node minus a few lines of code.
It achieves the same effect as convert.nod edges output
without issues that arise with multiple inputs & poly-surfaces.
Maybe you could look at it's code.
It is at the very end of the script.
I suspect that several more unnecessary lines
may be removed (or made into comments)
EDITED: 14 May 2019 by JFH
7777.730 In reply to 7777.729
Hi James.
Thanks a lot for the "ExtractEdges" new node !
I will be very useful also for my "2D workflows" :)
Asap I'm going to look at its code.
Thanks!
7777.731 In reply to 7777.729
Hi All,
Attached is .nod file to produce result as shown.
(not exactly as pattern is randomly generated)
It is a requirement for execution that "object2.js"
attached to my earlier post replaces similar in
"nodeeditor/nodes/extensions".
Also requires most recent NE mod (Karsten's cleanup menu):
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
It appears to be robust, but rename original
so you may easily revert to it if problems arise.
7777.732 In reply to 7777.731
Wow!
Wanderful node James.
You rock!!
Ciao!
7777.733 In reply to 7777.731
Looks cool James.
7777.734
Hi friends
This is my last Macro- Rhombic Grid,
I thought of it as my utility for
the creation of the Clifford Torus-
Anyway I think it can be a tool
of wide use ...
at least I hope ,
the exercise at this link:
http://www.mediafire.com/file/0lpo8m4fxsselje/M-Rhombic_Grid.rar
Have a nice day to all
alberto
7777.735 In reply to 7777.734
Nice node Alberto.
(note, getting an error with MoIV4 NEv0.97)
7777.736
Many thanks Brian....
I have not yet tried Elephant with the New Beta V4
just released, my philosophy is to wait
Max puts his hand to new versions making
compatible
Thanks again.....
Have a nice day
alberto
7777.737 In reply to 7777.736
Agreed alberto.
Tried out Motor2017 node, and CycloidGear node with V4, and they work well.
- B
7777.738
Hi Friends
I want to share this last search
in the field of Special Surfaces, I tried to make a Variation
to Boy's Surface ...
some parts are similar to those next to (polo)
the rest I changed by doing it maybe
more feasible, I think....
file to this link:
http://www.mediafire.com/file/x13bn7kpkm11mq1/BOY_%27S_Variation.rar
Have a great weekend to all
best
alberto
7777.739
Hi All,
Please find .nod file with spaceFrame macro.
It is a requirement for execution that extractEdges node be present.
"object2.js" to replace similar in "nodeeditor/nodes/extensions".
can be found in my earlier post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.729
Be warned that generation time may be approx. 20 secs
7777.740
Hi Friends
I want to share this new one
exercise of Sub Poly Triacontahedron
really interesting I think ......
file to this link:
http://www.mediafire.com/file/024zcfv5ctinjpp/New_Triacontahedron_Subd.rar
alberto
Ps- James nice result gives you exercise frame
Message 7777.741 deleted 22 Nov 2017 by JFH
Show messages:  1  …  662-681  682-701  702-721  722-741  742-761  762-781  782-801  …  1842-1859
