 1-15  …  396-415  416-435  436-455  456-475  476-495  …  1856-1859
7777.436 In reply to 7777.435
Hello Barry,
for animations the Quartz node is the right one. Regarding to your new node:
There is variable in the input and output object called "label". If you set this variable to your input value it should work.
Or post your file with new node you want to create, that I can have a look.
In the attachment you will find a very experimental animation proposal. I don't know if storing pictures with the camera node under windows work.
The camera node saves single pictures that can be glued with mencoder or ffmpeg to a video.
Have a nice day
Karsten
7777.437 In reply to 7777.435
There was a node called Watch. I'll have to look for it...
Message 7777.438 deleted 15 Jun 2019 by JFH
7777.439
Hello,
here is a draft for a simple helix node, that uses the standard Moi factory.
A nice day to all
Karsten
7777.440 In reply to 7777.437
The old Basic/Watch node, from an old version of nodeeditor, does not work properly in the latest version.
7777.441 In reply to 7777.440
Hello Brian,
@Brian: that was a good info!
@Barry: I had a look and made some changes to show how the labeling works.
A nice day to all
Karsten
7777.442 In reply to 7777.441
Hi Karsten,
thanks for the watch node it will be useful when checking maths function outputs.
I can not run your animation not sure if it's the version of node editor I'm running or not ?
The thing I am looking for is a sequence type event ie: object 'A' moves then object 'B' etc
So basically 'A' at some point in it's move cycle will trigger 'B' to start and so on.
The thing that got my interest was the Bottle Feed Screw. I animated it in Blender using the
time line but could not do a Variable Pitch Screw that way so I used the node editor with the
quartz node and it worked great.
I'm off on holiday with a copy of Javascript for Dummies so you may hear from me again.
Barry
7777.443
Hi Friends
First of all . many thanks Karsten and James,
for the precise explanations and examples,
on my part I will try to penetrate, as the Poet says
"this dark forest"
I hope I can understand ....
I take the opportunity to share this
exercise, done time ago "Mandala 3D"-
Files and images at the following link: http://www.mediafire.com/file/l6otl6249cfc7hm/Mandala_3.rar
Have a Nice Weekend to all
al
7777.444 In reply to 7777.443
Hello Al, Hello James,
thanks for sharing your files. For those who want to write some Poetry inside the nodeeditor, I made a text node:-)
Have a nice day
Karsten
7777.445
Hello Karsten
GRANDE........
al
7777.446 In reply to 7777.444
Where is the Text node ?
it's the Construct2
7777.447
Cool
Message 7777.448 deleted 23 Feb 2019 by JFH
Sorry but how do you obtain the node Text ?
In the construct2.js ? I suppose in folder nodes ?
But curriously it don't appear as show in my previous post!
Very mysterious!
Edit : find it!
I have put twice the file construct2.js : in folder nodes & folder extensions !
EDITED: 16 Jun 2017 by PILOU
Message 7777.450 deleted 17 Jun 2017 by JFH
7777.451 In reply to 7777.450
Thanks now all is fine!
I have put the file in two folders that makes the mess! :)
7777.452
Hi Karsten
The text node is fine, I wanted to ask you,
following James's post, if it's in the future
It is possible to provide all Node Points, even those
mPath, of an output that can be read
from our Text node, in such a way as to return
"Reading "the list of item?
It would be a great advance for the "manipulation"
some data......
Excuse me, if I tedium with these my constant
requests ...
But it is for the goodness of "Elephant"
Have a nice day
al
7777.453 In reply to 7777.452
Hi Karsten,
Following on from my last post, I realise that it maybe confusing to have a text input if it can only accept num array inputs.
As an alternative approach, I have attached image of how node maybe extended to serve as a counter of points in an array.
In the absence of a numbered labelling of points, I have relied on cloning to points spheres of variable sizes to make the sequencing legible. Obviously this method is grossly inadequate. I hope you can see the value of the suggested improvement.
EDITED: 20 Jun 2017 by JFH
7777.454 In reply to 7777.453
Hello James, Hello Al,
Yep - I think it is possible, but I don't have the time at the Moment - some private Problems:-(
Have a nice day
Karsten
7777.455 In reply to 7777.454
Hello Karsten,
Hope everything works out OK
All the best
Show messages:  1-15  …  376-395  396-415  416-435  436-455  456-475  476-495  496-515  …  1856-1859
