 1-13  …  534-553  554-573  574-593  594-613  614-633  …  1854-1859
7777.574
Good Morning James ,
Cool result ........
Bravo , Your Macro work fine-
best
al
7777.575 In reply to 7777.573
Hi James.
Thanks a lot! This is a very useful node.
Very useful for replicating an object over a surface with the help of a bunch of Max's node.
Bye.
7777.576
Hi James,
great work!
>>It is going to be very handy when we can share macros between projects
Today or tomorrow I'll release a new version with macros import-export support
7777.577
UPDATED: randomWrapNEW.nod attached
To run on new NE mod:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Hi All,
Here's an example for randomised pattern on a surface.
Macros certainly make node circuitry more elegant!
I can't wait to see what's Max's next great leap.
EDITED: 14 May 2019 by JFH
7777.578 In reply to 7777.577
Jelly-Fish nodes style! :)
Suggestion!
I suppose that can be adapted!
EDITED: 5 Oct 2017 by PILOU
7777.580 In reply to 7777.577
Hi James.
WOW! Amazing node!!
Thanks a lot.
7777.581
Hi Friends
I did my first Macro, thinking of creating something he could
simplify drawing work ...
In this case, we can create a circle for two points and radius
I think it works, at least to me it works
files at this link:
http://www.mediafire.com/file/deqjawbt6qn7077/M-_Circle_2pt%26radius.rar
Have a nice afternoon to all
al
7777.582
Hi Friends
this is my second Macro, a bit more complicated than the other,
returns a three-point circle or arc ;
how many interested people find the file at the following link:
http://www.mediafire.com/file/yz5hf7sfxmgvorh/Circle-Arch_to_3Pts.rar
Have a nice weekend to all
al
7777.583 In reply to 7777.582
Hi AL2000.
Thanks a lot for sharing!
Very complex nodes but very interesting for learning.
7777.584 In reply to 7777.577
Hello James,
Regarding your randomWrap7.nod
Your randomized pattern on a surface is both impressive and very interesting, particularly because it is seamless all the way around.
How might one create such a pattern on a plane and get the left and right matching to allow seamless tiling, at least laterally?
Suggestions welcome.
Many thanks,
-- MindSet
7777.585 In reply to 7777.584
Hello MindSet,
The pattern will inherently tile seamlessly regardless of orientation.
The only alteration to surfConvert macro necessary was to make polyline not closed.
At present this cannot be switched dynamically, otherwise I would build it into the macro.
See attached "randomWrapPlane.nod" file. I have shown 2 repeats of a 10x12 matrix, but you may change
to any combination.
RMB click of "Random" then select "Update" to refresh random pattern generation
to get desired result.
Have a great weekend
UPDATE: Mobius Wrap added: "randomWrapMobius.nod"
7777.586
Hello,
I want to share a draft or better a proof of concept for some new nodes. They work not stable, has bad performance and are critical to their parameters. So don't try to use it for creating something serious. I am at the beginning to understand the problem in detail. It's something for a boring rainy sunday.
A nice weekend to all
Karsten
EDITED: 6 Mar 2019 by KMRQUS
7777.587
Hi All,
I'm experimenting with animating a mechanism using the quartz node as the cycle actuator (time line).
Can anybody tell me how to have various start points for different movements .
As an example Quartz set to start at 0 and end at 250 how can I trip a start of a movement at 50 and stop at 200.
Any ideas
Barry
7777.588 In reply to 7777.587
Hello Barry,
start Quartz from 0 to 150 and add 50 with a math node? I don't really know what You want to do.
- Karsten
7777.589 In reply to 7777.587
Or something like that, if you want to connect different arrays with values?
7777.590 In reply to 7777.588
Hi. Karsten,
I'm using the quartz node instead of a slider to give my selections movement but as they do not all start at 0.
Some start moving at 0 and others maybe stationary till say 50 then move.
So if you think of the quartz node as a time line and it triggers movements at given points.
I was thinking an if/else node might be my answer ie: if (condition) {  block of code to be executed if the condition is true}
else { block of code to be executed if the condition is false}
Hope this clarifies what I'm trying to achieve.
Barry
7777.591 In reply to 7777.590
Hello Barry,
have a closer look to the posted b.nod file or have a look to that one - you can do that with that;-) maybe you can also use the compare node.
Karsten
7777.592 In reply to 7777.586
Hi Karsten,
formfinding node is very impressive. My dearest hope is that showers are forecast for tomorrow (your time) so that you may finesse the coding.At first, I had assumed that Moi was freezing when I tried you examples, but then when I finally saw the results, my heart leaped...truly truly inspiring stuff.
(I have dreamed the dreams of Frei Otto)
Great work!
7777.593
I'm trying to build a nod using the circular array node.
It appears that the node requires the count input to be an integer.
Is it possible to convert the output of a Math node from floating point to integer?
I've tried using (Int) in the Math function field but that doesn't seem to work.
Is there another way?
Mike.
Show messages:  1-13  …  514-533  534-553  554-573  574-593  594-613  614-633  634-653  …  1854-1859
