 1-4  …  485-504  505-524  525-544  545-564  565-584  …  1845-1859
Message 7777.525 deleted 23 Feb 2019 by JFH
7777.526 In reply to 7777.525
Nice interlacing!
7777.527 In reply to 7777.522
Re: please check also the RMB on the idxSelect node - you can also Switch it to the selection of values in numarrays or geometry of objectlists.
Thanks, Karsten, for pointing that out.
Mike.
7777.528 In reply to 7777.523
Amazing.
I won't be tackling anything like that for a very long time.
Mike.
7777.529
Hi All,
UPDATED: nod file attached
This is still a work in progress,
but as a teaser I have attached screen grab
of a parametric brick wall.
I'll get back to it on the weekend.
EDITED: 14 May 2019 by JFH
Size: 106.5 KB, Downloaded: 88 times, Dimensions: 640x560px
Message 7777.530 deleted 14 Sep 2017 by JFH
7777.531
Hello All
I continue exploring the Super Forms,
after Superellipse ,
now, it's the turn of SuperToroid-
By varying some parameters we get many different
Forms, really interesting, based on possible adaptations
of the Ring or Path ,and the Circle or Profile -
How many interested people find the file:https:
//www.mediafire.com/file/8saajmc34cx0ku6/Super%20Toroid.rar
Have a nice week and to all
al
7777.532 In reply to 7777.531
The node is very cool, AL2000!
I've recently encountered papers on super cyclides.
7777.533 In reply to 7777.524
Hi Karsten,
I am trying to take an array of values (curve length in my particular case)
and arrange them in order ascending &/or descending. In this way,
first and last values can be idxSelect to give range domain (num0,numN)
Can this be done with "logic/compare" node or is there need for a “sort” node?
(i understand that javascript sort() method specifically manipulates strings ,
but can be made to sort numerical values in conjunction with compare function)
Also I have be watching online grasshopper tutorials in an effort to vary spacing of points on a curve dependant degree of curvature.
Anyway I came across the “Remap” node in grasshopper, that will reassign a num
array to range between inputted domain. I remembered that you had contributed "infos/reMap" node (2 as it turns out). Unless I am mistaken they replicate the function of Max’s Basic/Interp node. If you were so inclined, I think there would be value in rewriting your node to emulate the function of grasshopper’s namesake.
This is not so much a request, more a suggestion of something that you may like to do so that your old nodes are not ignored like redheaded step-children.
Have a great weekend
Please put some images result of all these news nodes! :)
Message 7777.535 deleted 16 Sep 2017 by JFH
Message 7777.536 deleted 15 Sep 2017 by JFH
7777.537 In reply to 7777.533
Hello James,
I'm not familar with GH. So I don't know what it does in GH. The reMap in the nodeeditor interpolates only given values with a equdistant parameter [0,1,..,n] to a natural spline function. The output gives a number of values lying on that function. I don't think that the GH node has the same meaning!? Remap2 makes the same, but on the RMB you can switch to points as an input. Here the node makes the same however for the 3 coordinates.
The Logic nodes written by me are obsolete, because Max has decided that numarray instead of boolean should be used. Unfortunately all nodes are in the same menu. Nevertheless I will update my nodes some day. A sort node is possible, but I didn't understand your intention already. We need an input for the values e.g. a numarray and a second input for numarray, pointarrays or an object list with a corresponding output for the sorted elements- or only an output with the ordered indices of the input and use later idxSelect?
<<<Also I have be watching online grasshopper tutorials in an effort to vary spacing of points on a curve dependant degree of curvature.
That is also possible - I have programmed already a curvature analysis, but it's a lot of work to recreate a new curve given by the result. I think it's more useful to have a look to the script rebuild and wrap it to a node.
Have a nice weekend
Karsten
EDITED: 16 Sep 2017 by KMRQUS
Message 7777.538 deleted 23 Feb 2019 by JFH
<< I'm not sure if this is what you mean,
<< or indeed even if you were addressing me.
an image like an ellipsoïd, torus or any object result of a use node(s)!
for give desire to use (or not) these or that node(s)! ;)
Image of node itself is the technical part!
Practical only if you want use this node for made the image(s) above!
EDITED: 16 Sep 2017 by PILOU
Message 7777.540 deleted 28 Sep 2017 by JFH
7777.541 In reply to 7777.531
Very nice.
Mike.
7777.542
Hello friends
First of all thanks to Brain for approval my Work concerninn node. SuperToroid,
I'll try it with Super Cyclides, but it's not like that discounted the result .......
I continue exploring the Minimal Surfaces ,
now is the turn of Schoen FRD- module-
always molded in Low Poly-
For those interested find the file on this link:
https://www.mediafire.com/file/6su1mcy9urmdhy9/Schoen%20Minimal%20FRD.rar
Happy continuation at all
al
7777.543 In reply to 7777.542
Oh my goodness me.
That is so complex, Al.
Wonderful result.
Mike.
7777.544
Hello Friends
Now is the turn of another Minimal sur-Cattalan, beyond
to the canonical surface
I created a strip using the edges of the surface ..
how many interested people find the file at this link :
http://www.mediafire.com/file/zks994xy5sq326m/Catalan-_Minimal.rar
Have a nice day to all
al
PS ( many tanks Mike)
Show messages:  1-4  …  465-484  485-504  505-524  525-544  545-564  565-584  585-604  …  1845-1859
