 1-8  …  29-48  49-68  69-88  89-108  109-128  …  1849-1859
7777.69 In reply to 7777.68
Hi Karsten
Thank you very much,
looking forward your updated Blend
good work
Best
al
7777.70
Hi Karsten and Friends
You post this exercise for deepening the Node Blend ,
very important to me, together with Fillet....
Karsten, did You may revise Node BrepNameSubObjects , when you have the opportunity to do so ?
in such a way that it can yield back the selected geometry
in the form of Output can then be used as Input for other Feature
type,Curve, Surf etc. etc. for tools Loft, Extrude etc etc...
Moreover I am absolutely of the opinion that range to maintain the links with
other reactions should necessarily have two inputs
Start and End domain ...
we hope that some of you experts can satisfy
my desire
Thanks for everything and have a good weekend to all
Best
al
Size: 239.9 KB, Downloaded: 248 times, Dimensions: 1920x1080px
7777.71 In reply to 7777.70
Hello Al,
If I get you right, you want to extract geometry from a nodes output e.g. a face or a edge to use it as an input for a e.g. sweep. I thought about it already and I think it is possible.
Here I didn't get you, please explain your idea in more detail.
At the moment I try to make getCrvSFrame and Sweep multiprocess ready. I also made an update/addition to the point node - If you preselect points of a given geometry and create now the point node you have all coordinates evaluated in it. e.g.: Switch on the controlpoints of a surface, select them --> copy/paste and let them selected - go to the node editor and create a new point node, you will have a independent copy of them inside the node. I don't know what it is good for, but I'm sure that someone will have an idea for that;-)
Have a nice weekend
Karsten
p.s.: I'm not an expert Motto: I'm glad I'm crazy, it keeps me trying! -Iggy Pop-
7777.72 In reply to 7777.70
Hi Al,
Start and End domain ...<<
Unless I have misunderstood you; Karsten's Concat2 node already satisfies this requirement.
Hope this helps
-James
7777.73 In reply to 7777.71
Hi Karsten,
>>I also made an update/addition to the point node<<>>I don't know what it is good for, but I'm sure that someone will have an idea for that<<
I think it would be very useful if analysis of distances between these points could be determined,
and it's results: absolute dist, x dist, y dis, z list, be used as inputs into other nodes.
Michael's CustomDistance script is only a few lines of code. Is this be something that
could be reworked as node with relative ease?
Just a thought
-James
7777.74
Hello friends
I want to share this exercise on using fillet
I hope this will be usefull for someone .......
<James>
I understood what you want to tell me how to use
Concatenate2 , You're right it works ....
I agree that we should do a Node Distance and
I suggest , also ;
Vector and Evalutate Curves (Ref. Grasshopper)
I think you all know ....
It could draw a line from one point to one direction
with a given distance and you could use Vector also
in Extrusions , and other applications ....
I know it's hard work, but someone has to do it ! ! ! !
<Karsent>
about your madness, I assure you
I'm not joking to say I'm not less crazy
and I'm happy as well
Best
al
Size: 323.8 KB, Downloaded: 223 times, Dimensions: 1680x1050px
7777.75 In reply to 7777.74
Hello Al,
thanks for sharing your tests. Beware of the fillet factory - it's a killer (Moi-crash) that I can't tame at the moment!
EEhhhm - I'm not. I never used Rhino and so I'm not familiar with Grasshopper. I know nearly nothing about it. Neither the functionality, nor the workflow. I saw one very interesting video and one very long and boring, where someone was clicking hundreds of buttons and options, until I was sleeping.
So what do you want to evaluate at curves?
Am I right about vectors, that you want it as inputs for a direction for e.g. lines, or extrusions ( + input of the length)?
Have a nice day
Karsten
7777.76 In reply to 7777.75
Hi Karsten , many thanks...
EvalutateCurves is the ability to insert one or more points
on a curve, and to have as output, the point, the frame
oriented on point into a curve;
therefore a "blend "between your Path_Array and GetCvrS frame
In Extrusions Node you could use the Vector
for direction plus a distance, and , optionally possibly to
draft on the faces-
About Grasshopper, I think you have been Unfortunate to watch the Video ! ! !
Grasshopper , in my opinion , is the First and I still unbeaten program for
Parametric modeling Nodal-
The program is full of fans, and believe me, ABSOLUTELY worth it for you to give a view to the Forum
http://www.grasshopper3d.com
and the impressive number of plug-ins dedicated to it
http://www.food4rhino.com
I think you should perhaps get some inspiration
from the big old GH-
In any case, I am attaching some picture of how are the nodes
in Grasshopper related to Evalutate Curves and output Vector , and Curve length
Good work, and have a good day
Best
al
Size: 446.4 KB, Downloaded: 198 times, Dimensions: 1680x1050px
Size: 458.9 KB, Downloaded: 168 times, Dimensions: 1680x1050px
Size: 455.8 KB, Downloaded: 179 times, Dimensions: 1680x1050px
7777.77
Hi Friend
I send a hard test on the use of Fillet,
despite all the doubts of Karsten,
it seems quite powerful,
only one clarification ,
>Karsten < could we add a link to
Knob or Slide, into Fillet Node?
See attached Picture-
Best to all
al
Size: 326.2 KB, Downloaded: 257 times, Dimensions: 1680x1050px
Size: 341.5 KB, Downloaded: 243 times, Dimensions: 1680x1050px
7777.78 In reply to 7777.77
Hello Al,
I have forgotten to change from number to numarray for the input in fillet node. In addition I thought and I still think about your suggestions for the eval Curve. At the moment you can make also a workaround for that with the given nodes. I will add also an update button for the fillet next time. At the moment I rearrange the the nodes to the menuitems, and I hope that old nodefile won't be dirty.
Have a nice weekend
Karsten
p.s.: Cool result!
EDITED: 6 Mar 2019 by KMRQUS
7777.79 In reply to 7777.78
Hello Al and Karsten and good morning,
I'm running latest Project Elephant (0_85mod) and I downloaded your latest construct2.js file.
When I run the" pa_al.nod" file I get the error displayed by attached image.
What's missing in my Elephant installation ?
Size: 49.1 KB, Downloaded: 171 times, Dimensions: 536x480px
7777.80 In reply to 7777.79
Hello Marco,
I think nothing - but that message comes sometimes up, when nodes have been modified and that is definitively in my installation - please try to replace the nodes and rewire or post, please, a screenshot of the nodeeditor window first.
I will post a new version next days.
Have a nice day
Karsten
7777.81 In reply to 7777.80
I'm sorry Karsten but...I didn't understand this part of your reply :
> "please try to replace the nodes and rewire or post, please, a screenshot of the nodeeditor window first."
Could you please explain ?
7777.82 In reply to 7777.81
Hello Marco,
it means: make a screenshot of the nodeeditors window;-) that I can have a look which node is missing:-)
Have a nice day
Karsten
7777.83 In reply to 7777.82
Ok Karsten,
Here's a medley of my 0.85_mod Project Elephant nodes : http://take.ms/m4zNA
I skipped the standard ones.
best,
7777.84 In reply to 7777.83
Hi Karsten and Marco
Make no mistake I made as well,
but perhaps it is not the proper way .......
I removed your old Node Costruct2 from the Nodeditor folder
I substitute it with the new ....
Opening the file there were problems
see attached picture ...
then at the end it seems that everything works
Pat array rewritten is cool , very flexible i Think now.........
What are the Extrude nodes, etc, etc. I do not understand the connections
you can make me a picture to understand
thank you, great
al
Size: 274.7 KB, Downloaded: 167 times, Dimensions: 1920x1080px
Size: 250.4 KB, Downloaded: 163 times, Dimensions: 1920x1080px
Size: 273.6 KB, Downloaded: 156 times, Dimensions: 1920x1080px
7777.85 In reply to 7777.84
Hello Marco, Hello Al,
sorry! I have used a not distributed node in it, but the file shows already what it should:-) It is an extract node for bReps that is missing! Attached my last experiments;-)
You can install it also parallel to your existing installation for test with an additional shortcut;-) Subdiv isn't finished!
Have a nice day
Karsten
EDITED: 12 Dec 2017 by KMRQUS
7777.86 In reply to 7777.85
ok-first tests:-) SubDiv is only a wrapped version of Max great SubDiv skript!
EDITED: 8 Jan 2018 by KMRQUS
7777.87 In reply to 7777.85
Thank you VERY much Karsten !!
Now all works fine!
P.S. Is becoming increasingly difficult to keep organized the original Max's Project Elephant "supercharged" with all new nodes written by the community.
Thanks again and good evening to everyone.
Best,
7777.88
Hi Karsten
Currently I have installed in my folder Nodeeditor your version 0.85
of 7/10/2016 ...
To install one today ,
I remove the contents of the Nodeeditior and I put this
last ....
give me an answer
I would not create a chaos
I'm sorry
best
al
Show messages:  1-8  9-28  29-48  49-68  69-88  89-108  109-128  129-148  …  1849-1859
