 1-7  …  408-427  428-447  448-467  468-487  488-507  …  1848-1859
Message 7777.448 deleted 23 Feb 2019 by JFH
Sorry but how do you obtain the node Text ?
In the construct2.js ? I suppose in folder nodes ?
But curriously it don't appear as show in my previous post!
Very mysterious!
Edit : find it!
I have put twice the file construct2.js : in folder nodes & folder extensions !
EDITED: 16 Jun 2017 by PILOU
Message 7777.450 deleted 17 Jun 2017 by JFH
7777.451 In reply to 7777.450
Thanks now all is fine!
I have put the file in two folders that makes the mess! :)
7777.452
Hi Karsten
The text node is fine, I wanted to ask you,
following James's post, if it's in the future
It is possible to provide all Node Points, even those
mPath, of an output that can be read
from our Text node, in such a way as to return
"Reading "the list of item?
It would be a great advance for the "manipulation"
some data......
Excuse me, if I tedium with these my constant
requests ...
But it is for the goodness of "Elephant"
Have a nice day
al
7777.453 In reply to 7777.452
Hi Karsten,
Following on from my last post, I realise that it maybe confusing to have a text input if it can only accept num array inputs.
As an alternative approach, I have attached image of how node maybe extended to serve as a counter of points in an array.
In the absence of a numbered labelling of points, I have relied on cloning to points spheres of variable sizes to make the sequencing legible. Obviously this method is grossly inadequate. I hope you can see the value of the suggested improvement.
EDITED: 20 Jun 2017 by JFH
7777.454 In reply to 7777.453
Hello James, Hello Al,
Yep - I think it is possible, but I don't have the time at the Moment - some private Problems:-(
Have a nice day
Karsten
7777.455 In reply to 7777.454
Hello Karsten,
Hope everything works out OK
All the best
7777.456
Hello to All
Continue my research on Minimal Surf:
Is the turn of the Minimal Periodic Doubly Scherk,
Modeled Low Poly-
Fairly simple but engaging, at least I think
link :http://www.mediafire.com/file/7j9enkguvsvaxe5/Doubly_Scherk-Minimal_Surf.rar
Have a nice day to all
al
7777.457
Hi All,
Attached is my latest experiment with nodeeditor showing
parametric depth control of flowed geometry over a surface substrate.
BE WARNED: drawing to screen may be up to half a minute.
Have a great weekend
P.S. simple 2nd example added
EDITED: 14 May 2019 by JFH
Size: 83.6 KB, Downloaded: 61 times, Dimensions: 640x504px
7777.458 In reply to 7777.457
Remember my doddling! :)
Message 7777.459 deleted 2 Jul 2017 by JFH
7777.460
Hi All,
A simple exercise tessellating surface with tile transformation.
p.s. UPDATED
Message 7777.461 deleted 12 May 2019 by JFH
7777.462
Any chance Advanced NODE BUNDLE users putting together some YouTUBE demos of their NODES on work methods to give beginners a leg up in the process.
7777.463
Hi to All
An experimental MathSurf tasseling
Stereo Sphere
link :https://www.mediafire.com/?xni7d1ima5h4aio
Have a nice Week -end to all
al
7777.464
Hi Friends
I continue exploring the Minimal Surfaces
Scherk B- Math definition , and low poly modeling
with different assemblies.
link :http://www.mediafire.com/file/x2lur6vde6cj4xq/Scherk-B.rar
al
7777.465
Hi Friends
A Minimal Surf. transition.....
From Catenoid to Helicoid
controlled by a slider
link:
http://www.mediafire.com/file/d38g2c6hvr8m7d6/Catenoid_Trasformation.rar
Have a nice Week-end to all
al
7777.466
Hi Friends
Another test ;
Minimal Surface ,Low Poly Modeling,
Gyroid
link :
http://www.mediafire.com/file/bs8p41ocdhaho19/Gyroid.rar
best
al
7777.467 In reply to 7777.466
(In Italian)
Ciao AL2000!
Visto quello che riesci a fare con il Project Elephant mi chiedo cosa riusciresti a tirar fuori da Grasshopper per Rhino !!
W la matematica (questa sconosciuta....per me) !
(In English)
Hi AL2000!
Considering what you are able to do with Project Elephant I'm wondering what you can make from Grasshopper for Rhino !!
Maths forever (this stranger....for me) !
Bye.
Show messages:  1-7  …  388-407  408-427  428-447  448-467  468-487  488-507  508-527  …  1848-1859
