 1-18  …  459-478  479-498  499-518  519-538  539-558  …  1859
7777.499
Hi Karsten and Friends
Well done Karsten......
The new Twist Nod works fine,
coupled with Flow Nod by interesting results, the
Those interested find this link ,my test:http://www.mediafire.com/file/vuuf2yk4d35c5pj/Twist_Test.rar
Have a nice day to all
al
7777.500 In reply to 7777.498
Thanks, James.
Hopefully in time the entry fields will be fully operational thus removing a source of confusion for those wanting to write a stripped down nod.
In the meanwhile the work around is, as you pointed out, one that has benefits.
Mike.
7777.501 In reply to 7777.497
Brian, as an exercise I've made a nod based on the 4 variants that you posted for Hyperbolic Paraboloids.
The nod uses the same variable as you posted using discrete inputs to Points/MathPts as James advised and displays all four variants together.
The slider is limited to one decimal place so to get a value of A of 1.618 (as you had) it is necessary the disconnect the slider and to enter 1.618 directly into the A input field in Points/MathPts - which does work as expected (B and C don't).
I did think of making the spacing of the outputs on the screen automatic but concluded that it would make a very confusing nod so I opted to make the spacing manually adjustable via a knob.
The output is 4 solids through the use of Construct/Extrude with a distance of 0.01mm.
Please check that the outputs look right to you.
Thanks, Mike.
7777.502 In reply to 7777.498
Hi, James.
Seems to me that the A input field does work in Points/MathPts - as long as there is nothing connected to the A, uh, input button.
Mike.
7777.503 In reply to 7777.501
Visually, the node looks good.
In the Info panel, the slider "digits" can be increased. The slider can display at most 2 decimal digits, in the current range.
So digits could be increased to 3, but only 2 are displayed in the slider.
It looks like the slider shows as most 2 decimal digits, with the 3rd decimal rounded to two decimal digits.
It is possible to easily edit the interface.js file so as to display more decimal digits in the slider, but I will leave it alone.
There are range limitations to the # of digits displayed, as well.
EDITED: 31 Aug 2017 by BEMFARMER
7777.504
A trivial 'real world' nod to produce a printable circular funnel.
As an example I've chosen sizes to match a funnel I made some years ago to facilitate loading peppercorns into a pepper grinder.
7777.505 In reply to 7777.504
Welcome to the Elephant
World...... Mike.
Perhaps, for such a simple object, I think that,
start with a profile, then create a revolution
is the best method ....
Maybe many less Nod ???? ...
In every case appreciable
best
al
7777.506 In reply to 7777.504
Hello Mike,
it makes me happy to see the different aspects of the application. Especially when the results will end in real world parts. Methods and complexity will automatically increase. And used in the right place, productivity will also increase:-)
Have a nice day
Karsten
7777.507 In reply to 7777.505
Thanks for the suggestion, Al, I'll think about it.
Mike.
7777.508 In reply to 7777.506
Thanks, Karsten. I have plans to increase complexity by making a nod for a 'universal' funnel. That is, a funnel that has square round elements.
Mike.
7777.509 In reply to 7777.506
Hi Karsten,
I am happy to see you back on the forum & hope you are well.
I wonder if you wanted to have a play around with something node-wise,
if you could have a look at extending your text node, so that it could be utilised
for numbering pt arrays as per my earlier posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.448
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.453
This would be a real boon for the more complex indexing of arrays.
If you could, I would be forever in your debt!
7777.510
A more ambitious - and complex - funnel nod. The 'universal funnel'.
This nod is based on rounded rectangles so the top, middle and bottom sections can be rectangular, square or round.
Mike.
7777.511 In reply to 7777.509
Hello James,
it is a little bit complicated to integrate the functionality into one node, possible, but not useful in my opinion - so I made a additional one. Please test it and give a feedback.
Have a nice day
EDITED: 6 Mar 2019 by KMRQUS
7777.512 In reply to 7777.511
Hi, Karsten, looks wonderfully good to me.
Tiny, tiny typo in both the Numbering and Text nodes you have the label 'Bolt' - should of course be 'Bold'.
Mike.
7777.513
Another perhaps useful nod. Bottle square or round.nod
The output is five solids. I left them separate rather than using 'Union' inside the nod as I thought that the output would be slightly more convenient in that form, though I'm having second thoughts as I type this!
Below shows that sort of bottles that can be produced with the nod. It will not generate oval bottles.
NOTE that the neck is plain - required threads or bead have to be generated separately.
Mike.
7777.514 In reply to 7777.513
Hello Mike,
it looks like you're having fun:-)
and thank you for your note. I'm not a native speaker, so any improvement is welcome. Here is a corrected version.
thanks and have a nice day
Karsten
Message 7777.515 deleted 23 Feb 2019 by JFH
7777.516 In reply to 7777.515
Thanks for the warning, James.
Mike.
7777.517
Hi, guys, is there a simple way of getting the x,y,z values of the last point calculated by MathPts?
Mike.
7777.518 In reply to 7777.517
Hi Mike,
>> x,y,z values of the last point calculated by MathPts <<
MathPts "f(uv)"input into "InPts" ArrayExt/idxSelect node
Multiply Unum X Vnum minus 1 for input into "idx" on ArrayExt/idxSelect node
then "Out" input into Points2/splitPt to get x,y,z values.
An alternative is to use ArrayExt/ArrayFlipper to idSelect with index of 0
If this does not make sense, upload your file & I modify it
Show messages:  1-18  …  439-458  459-478  479-498  499-518  519-538  539-558  559-578  …  1859
