 1-18  …  379-398  399-418  419-438  439-458  459-478  …  1859
7777.419 In reply to 7777.418
Cool but i don't want to code! ;) (for the moment)
(if you can give me the line transformed! ;)
PS will be inestimate if you replace edges by cylindric structures and real nodes of junction! ;)
You can of course simplify!
EDITED: 8 Jun 2017 by PILOU
Message 7777.420 deleted 9 Aug 2020 by JFH
Cool! :)
with the colors functions of Moi! (see 3 posts previous)
7777.422
Hi James and Friends ,
I am very happy with your sharing-
I hope that in the future, others will do the same ,
I would not wish that we were just the voices of the chorus-
Good work
al
7777.423 In reply to 7777.422
Hello Al,
it seems that there is a big Inhibition to use and play with the elephant. So someone has to be the "primus inter pares".
Have a nice day
Karsten
p.s.: ... better five lions than 500 sheep. (from Rambo III) lol
Message 7777.424 deleted 14 May 2019 by JFH
7777.425 In reply to 7777.424
Cool!
7777.426
Hello All,
I found a grasshopper youtube tutorial by Wissam Wahbeh
inspired by the cathedral of St.Mary of the Assumption, San Francisco,
Designed by Pier Luigi Nervi and Pietro Belluschi.
https://www.youtube.com/watch?v=o4ufv13EZk4
Nodeeditor process has next to nothing in common with grasshopper steps shown in the video;
it was more about reproducing the end result.
EDITED: 14 May 2019 by JFH
7777.427 In reply to 7777.426
Sorry seems i have not the "Mirror" node !
Your script is for the Official or Modified Elephant ?
Will be fine to have a list of existing nodes! ;)
Something like...(it's an old one)
EDITED: 13 Jun 2017 by PILOU
7777.428 In reply to 7777.427
Sorry I forgot that Mirror was a new node. It can be found here
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.335
otherwise I am using latest mod. It can be found here
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
7777.429
Hello James
Well done James
nice definition_
I saw that, together with Karsten, you defined
a new way to handle points (multiple inputs for Polyline)
I have to do and I have not dealt with the topic ...
You can briefly let me know what you got
with Point Split node
I've seen formulas on the outbound links from the node.....
Thanks in advance for the info
Good afternoon
al
7777.430 In reply to 7777.428
Thx!
More easy with mirror inside! ;)
7777.431 In reply to 7777.429
Hello Al,
<<let me know what you got with Point Split node>>
The SplitPts / PointsExt pairing breaks what would be
one contiguous point array into a series of discreet arrays,
so as a consequence you get separate polylines instead of
one with linking diagonals. Try bypassing these 2 nodes to
see their effect.
<<I've seen formulas on the outbound links from the node.....>>
the inputs to PointExt (xLength, zLength) determine the points
at which to break original point arrays into series of new point arrays.
I hope this helps.
Let me know if greater clarification is necessary.
P.S. New Version using logic nodes for odd number generation attached to earlier post
EDITED: 14 Jun 2017 by JFH
Message 7777.432 deleted 14 May 2019 by JFH
7777.433
Hi james
Thanks a lot for the info you gave me, I saw that
You have also updated the latest files.
Try to understand this method,
even if at first I do not think it's so easy-
I'm used to, with grasshopper to use data,
which may be flat or branched,
I do not know if I can fully understand the potentialities, the outputs of the
Node Split Point (x-length) - (y- length) and (z -length) and mode
in which to operate to branify them
What I understand and that each output alters the Array data in the three
components ...
Graphically, x width, depth y, z height
But how to work with math data is another music ...
Maybe you could send me some basic examples
"Very simple ", to understand the mechanism effectively
Thanks again..... and have a nice day
al
7777.434 In reply to 7777.433
Hello Al,
it isn't so complicated than it looks;-)
If you have a pointarray with e.g. 40 points as an input for e.g. a curve the curve will be drawn from point to point, if the xLength is 40. But if the xLength is 10 and the zLength is 4 you will get 4 independent curves with 10 points in each curve.
It is an internal mechanism or meta information to organize point sequences. Some of the nodes can evaluate this an can process the right result. E.g. the bundle node generates this meta information automatically - for the concate nodes it is difficult to generate this data, because the inputs can have different length and the node will be used for different jobs.
If you want to have a look to this data you can use also the arraylogger ->scroll down, at the end there are the infos.
Have a look into the waveproto1.nod file
The point values in the info panel shows the changes - here you get 6 curves with each curve has 7 control points, without that, you will get one curve with 6*7=42 control points:-(
That was the problem here.
Have a nice day
Karsten
7777.435
Hi All,
I'm trying to make a node that displays it's input value (numeric) for reference checking.
I started with the const node but can not workout how to get the label to display the input value.
So any pointers will be gratefully received.
Also I'm keen to use the node editor for animating mechanisms so a sequence node
to fire when a node sequence should start would be good or if there is a way to do this now
could you let me know.
Barry
7777.436 In reply to 7777.435
Hello Barry,
for animations the Quartz node is the right one. Regarding to your new node:
There is variable in the input and output object called "label". If you set this variable to your input value it should work.
Or post your file with new node you want to create, that I can have a look.
In the attachment you will find a very experimental animation proposal. I don't know if storing pictures with the camera node under windows work.
The camera node saves single pictures that can be glued with mencoder or ffmpeg to a video.
Have a nice day
Karsten
7777.437 In reply to 7777.435
There was a node called Watch. I'll have to look for it...
Message 7777.438 deleted 15 Jun 2019 by JFH
Show messages:  1-18  …  359-378  379-398  399-418  419-438  439-458  459-478  479-498  …  1859
