 1-13  …  554-573  574-593  594-613  614-633  634-653  …  1854-1859
7777.594 In reply to 7777.593
Hi Mike,
Use Basic/Math node with formula: "round(a)"
to round to near integer,
or floor(a) to round down
or ceil(a) to round up
Hope this helps
EDITED: 7 Oct 2017 by JFH
7777.595 In reply to 7777.594
Thanks!!!
7777.596 In reply to 7777.592
Hello James,
it will take a while until the node will work. At the moment I have some bugs and I'm not a programmer. JavaScript isn't easy to debug. I have to find a solution for fast convergence and a good criterium for equilibrium. Sometimes the algorythm blows the mesh into space. A display after every step won't work, but I don't know why - it would help to understand what's going on - and would be an eye catcher. I don't want to ask the experts, because they have better things to do (v4, Elephants, additional interfaces ...). What to give to the output and which format is also not definded - at the end we want to do something with the result.
So - the winter comes here and that will help to focus to such things.
Have a nice day
Karsten
7777.597 In reply to 7777.590
Hello Barry,
here is another example that demostrates the workflow. If it isn't useful for you you can maybe relax with it.
Have a nice day
Karsten
7777.598 In reply to 7777.597
Hi Karsten,
thanks it is relaxing however the node workings are beyond me.
I have tried to create an if/else node but it does not output when it reaches 100.
Could you have a look please if only for your entertainment.
I did try to enter it within the formula section in the maths node but no go.
As they say a little knowledge is dangerous thing.
Again many thanks
Barry
EDITED: 30 Jan 2021 by BARRY-H
7777.599 In reply to 7777.598
Hello Barry,
to understand the nodefile it is neccesary to think in positions of your objects. Then select the matching positions of your objects with the idxSelect nodes -controlled with the Quartz node.
Thats all.
I will have a look to your idea and try to understand it, but not today, it's late in the evening and I had some beer while watching TV(Soccer - Worldchampionship qualifing:-).
So have a nice evening
Karsten
7777.600 In reply to 7777.598
Hello Barry,
you don't Need a new node for that - have a look to the example. Compare and split will do that what you want. Have also a look to the RMB on split.
Have a nice day
Karsten
7777.601 In reply to 7777.600
Hi Karsten,
thanks will experiment with it.
Just out of interest could you explain why when using my if/else node it did not work when value of 'a' was 100 or over.
It's set to if (a>b) {out = (a-b)} else {out = 0}
I know it's my coding and inexperience but it will help my learning curve.
Many thanks
Barry
7777.602 In reply to 7777.601
Hello Barry,
your variables a and b are Arrays! If you want to compare elements of the arrays you have to Access the single elements with e.g. a[5]<b[0].
What the result of a<b is? I don't know. The this.properties.mode things are only useful for the multiprocess functionality Max implemented.
I think you have to implement a multiprocess function (Standard Long) or do it manually when you only want to compare all elements of the "a" Array with one single value of "b" (b[0].
for (var i=0; i<a.length;i++) if(a[i]<b[0]) doSomething();
I hope that helps for further steps.
Have a nice day
Karsten
p.s.: out is also an Array - so use out.push(a[0]-b[0]);-)
EDITED: 9 Oct 2017 by KMRQUS
7777.603
Hello Friends
Continuing exploring Minimal Surfaces,
in particular of the Scherk Singly Periodic
and the possibility of aggregating of the base module,
particularly in the most popular Saddle Tower,
I would like to share with you this interesting one
transformation...
a Twisted Torus of the Basic Saddle (Low Poly)
with the possibility of increasing the branches of the tower itself.....
file at this link:
http://www.mediafire.com/file/sf3u5jrbc9dc5jc/Twisted_Scherk_witn_n%C3%82%C2%B0_branch.rar
Good depth.......
Have a nice evening to all
al
7777.604 In reply to 7777.603
Hi AL!
I have a problem with all the nodes that you have posted lately.
None of them work with the latest 0.97.... version of NE.
Every time I load one of your node file, the "Run" button of NE is always disabled.
Instead if, for example, I create a new node or load one of the latest Max's node (Macro.nod for example) all works fine.
Please check this screencapture, it is relative to the node you posted at http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.603
Maybe I'm missing something...
This is the content of my "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions"
and "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions\libs" folders
And this is the code I have into index.html file of NE :
loadScripts('core','lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes','macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs','*');
loadScripts('nodes/extensions','*');
loadScripts('core','init, ext.*');
Could you help me ?
Ciao!
7777.605
Hi Marco
the file posted,I did it with 0.96 Version....
I downloaded Version 0.97, but I'm not using it yet
ciao
al
7777.606 In reply to 7777.605
Ok Al.
I will try with 0.96.
Ciao!
7777.607 In reply to 7777.606
Hi Marco
There are missed nodes in your nod-file.
Check all nodes with red title
7777.608 In reply to 7777.607
Thanks a lot Max for the tip!
Ciao.
7777.609 In reply to 7777.607
Ok. Solved!
I had the wrong version of "transform2.js".
7777.610 In reply to 7777.609
Hello Marco,
it's fine that you figured out the Problem. I've posted some updates in single files, so it's difficult to start, when you not followed the complete Progress. But I don't know if it is useful to post a complete package when I only changed or added one single node. Esspecially when also new Versions from Max comming up. Sorry for that.
Have a nice day
Karsten
7777.611 In reply to 7777.610
Hi Karsten.
Thanks for the reply
@You : "...But I don't know if it is useful to post a complete package when I only changed or added one single node..."
Well...
As I said many times, I have my very personal point of view, a point of view of a software developer.
IMHO, in order to avoid version madness and headache, this is the best methods to keep all the users up to date
about "extensions" nodes made by us or by anyone other than Max :
I mean, the Max's way.
I think this is the best solution.
That is, having an online repository, like http://moi.maxsm.net/nodeeditor/, where all users can download always the very latest version of some particular
"extensions" for NE written by some developer.
This is a huge benefit, because a user doesn't have to wonder "Hmmm...is this the correct version of the script ? I remember that someone here and there
said that at line 130 of the code I have to put "x = x +1" and not "x = x -1".
I think that now is the time to definitively stop this strange situation :)
A "user" of a script or node must only download and overwrite all the files without wonder what's inside them.
This is an aspect "TOTALLY" delegated to the developer of the node.
Please, let's stop version madness :)
Thanks a lot and have a nice day.
Ciao!
Marco (mkdm)
EDITED: 11 Oct 2017 by MKDM
7777.612 In reply to 7777.611
P.S.
When I say "..That is, having an online repository, like http://moi.maxsm.net/nodeeditor/, where all users can download...",
I mean that "each" developer could have a personal online repository where he can upload all his scripts/nodes/plugins,
without the need to have a global repository for all Moi's users.
ASAP I'm going to create my personal online repository with all the scripts/plugins/nodes/ I have written so far or I hope to write in the near future :)
Have a nice day.
7777.613 In reply to 7777.611
Hello Marco,
the thread is called -"Nodebundle for playing with Nodes" with Focus on playing. I left the "Parametric design in Moi" thread with this stuff, because there were some critics - ok. Only a few People really playing with the additions. I wrote some nodes, because some of them requested a special functionallity. I have no masterplan for developing that stuff. Max has developed some alternative and improoved nodes - so some of my nodes are obsolete now. I haven't a Homepage or a repository. I tried to start a documentation on Michaels Homepage. But a wiki System isn't a one man Show! From time to time I get some critics now here, that a posted nodefile isn't working and I try to help. I also try to answer question how to solve a particular Problem while using the nodeeditor. I sometimes ask for intuitive names for nodes, with some execptions, I didn't get answers. Sometimes I have the Feeling that some guys here are not amused that someone is writing nodes here -anyway.
Nevertheless,
have a nice day
Karsten
Show messages:  1-13  …  534-553  554-573  574-593  594-613  614-633  634-653  654-673  …  1854-1859
