 1-19  …  500-519  520-539  540-559  560-579  580-599  …  1840-1859
Message 7777.540 deleted 28 Sep 2017 by JFH
7777.541 In reply to 7777.531
Very nice.
Mike.
7777.542
Hello friends
First of all thanks to Brain for approval my Work concerninn node. SuperToroid,
I'll try it with Super Cyclides, but it's not like that discounted the result .......
I continue exploring the Minimal Surfaces ,
now is the turn of Schoen FRD- module-
always molded in Low Poly-
For those interested find the file on this link:
https://www.mediafire.com/file/6su1mcy9urmdhy9/Schoen%20Minimal%20FRD.rar
Happy continuation at all
al
7777.543 In reply to 7777.542
Oh my goodness me.
That is so complex, Al.
Wonderful result.
Mike.
7777.544
Hello Friends
Now is the turn of another Minimal sur-Cattalan, beyond
to the canonical surface
I created a strip using the edges of the surface ..
how many interested people find the file at this link :
http://www.mediafire.com/file/zks994xy5sq326m/Catalan-_Minimal.rar
Have a nice day to all
al
PS ( many tanks Mike)
7777.545 In reply to 7777.544
Hi AL2000.
Does it work with the latest official version of P. Elephant that Max published some days ago ?
Thanks and have a nice day.
Bye.
Please post a simple screen of the GEOMETRIC RESULT! (animated image will be a must but a still image will be also sufficient)
(the node one also will be a must but the geometric is INDISPENSABLE for the reader of this thread! )
Here for example LinePoly by James http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.121
Geometric on the Top, node(s) on the Bottom
Complete version of the node LinePoly here in French! ;)
EDITED: 21 Sep 2017 by PILOU
7777.547 In reply to 7777.546
Hi Pilou, although it certainly is nice it also takes extra work to generate images like that. You just can't expect that every time someone shares some of their node work that they should be required to do even more additional work if they don't have a lot of time available or if they just don't happen to like to do those extra steps.
If you want to see what it does in a visual way, why not just download it and run it so you can see it right there on your own screen?
7777.548 In reply to 7777.544
Ok AL2000.
I have downloaded and I've seen that it works with latest version of P. Elephant.
Bye.
Hi everyone!
After a very long time I'm back to play with P. Elephant.
I forgot almost everything... :)
Just to make a warm lap I did this very simple "pseudo bolt" generator.
It works with latest version of P. Elephant (get it at http://moi.maxsm.net/nodeeditor/)
This is the .nod file : http://take.ms/auUrs
Check this video : http://take.ms/bBp3n
Bye!
7777.550 In reply to 7777.549
Hello Marco,
thanks for sharing the Video. It will help People to start with the nodeeditor - and the Project is it worth that more People use it.
Have a nice day
Karsten
7777.551 In reply to 7777.550
You're welcome!
I hope to find some spare times in the next days to translate my old PointArray utility nodes for the 0.94 version of Elephant.
But, as I said....I remember almost anything of Elephant :)
Bye.
7777.552 In reply to 7777.547
<< why not just download it and run it so you can see it right there on your own screen?
Sure but I suppose that a creator of node must run its node for test it! :)
So no more add work to reccord it with something like that...
http://blog.bahraniapps.com/gifcam/
and for a reader of the tread it's more easy to know what is the visual subject of something than darky words like
Minimal surface-Cattalan :)
7777.553 In reply to 7777.551
Hello Marco,
all additional nodes of v0.93 should work in V0.94 also - at the Moment I can't see changes in the internal function of the nodes - as Max mentioned it a while ago.
@Pilou: Sometimes it is more fascination to explore something with a Little suspense or a suprise, than to know the result at first.
So a nice day to all
Karsten
7777.554 In reply to 7777.553
Hi
@You : "...all additional nodes of v0.93 should work in V0.94 also.."
Thanks for the info.
The problem is that I wrote my utility nodes long time before v0.93 so I don't know is they work.
I have to check.
Bye.
7777.555 In reply to 7777.554
I consider all additional nodes as our little babies - regardless of their origin - so I've taken care of yours too;-) But nevertheless It's a Little bit difficult to check them all.
7777.556 In reply to 7777.555
@You : "...so I've taken care of yours too..."
Thanks a lot Karsten!
7777.557 In reply to 7777.553
<< Sometimes it is more fascination to explore something with a Little suspense or a suprise, than to know the result at first.
Sure ... but can be dangerous for emotive people! :)
7777.558 In reply to 7777.557
@You : "...Sure ... but can be dangerous for emotive people! :)..."
LOL :) :)
Ciao Pilou!
7777.559 In reply to 7777.552
It is more work though, that's another program that someone needs to download, install, and run.
I'm not saying it's a whole lot of work, it's true that it's only a small amount of extra work. But extra work and extra steps nonetheless.
When the purpose of the message is to share some node work with other "node enthusiasts" it's reasonable for them to just post the node files and expect that others that are interested in it will load it.
If it was in the gallery or in a reply to some other thread where the creator of the thread might not be familiar with the node editor then that's a different case. But here it's a thread specifically for node stuff.
Show messages:  1-19  …  480-499  500-519  520-539  540-559  560-579  580-599  600-619  …  1840-1859
