 1-14  …  415-434  435-454  455-474  475-494  495-514  …  1855-1859
7777.455 In reply to 7777.454
Hello Karsten,
Hope everything works out OK
All the best
EDITED: 20 Jun 2017 by JFH
7777.456
Hello to All
Continue my research on Minimal Surf:
Is the turn of the Minimal Periodic Doubly Scherk,
Modeled Low Poly-
Fairly simple but engaging, at least I think
link :http://www.mediafire.com/file/7j9enkguvsvaxe5/Doubly_Scherk-Minimal_Surf.rar
Have a nice day to all
al
7777.457
Hi All,
Attached is my latest experiment with nodeeditor showing
parametric depth control of flowed geometry over a surface substrate.
BE WARNED: drawing to screen may be up to half a minute.
Have a great weekend
P.S. simple 2nd example added
EDITED: 14 May 2019 by JFH
Size: 83.6 KB, Downloaded: 85 times, Dimensions: 640x504px
7777.458 In reply to 7777.457
Remember my doddling! :)
Message 7777.459 deleted 2 Jul 2017 by JFH
7777.460
Hi All,
A simple exercise tessellating surface with tile transformation.
p.s. UPDATED
Message 7777.461 deleted 12 May 2019 by JFH
7777.462
Any chance Advanced NODE BUNDLE users putting together some YouTUBE demos of their NODES on work methods to give beginners a leg up in the process.
7777.463
Hi to All
An experimental MathSurf tasseling
Stereo Sphere
link :https://www.mediafire.com/?xni7d1ima5h4aio
Have a nice Week -end to all
al
7777.464
Hi Friends
I continue exploring the Minimal Surfaces
Scherk B- Math definition , and low poly modeling
with different assemblies.
link :http://www.mediafire.com/file/x2lur6vde6cj4xq/Scherk-B.rar
al
7777.465
Hi Friends
A Minimal Surf. transition.....
From Catenoid to Helicoid
controlled by a slider
link:
http://www.mediafire.com/file/d38g2c6hvr8m7d6/Catenoid_Trasformation.rar
Have a nice Week-end to all
al
7777.466
Hi Friends
Another test ;
Minimal Surface ,Low Poly Modeling,
Gyroid
link :
http://www.mediafire.com/file/bs8p41ocdhaho19/Gyroid.rar
best
al
7777.467 In reply to 7777.466
(In Italian)
Ciao AL2000!
Visto quello che riesci a fare con il Project Elephant mi chiedo cosa riusciresti a tirar fuori da Grasshopper per Rhino !!
W la matematica (questa sconosciuta....per me) !
(In English)
Hi AL2000!
Considering what you are able to do with Project Elephant I'm wondering what you can make from Grasshopper for Rhino !!
Maths forever (this stranger....for me) !
Bye.
7777.468
(in Italian)
Ciao Marco
in Grasshopper riesco a tirar fuori molto di più ,
ma il merito è del programma... non mio-
Ci sono una quantità di strumenti disponibili di default nel programma
che fa spavento...
inoltre , ci sono tutta una serie di plug , realizzate gratuitamente da terzi
"amatori" , dedicate ai piu svariati ambiti, prima tra tutte Kangaroo , Wb Mesh,etc. etc
e tante altre
Vale la pena che tu dia un occhiata alle potenzialità del programma
credimi , ne vale la pena-
Però , c'e anche da dire che Elephant , per alcuni aspetti ,
e secondo me innovativo , sopratutto per quanto riguarda il funzionamento
di alcuni Nodi , Math Point , SubD ad esempio con il trattamento delle
Poly Surf come fossero Mesh, etc etc
Tutto merito del Geniale Max-
Ti ringrazio per le belle parole , e ti esorto comunque a scoprire al più presto anche Grasshopper
Buona Giornata
al
(in English)
Hello Marco
In Grasshopper I can get out a lot more,
But the merit is the program ... not mine
There are a number of tools available by default from the program
Scary ...
Moreover, there are a whole number of plugs, made free of charge by third parties
"Amateurs", dedicated to the most varied areas, first of all Kangaroo, Wb Mesh, etc. etc
And many more
It is worthy to give a hint to the potential of the program
Believe me, it's worth it-
However, there is also to be said that Elephant in some respects
And in my opinion innovative in terms of operation
Some Nodes, Math Point, subD for example and the treatment of
Poly surf as if they were meshes, etc. etc
All the credit to the Max's Genius-
I thank you, and exhort you to discover Grasshopper
Have a nice day
al
7777.469 In reply to 7777.468
Grazie AL.
Cercheró di tornare a dare un'occhiata prima o poi anche a Grasshopper (Ho Rhino da 5 anni e da circa due lo apro solo per scaricare gli update della WIP 6 :)
Buona giornata.
7777.470
Hyperbolic functions, such as sinh and cosh, do not seem to available in nodeeditor v .93.
Are they likely to be available in the future or does the litegraph library not support them?
Mike.
7777.471 In reply to 7777.470
Hi Mike,
Try:
cosh(u) = ( exp(u) + exp(-u) ) /2
sinh(u) = ( exp(u) - exp(-u) ) / 2
Brian
7777.472 In reply to 7777.471
Thanks, Brian.
Of course - it worked!
Nice work around.
Mike.
7777.473
Hyperbolic Helicoid. HyperbolicHelicoid
Thanks to Brian's formulaic equivalents to sinh and cosh I've got this working.
HyperbolicHelicoid.nod produces a surface which is easily converted into a solid by executing Construct/Offset/Shell using Thickness 0.01mm (for default .nod values) and Direction: Normal
Cool: with image + Nod we can decide if yes or no we want load the tool! ;)
Maybe useful for pasta makers ?
Show messages:  1-14  …  395-414  415-434  435-454  455-474  475-494  495-514  515-534  …  1855-1859
