 1-19  20-39  40-59  60-79  80-99  100-119  …  1840-1859
7777.60 In reply to 7777.59
Thanks for your reply. It contains all i need for Max's code.
And...in order to get Karsten's contribution also ?
Where to look for ?
Thanks both and nice day.
Marco.
7777.61 In reply to 7777.60
Hello Marco,
everything is in this thread:-)
Have a nice day
Karsten
7777.62 In reply to 7777.61
Ok Michael,
i'll search here more deeply, as soon as i can...
Thanks and good job.
Marco.
7777.63 In reply to 7777.56
Hello James,
combination with the curvature seems to work.Here is picture.
Have a nice day
Karsten
EDITED: 22 Dec 2017 by KMRQUS
7777.64 In reply to 7777.63
And a rendering of the bridgetest:-)
7777.65
Hello James, Hello Al,
@ James: based on Maxs Concat node I have made a node called Concat2 - it's possible to modify the input and output type by RMB. It's not perfect, because there are some lines in Max code, I don't understand. Nevertheless, it should work for your needs.
@ Al: At the moment Blend only can process 2 edges:-( and Yes, it's not ease to understand how it works, but it's not easy to find a solution for that. I think, the Moi API isn't made for that. In the next days I will have a look for the G0-option.
A nice day to all
Karsten
7777.66 In reply to 7777.65
Hi Karsten,
Thank you for concat2 node, it is exactly what I wanted.
I hope it is useful for others as well.
Cheers for that!
-James
7777.67
Hello Karsten
Thanks for the answer, and for the new Node Concatenate
I saw ,scrolling the page , that you posted in 11-April
a SubDiv- Node......
I ask you is compatible with the v.085 , who currently use...
if it were possible I would try it-
To be honest I have seen many more of your and James Node,
but I do not know if they are compatible.........
I would not create a chaos in my current Nodeeditor folder
best
al
7777.68 In reply to 7777.67
Hello Al,
don't try the old nodes, they won't work. I'm actually update the nodes to the version v0.85 - SubDiv also (very poor and rudimentary modeling). I had a look to the Blend node for G0 - means point continuity - means Loft between two edges;-)
Have a nice day
Karsten
7777.69 In reply to 7777.68
Hi Karsten
Thank you very much,
looking forward your updated Blend
good work
Best
al
7777.70
Hi Karsten and Friends
You post this exercise for deepening the Node Blend ,
very important to me, together with Fillet....
Karsten, did You may revise Node BrepNameSubObjects , when you have the opportunity to do so ?
in such a way that it can yield back the selected geometry
in the form of Output can then be used as Input for other Feature
type,Curve, Surf etc. etc. for tools Loft, Extrude etc etc...
Moreover I am absolutely of the opinion that range to maintain the links with
other reactions should necessarily have two inputs
Start and End domain ...
we hope that some of you experts can satisfy
my desire
Thanks for everything and have a good weekend to all
Best
al
Size: 239.9 KB, Downloaded: 248 times, Dimensions: 1920x1080px
7777.71 In reply to 7777.70
Hello Al,
If I get you right, you want to extract geometry from a nodes output e.g. a face or a edge to use it as an input for a e.g. sweep. I thought about it already and I think it is possible.
Here I didn't get you, please explain your idea in more detail.
At the moment I try to make getCrvSFrame and Sweep multiprocess ready. I also made an update/addition to the point node - If you preselect points of a given geometry and create now the point node you have all coordinates evaluated in it. e.g.: Switch on the controlpoints of a surface, select them --> copy/paste and let them selected - go to the node editor and create a new point node, you will have a independent copy of them inside the node. I don't know what it is good for, but I'm sure that someone will have an idea for that;-)
Have a nice weekend
Karsten
p.s.: I'm not an expert Motto: I'm glad I'm crazy, it keeps me trying! -Iggy Pop-
7777.72 In reply to 7777.70
Hi Al,
Start and End domain ...<<
Unless I have misunderstood you; Karsten's Concat2 node already satisfies this requirement.
Hope this helps
-James
7777.73 In reply to 7777.71
Hi Karsten,
>>I also made an update/addition to the point node<<>>I don't know what it is good for, but I'm sure that someone will have an idea for that<<
I think it would be very useful if analysis of distances between these points could be determined,
and it's results: absolute dist, x dist, y dis, z list, be used as inputs into other nodes.
Michael's CustomDistance script is only a few lines of code. Is this be something that
could be reworked as node with relative ease?
Just a thought
-James
7777.74
Hello friends
I want to share this exercise on using fillet
I hope this will be usefull for someone .......
<James>
I understood what you want to tell me how to use
Concatenate2 , You're right it works ....
I agree that we should do a Node Distance and
I suggest , also ;
Vector and Evalutate Curves (Ref. Grasshopper)
I think you all know ....
It could draw a line from one point to one direction
with a given distance and you could use Vector also
in Extrusions , and other applications ....
I know it's hard work, but someone has to do it ! ! ! !
<Karsent>
about your madness, I assure you
I'm not joking to say I'm not less crazy
and I'm happy as well
Best
al
Size: 323.8 KB, Downloaded: 223 times, Dimensions: 1680x1050px
7777.75 In reply to 7777.74
Hello Al,
thanks for sharing your tests. Beware of the fillet factory - it's a killer (Moi-crash) that I can't tame at the moment!
EEhhhm - I'm not. I never used Rhino and so I'm not familiar with Grasshopper. I know nearly nothing about it. Neither the functionality, nor the workflow. I saw one very interesting video and one very long and boring, where someone was clicking hundreds of buttons and options, until I was sleeping.
So what do you want to evaluate at curves?
Am I right about vectors, that you want it as inputs for a direction for e.g. lines, or extrusions ( + input of the length)?
Have a nice day
Karsten
7777.76 In reply to 7777.75
Hi Karsten , many thanks...
EvalutateCurves is the ability to insert one or more points
on a curve, and to have as output, the point, the frame
oriented on point into a curve;
therefore a "blend "between your Path_Array and GetCvrS frame
In Extrusions Node you could use the Vector
for direction plus a distance, and , optionally possibly to
draft on the faces-
About Grasshopper, I think you have been Unfortunate to watch the Video ! ! !
Grasshopper , in my opinion , is the First and I still unbeaten program for
Parametric modeling Nodal-
The program is full of fans, and believe me, ABSOLUTELY worth it for you to give a view to the Forum
http://www.grasshopper3d.com
and the impressive number of plug-ins dedicated to it
http://www.food4rhino.com
I think you should perhaps get some inspiration
from the big old GH-
In any case, I am attaching some picture of how are the nodes
in Grasshopper related to Evalutate Curves and output Vector , and Curve length
Good work, and have a good day
Best
al
Size: 446.4 KB, Downloaded: 198 times, Dimensions: 1680x1050px
Size: 458.9 KB, Downloaded: 168 times, Dimensions: 1680x1050px
Size: 455.8 KB, Downloaded: 179 times, Dimensions: 1680x1050px
7777.77
Hi Friend
I send a hard test on the use of Fillet,
despite all the doubts of Karsten,
it seems quite powerful,
only one clarification ,
>Karsten < could we add a link to
Knob or Slide, into Fillet Node?
See attached Picture-
Best to all
al
Size: 326.2 KB, Downloaded: 257 times, Dimensions: 1680x1050px
Size: 341.5 KB, Downloaded: 243 times, Dimensions: 1680x1050px
7777.78 In reply to 7777.77
Hello Al,
I have forgotten to change from number to numarray for the input in fillet node. In addition I thought and I still think about your suggestions for the eval Curve. At the moment you can make also a workaround for that with the given nodes. I will add also an update button for the fillet next time. At the moment I rearrange the the nodes to the menuitems, and I hope that old nodefile won't be dirty.
Have a nice weekend
Karsten
p.s.: Cool result!
EDITED: 6 Mar 2019 by KMRQUS
7777.79 In reply to 7777.78
Hello Al and Karsten and good morning,
I'm running latest Project Elephant (0_85mod) and I downloaded your latest construct2.js file.
When I run the" pa_al.nod" file I get the error displayed by attached image.
What's missing in my Elephant installation ?
Size: 49.1 KB, Downloaded: 171 times, Dimensions: 536x480px
Show messages:  1-19  20-39  40-59  60-79  80-99  100-119  120-139  …  1840-1859
