 1-3  …  644-663  664-683  684-703  704-723  724-743  …  1844-1859
7777.684 In reply to 7777.683
Hi James,
thanks it works great now.
Is it possible to flow selected tiles to this topology as Rhino's panelling tool ?
Barry
7777.685 In reply to 7777.684
Hi Barry,
<<Is it possible to flow selected tiles to this topology as Rhino's panelling tool ?>>
Yes, now it is. I have updated my earlier post with new "retop. nod" with ordered points.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.683
It should work now.
EDITED: 1 Nov 2017 by JFH
7777.686 In reply to 7777.685
Hi James,
got this result when I ran your latest nod the outer facets extend inside any idea's ?
Barry
Size: 152.6 KB, Downloaded: 88 times, Dimensions: 487x467px
7777.687 In reply to 7777.685
Hi James,
not sure if the attached photo showing highlighted facet helps.
So the facet seems to loft from outer boundary to inner on opposite side and vice versa for other side.
Thanks.
Barry
Size: 114.2 KB, Downloaded: 79 times, Dimensions: 480x441px
7777.688 In reply to 7777.687
Hi Barry,
Can you please upload .nod file so I can understand what you are trying to do.
7777.689 In reply to 7777.688
Hi James,
I haven't changed anything from your posted nod file just selected surface and run.
Your photo looks correct but mine as the result shows the outer facets are extending to the
opposite side.I have attached the surface and the nod file.
Barry
7777.690 In reply to 7777.689
Oop! I had uploaded a WIP file instead of the final version.
New version can be now found here:
7777.691 In reply to 7777.690
Hi James,
perfect works great thanks.
Will it be possible to select a object and tile it to the surface in one of your future nod
as you have shown in photo of your earlier post ?
Again many thanks
Barry
7777.692 In reply to 7777.691
UPDATED: macro now includes faceted & smoothed surface options
Hi Barry,
<<Will it be possible to select a object and tile it to the surface
in one of your future nod>>
Good idea...please find attached.
EDITED: 14 May 2019 by JFH
7777.693 In reply to 7777.692
Hi James,
superb and with the option of smooth or faceted excellent.
Looks even better with thickened tiles perhaps an extrude or shell function could be added.
So again many thanks.
Barry
7777.694
Hi James
I need help......
your Macro Retopo does not work with your Isocuve tools
has the following ID-Construct2 / isocurve
my Isocuve has the following ID_test / isocurve
You may kindly send me your update
to insert it into the program-
Surely I missed some will last update of
Karsten
By the way fine work,compliments
Thanks in advance and
have a nice day
best
alberto
7777.695
Hi All,
The pace the forum and this project moves at is amazing - this node is fantastic! Another old Rhino Plugin which would work much better under the finesse of a NODE master is the Array 3d Over Curve plugin. Here is a result. With plugin you can control an object with a control point to array over a curve path. With incremental Scale/Rotation/Spacing can be incremental or constant.
Here is result
Admirer of Fines Nodes but Luddite in Practice.
EDITED: 20 Sep 2020 by ALEXPOLO
7777.696 In reply to 7777.694
Hi Alberto,
I had similar issues where nodes have been relocated but if you just replace the
ISO nodes with iso nodes from test it should work.
Barry
Hello Alberto, James, AlexPolo, Karsteen, Barry (and the other N.E. smart guys)
I'm fascinated to see what you are doing with the NE!!!
You're doing wanderful things!!!
I think that actually the unique and real "Achilles heels" of the NE project is the limits and the poor performance of the current Moi's Api.
As soon as Michael will improve it I think we will see amazing stuff!
Thanks!
Ciao.
Marco (mkdm)
7777.698 In reply to 7777.697
Hi Marco, what performance improvements are you looking for specifically?
Do you have a case with poor performance that you can post?
7777.699 In reply to 7777.694
Hi Alberto &, Barry
<<Surely I missed some will last update of Karsten>>
Have a read of Karsten's post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Changing to new menu system breaks old .nod files,
but it is much more elegant and efficient.
And Karsten describes a method for updating with
minimum disruption (for windows users, at least)
I encourage you to update, if too, only so I can appreciate
your brilliant examples
EDITED: 2 Nov 2017 by JFH
7777.700 In reply to 7777.699
Hi James,
I agree update to Karstens post is the best option but it should be noted that old/new nod files that contain nodes that have been relocated can easily be fixed by replacing from new/old location.
As I found when running old nod files and the iso node was in test and I was running latest Karsten extensions and it had been moved to construct2.
Hope this explains my reasoning.
Barry
7777.701
Hi James and Friends
Thank you all for the support...
Now the Retopo and Tile files work perfectly ..
I wanted to ask if, rather than following the Method
driven by Karsten, they could coexist inside
of the same Folder both old tools and new ones ,
perhaps renaming Js new files-
In this case there would be maximum compatibility between old and new
with the only Handicap to have more Tool Labels
What do you say ... can you do it?
In each case again thanks to everyone
for support
best
alberto
7777.702
Hi James,
my request for extrude or shell is not needed.(I need to plug my brain in before asking)
By starting with a solid its possible to scale it in the w direction by just adding the scale node.
This will allow thickening of tiles that cannot be extruded ie: more organic shapes.
Again thanks
Barry
7777.703 In reply to 7777.698
Hello Michael.
Please, don't consider my previous post as a sharp criticism of your job!
You did wanderful and amazing things with Moi!!!
I have said this many many times on this and other forums :)
But I think that I'm not saying nothing strange when I say that current Moi's Api performance are unsatisfactory.
For example they are absolutely not comparable to Grasshopper performance.
This is very evident when you run complex NE nodes or even a bunch of middle-complex nodes that are chained together and you have simply to grad a slider.
Often you have to wait secs or dozens of secs to see changes, also on fast computer like my desktop PC.
Same operations in Grasshopper are many times faster.
I repeat, I think I'm not saying nothing "fake".
I hope I made myself clear.
Thanks.
Marco (mkdm)
EDITED: 2 Nov 2017 by MKDM
Show messages:  1-3  …  624-643  644-663  664-683  684-703  704-723  724-743  744-763  …  1844-1859
